#2521 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
#2522 |
By square set up I was referring to an equal set up front to rear vs. staggered. My question is really just regarding fit. Will 245 35’s fit all around without blowing out my fenders on the street or autox?
#2523 |
not a max tire question, but depending on your height and camber settings, (guessing based off my setup) you'd probably need to have the car not be too low, add camber and roll/minor pull the front fender. Rears, some camber and roll fenders to fit. It's do-able.
#2524 | |
#2525 | |
Banned from the Marketplace
![]() Join Date: Apr 2009
#2528 |
![]() Join Date: Jan 2011
Awesome...
#2530 |
Chassis: s13 coupe
Fender mods: fronts: stock, rears: rolled Suspension: Megan Coils and RUCAS Wheel specs: 17x9 +22 and 17x10 +38 preferred tire size: 255/40 and 275/40 Will the rim/tire combo work on a stock body s13? I know/understand that I will probably have to get the fronts rolled and a slight pull in rear. |
#2531 | |
I've run 245's on 18x9.5's and even nt01 aren't close to being square. I think 265-285 is square on 9.5". I really like 285's or maybe 295's on 9.5" wheels. |
#2532 |
#2533 |
Do your coupe still have the RPF1's on it? What are the specs on your RPF1's? And can you plz post a few pictures of it? Im looking to do the 17x10 +38 and 17x9 +22 RPF1's on my black coupe too.
#2534 |
![]() Join Date: Nov 2006
I'm in the Process of Building a S-14 LS240. The Drivers side quarter had some rust from previous owner's accident that was not repaired correctly. I'm weighting my options on wide quarters Vs replacing the quarter or fixing with bondo.
Looking to run 17x10.5 Cobra Replica's with a 305 or a 295 any suggestions? |
#2535 | |
![]() Join Date: Jan 2003
![]() ![]() Feedback Score: 13 reviews
![]() Quote:
-Both roll and pull, then repair the 1/4 panel and go with the 295/35/17 (this tire keeps your speedo calibrated b/c factory tire diameter on S14 with OEM tire size of 205/55/16 was ~25" tire diameter, same as a 295/35/17). -Only roll the fender, then repair and run a higher offset wheel like a 10.5 +30 and to fit the 295/35/17. -Install flares since your fender needs to repaired anyway, and then run something much larger like a 315/35/17 (25.7" tire diameter) or even 335/30/17 (24.9" tire diameter) if you can swing it financially. Again, someone may have a different opinion based on their experience, but I've made a fitment calc Excel sheet for the S14 and found it to be highly accurate. PM if you need more clarification. |
#2536 |
![]() Join Date: Mar 2003
change it up
Heres mine on the drift spares 18x9.5 +15 26/35/18 front 18x10.5+15 and a 10mm spacer not flush but it gives me a wide range of tire choices 275/35/18 rear in the pics. but it goes up to 295 depending on the track. ![]() ![]() ![]()
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com |
#2538 |
yea lol. Heres a more recent pic, i took the rocket bunny wing off because i didn't like how it flowed with the car. (wing is for sale btw, uninstalled) shameless plug. ![]() ![]() 18x10 +18 265/30/18 18x11 +18 295/30/18 ![]() ![]()
#2539 |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
I don't know if I ever told you, but that paint came out GREAT for a diy job.
![]() ![]() Friends help you move. Real friends help you move bodies. |
#2541 | |
Also FYI, I strongly suggest not running Cobra replicas: they are 13 pounds heavier in rotating mass PER WHEEL over Enkei RPF1s. If you want to go wide and don't like the look of RPFs, go with CCW Classics. You can get them in whatever size and offset you want. If you want grip for an LS, go widebody and run 17x11 CCWs with 335/35/17 for daily driving ![]() |
#2542 | |
thanks hell no i don't dd, that shits uncomfortable as fuck.
#2543 |
Hahah, still baller
@hcr32love 400whp NEO R32 Sedan |
#2544 | |
#2545 |
Damn I'm lovin the Professors on this page. Why's the s14 so uncomfortable? No insulation or no a/c? non reclinable/non padded seat? Spring rates set to GRANITE?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#2546 | |
Contrary to the crap i talk, i drive it all the time though never to my job just after work or on weekends just around for fun, I've driven it 5 hrs in the last two nights just playing with the cooling system to figure out if i have blown head gaskets or my cooling redesign was flawed turns out a little of both i think. The seat is a momo sport cup, not terrible but it is a bucket. Springs are 10k front 8k rear, although it rides surprisingly well, as long as you don't hit any bumps, or road reflectors. And of course no a/c and in florida no less, no sound deadening, no windshield wipers ( i regret this one), so its a sauna, and if it rains you have to drive with the windows down or it fogs up and you can't see crap. Moral of this story, don't build race car show cars, that you actually race, and take to car shows, and drive on the street. Unless like me tonight you want the owner of the brand new 911 turbo porsche you just wooped giving you props on how sick your car looks lol.
#2549 |
![]() Join Date: Mar 2007
Anyone encounter understeer with 265/40/17 up front?? I going to do 255/40/17 up front and 275/40/17 in back. Current setup is 235/40/17 up front and 255/40/17 in rear no pull or roll fims are 17x9 +22
Id like to run 265 up front
Obliterate |
#2550 | |
![]() It wouldn't be anything you couldn't tune out.
