#2642 | |
I have read some people use spacers on one side to even them out, but I don't like the sound of that. Plus I prefer the flush look over the poke, so I'd have to get higher offsets and then use spacers to correct the side with less poke. ![]()
2006 Holden Monaro - 700+whp ; 2014 Holden Commodore SSV - 400whp |
#2645 |
Well I think I found my problem today. At the top of my coilover is a metal ring. It's off the spring and pretty much crunched up. I need to center it so what can I do lol
#2646 |
I didn't have the alignment done, the PO did - but I looked at the sheet and it's all good. I took a good look at the car underneath and everything is straight and it's got a clean Carfax (which really doesn't mean much). Reading these forums it just seems common for one wheel to stick out more than the other, but those ~11mm really bug me.
#2647 | |
Man w/ CTSV & a Car Seat
#2648 | |
#2651 |
![]() Join Date: Sep 2012
Looking to buy 17x9 +25 wheels all the way around for my s13. i have a couple of questions.. will i need to run any camber on the front and rear for them to fit? will i need spacers to clear the coilover? and how flush will it sit? any help would be wonderful!
#2652 |
Would look pretty close to this: Stock R33 GTR wheels 17x9 +30.
![]() Shouldn't need to run spacers but that all depends on what coilovers you have, how low and how big the springs/perches are. I'd roll the fenders but that should be it. |
#2655 |
How hard would it be to fit a 18x9 0 offset up front on an s14?
I'll be running a 215/35 or 205/40 haven't decided yet. Any help would be appreciated . |
#2657 |
A 215 on a x9 is a perfect fit, a 205 is pushing it a little. But I guess if you're one of those guys that prefers meatiness then yeah they are too small lol .
#2658 |
No, I'm one of those guys that like to shoot for the same overall diameter as stock. Those sizings are undersized even for S13s by comparison and S14s run bigger sizing. 215/40-18 is as small I'd like to run, if I have to, but 225/40-18s are what I've always run on my fronts since 2002.
#2659 |
![]() Join Date: Feb 2012
If your car's low and/or you have drift knuckles then 215/35-18 or 215/40-17 is GOOD for the front to avoid rubbing 24/7 unless you do front tubs. Rears should be stock diameter though. 18x9+0 with 215/35-18 should be perfect with 3 or more degrees of camber in the front.
ACE マジック HEART |
#2663 |
Wouldn't fit in the front. It would probably hit the coilover. Perfect for the rear though. I would go with 18x9 in the front. Really, it's not worth it to go bigger than 18x9.5 in the front, and I think I prefer 17s in the front. 17x9 F and 18x10 R is perfect imo.
ACE マジック HEART |
#2664 |
#2667 |
Q: Will XXR 527 or 530 spokes on a 17x8.25 +25 (or 17x9.75 +25) fit on an Stock body s13 w/ BBK and TEIN MonoFlex? would like to run 245 or 255 square R888 for track setup. four lug. front camber -3.25 rear -1.75
currently on 17x7.5 +43 AVS T7 with a 15mm Spacer to clear the calipers (net: +28). caliper clearance: ![]() thanks for your help! i couldnt find any threads with XXR 527/530 spoke curvature images.
Evo X MR, Z33 Built VQ TT, S13 SR20DET |
#2669 |
I need some input with fitment/ wide body on my s13. I am looking for the stretch poke fitment. Below are my specs as of now. I am looking for another set of tires for more of a stretch with keeping it safe as a DD. Car is going in for paint so want to have the fitment perfect for when the kit is installed. Still need to cut the rear fenders above the body line, if anyone can do a quick line of how high I can cut side to side and up that would be great!
Front Fender: 30mm Rim: 18x11 Et: -1 with 10mm spacer ( final et -11 need spacers to clear 300zx brakes) Tire: 245/35 Camber: -4 ( can't go more unless I still the coil for camber) Rear Fender: 50mm Rim:18x12.5 Et: -18 ( with 4mm spacers final -22) Tire: 285/30 Camber: -1.5 ( can't go more) Thank you for your help! Sent from my iPhone using Tapatalk |
#2670 | |
Retired General
I hope your front fenders are tubbed with that size up front. As far as where to cut on the rear quarter panel, it's just above the body line in an arch like the original fender. There's videos of it all over youtube. Its kinda hard to explain in text. |
