#2491 |
![]() Join Date: Oct 2006
silly question (and sorry if it's been asked already).
when trying to correct front suspension geometry on a lowered car, why hasn't anyone just re-drilled the bolt points for the front lower control arm where it bolts to the sub-frame? EDIT: Yes I realize the sway bar and tension rod bolt points on the lower control arm would be a stupid angles in this scenario, but both of these are easily corrected imo. |
#2492 |
![]() Join Date: Nov 2005
Read through the first few pages. It changes the relationship between the LCA and the steering rack/tie rods, and would make for some nasty bumpsteer. You'd have to move your rack up as well.
#2493 |
I think this bumpsteer problem is just as correctable.
Couldn't you just put a spacer above the outer tie rods to correct that? The spl parts even include "T2024 spacers" that should work perfect.
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#2494 |
Unless you're low enough to need those spacers anyway. Then you have to think about the arcs of the control arm vs the tie rod. Are they going to be in sync now?
#2497 | |
S-chassis front lower arm/tension rod combo should be available this month according to Dan's last report.
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 03-02-2011 at 06:04 AM.. |
#2498 |
![]() Join Date: Nov 2009
isnt it gonna be the full package with the drop spindle?... and will they address the issue of having some kind of lock limiter for grip guys as i run pretty beefy 295s up front... i wants to buyz...
#2499 | |
200sx s13 - 705whp -youtube.com/mobne -Streetperformance.se |
#2501 | |
#2503 | ||
You could have them just do the ball joint mount drop on your knuckles, and not their angle kit. Driftworks GeoMaster - Offset Rack Spacers Driftworks Shop Rack or spacers need to be modified for correct LHD fitment.
#2505 |
So, back in Jan. I was talking about a conversation I had with Shinji from HeyMan! about steering knuckles. He was explaining how if you shorten the knuckle too much, it makes the steering too fast, and the rear of the car will oversteer TOO much and your car will feel very loose.
Well flash forward to the other day. I was watching a TV show on NASCAR wrecks and stuff. I noticed that every time a car would spin out, the driver would countersteer the car (duh), but the steering angle was minimal! Then it dawned on me, NASCAR's need a lot of grip for the driving they are doing. I believe one way they get some grip is by the steering set-up. Their cars are set up with slower steering, which results in more rear grip. I just thought I would try to explain this here, maybe it will help some people understand knuckles more, idk. Hopefully I made sense in this post, lol
#2506 |
![]() Join Date: Apr 2004
Slower steering ratio gives you no more grip.
Faster steering is only a problem if the driver is so unskilled they can't adjust to it.
#2507 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
It's not so much grip dependent, it's just how to keep them safe at 190mph
#2508 |
I think sometimes in Japan, philosophy trumps logic.
#2510 |
Well if they suck in rear grip, they REALLY suck in front grip. It's really just that people suck at balancing the suspension, which is the reason this thread was made.
#2511 |
![]() Join Date: Sep 2004
No, it's Zilvia. the answer to half of the questions on this site are 3 posts above the questions.
1. hey guys I got hot dogs at pinks, they're delicious. 2. man those dogs look good. 3. yum (mglngth) 4. i'm hungry now. 5. excuse me can you explain where you got these hot dogs from, I would like to try them out in my stomach someday. WELCOME TO ZILVIA!!! ![]() |
#2512 | |
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
THISSS. I've noticed such huge improvements on my car. I want to go to a damn road course and see what this thing can really do now. |
#2513 | |
Just a little suggestion so you enjoy yourself first time out on track.
#2515 | |
yo I forget but did you get the driftworks spindles? I haven't bothered reading the last million posts hehe. if so let's hit up streets of willow. I was able to test out the front gp sports knuckles, but now with the driftworks knuckles I'm curious to know how they are.
.25 till 3 |
#2516 | |
![]() Join Date: Feb 2009
#2519 |
Someone who is actually interested in learning instead of shoveling out their opinion to everyone.
