#2371 | |
If you want it as close as possible, have your wheel straight before you take it off (preferably come to a stop with it straight, don't turn the wheel while it's parked) put the wheel, qd, and hub all together. Then position it on the column as straight as possible. Leave the hub on the column, pull the wheel and qd off the hub, bolt the hub in place and put the rest back on. just make sure to put it all back in the same position without moving the wheel while doin so. If it is slightly off to where repositioning the hub won't help, get an alignment done to straighten the wheel, or leave it.
#2372 |
![]() Join Date: Dec 2003
im pretty sure hes talking about distance between him and the wheel.\
and that would depend on wheel depth and hub length.
![]() **CoUpe LOve** Member #00 |
#2373 | |
in that case, Wake is right, it all depends. as long as you know the depth of each piece, you can figure it out and compare it to your stock wheel. ex- S14 stock wheel is 135mm from the base (where it bottoms out on the column) to the face of the wheel.
#2374 | |||
![]() Quote:
NARDI Deep Corn Suede Steering Wheel : 330 & 350mm because i thought that was width of it? i want an aftermarket wheel for security purposes. but i like were the oem wheel sits now. so id like to be able to get an aftermarket wheel as close as possible to the size and the placement of the oem wheel. its for an s13 if that has anything to do with it. thanks for the help thus far.
WTB: 1/24 scale chuki s13 model. |
#2375 |
![]() Join Date: Sep 2009
![]() Feedback Score: 15 reviews
so i asked a question why my a/c/heat only blew on 4 in my s14
i replaced the resistor and it works! =] so if anybody else have the same problem of the a/c and heater blowing only on 4. try changing it.
straights are for fast cars, corners are for fast drivers. |
#2376 |
![]() Join Date: Apr 2008
situation.. i have a 98 kouki with 6k hids.. cop pulled me over and gave me a fix it for it..(ignored my exhaust, my tint, QR,) He said, i cant run that coz its blinding people. (even tho i know he was behind me the whole time, so im sure he wouldnt evenknow). And his explaination was, im putting HID on a non HID housing, which, i thought the projectors are HID housing even tho the stock koukis doesn't do a good job of projecting a very nice cut off.. in the ticket it said, modified headlights.. He even asked me if i still had my stock headlights.. i said those are stock headlights.. he looked at me like i was the biggest liar in the world.. im pretty sure he is thinking of the zenki..
question, do i have a legitimate case of fighting it? i know i could just put the stock bulb and get it over with.. but it just pisses me off, that he looked at me as if i was lying to him about it.
#2377 |
![]() Join Date: May 2010
ok this may be a noob question but i just swaped clusters out of a ka24de and i have a single cam. well i switched the tach and that works but i cant get the speedo to work. do i need to change the wiring harness that comes off the speedo motor? this is my third cluster cause they stop working. maybe speed sensor bad? any advice
#2378 | |
i have 6k hids as well on my kouki. i know this doesnt help your question, but does your hids looks a little bit blue? i would expect it to b white.
#2381 | |
#2383 |
if you put hids in non hid housing it does blind people. its a different light reflection pattern in both headlight housings. I put S4 lights on my old A4 so i could get around that.
#2384 |
but arent the kouki head lights projectors? i understand how bright it is if its not projected.. it does blind people and its annoying..
#2385 |
It is a projector, but it is not an HID projector. The optics are designed differently between HID and non-HID projectors. HID bulbs and non-HID bulbs generate the light in a different spot within the bulb, so the non-HID optics do not work with an HID bulb.
See the following link for a good description of the differences: Daniel Stern Lighting Consultancy and Supply "The only available arc capsules have a longitudinal arc (arc path runs front to back) on the axis of the bulb, but many popular halogen headlamp bulbs, such as 9004, 9007, H3 and H12, use a filament that is transverse (side-to-side) and/or offset (not on the axis of the bulb) central axis of the headlamp reflector). In this case, it is impossible even to roughly approximate the position and orientation of the filament with a "retrofit" HID capsule. Just because your headlamp might use an axial-filament bulb, though, doesn't mean you've jumped the hurdles—the laws of optical physics don't bend even for the cleverest marketing department, nor for the catchiest HID "retrofit" kit box."
#2386 |
![]() Join Date: Sep 2008
Hey guys, a friend who is helping me with my oil filter relocation and oil cooler install (haven't ordered yet, needed to ask this first), drew up and example of what he thinks I l'll need. Just wanted to compare and see what others did, as there aren't threads that show picture specifics of every fitting they used.
![]() So did anyone else happen to use anything different than: two 90's in and out from the sandwich plate where the oil filter once resided, and then two nineties going into the filter located wherever i choose to put it and two 90's coming out and going to the oil cooler, and then you've got two straights going to the oil cooler. Let me know if you guys thing this would be a good idea? Any tips, advice would be helpful. Thanks. |
#2387 | |
![]() Join Date: Jun 2010
im a tall guy and i have also been thinking about wheel combos the guy above posted a s14 has 135mm base height....im assuming s13 is similar..if you have a 80mm hub adapter (more like 100mm if you're going quick release) + 80mm offset steering wheel you would have a base height of 160mm or 25mm (1 inch) closer to you as the driver... i think ill be cool with that and i tried gettin info for the post above but failed to quickly/easily come up with a pic of a oil cooler/relocate kit...but no dice IMO a filter relocate is pointless |
#2388 | |
i need to try that .but how do i remove the blower from my car to replace it s14 aswell
LoW bAlLiN eVerY DaY!! ![]() |
#2390 |
![]() Join Date: Feb 2010
![]() Feedback Score: 11 reviews
Found a 98 sr20det vvt longblock for sale. Engine is blown, however it is still rebuildable. I want to save money on shipping and only buy relevant parts that will help me with the rebuild. The rebuild plans on this block is 2.2L (forged buttom end) with a head capable of high revs. What I'm asking for is help making that list. I think I need the following:
Bare block,crank,bare head with valve cover,vvt sprocket,ecu,and harness. |
#2392 | |
![]() Join Date: Jul 2007
![]() picture taken from http://zilvia.net/f/cars-sale/334268...-2800-obo.html if this pic need to come down, sorry, and pm me. |
#2394 | |
![]() Join Date: Nov 2003
Thanks! Do you know what the difference is between the fans? I know whatever the one is I have fits on the water pump pulley fine... |
#2395 | |
![]() pic taken from http://zilvia.net/f/cars-sale/334864...-flush-eh.html will remove on request. see what some searching will do? youre welcome |
#2396 | |
I know the 300zx are the same, but there are no z's at pick and pull here, a ton of q45's though. Anyone? Yoke off Q45 same as 300zx?
Nothing says racecar like a stock car with no interior. |
#2397 | |
#2399 |
#2400 |
![]() Join Date: Aug 2005
i actually found the nuts.
M2 Tuning - Wheel Adapter, Wheel Spacers, Wheel Locks, More! i never heard of them. anyone from socal heard of M2 Tuning?
