Old 12-03-2009, 12:54 AM   #211
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
if it was that damn easy we would have all ben doin it.i believe the 95-98 head flow better than the 91-94,now if you build a high comp motor from there then you should be golden but tuning it is goin 2 play a big role in that and modifing the intake mani
project-D180 is offline   Reply With Quote
Old 12-12-2009, 12:06 PM   #212
articdragon192
articdragon192's Avatar
Oh hmmm, I never posted up my dyno sheet here. Guess I'll share my old set up
Mods:
K&N Drop in filter
248/248 cams
DC Sports S13 Header
Gutted cat (dumb, I know)
RSR Ex-Mag (3" piping)
Base Timing advanced 5 degrees
Auto ECU
RPS 6 Puck
Fidanza 14lbs Flywheel
~154 whp
~152 ft-lbs
Lemme tell you, this motor was a blast to drive.
And dyno vid
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 12-19-2009, 09:29 AM   #213
shinrekka
shinrekka's Avatar
shinrekka is an unknown quantity at this point
no built SOHC motors?
Wow, such a cheap and easy motor and no one does anything with it. Im looking forward to putting mine together this spring and everyone just hates and never gives it a shot. I want to see some high compression, lumpy cammed SOHC motors out here.
shinrekka is offline   Reply With Quote
Old 12-24-2009, 10:10 AM   #214
speedfreak90
speedfreak90's Avatar
speedfreak90 is an unknown quantity at this point
i just want to say thanks for this thread. really helped me get an idea of the route i wana take on my N/A build...
speedfreak90 is offline   Reply With Quote
Old 12-24-2009, 02:15 PM   #215
project-D180
what route r u takin?whats ya plans on the build
Old 12-29-2009, 11:41 PM   #216
Iceman00
Iceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymore
Wow it has been a while, I see not any huge progress has been made..
A few points:
Off the shelf headers will probably suck. If you want real power, look into a Burns collector or some Kromer Kraft headers/
Stock/factory cams are shit. You can advance and retard them all you want, but a good set of cams will go a long way
Tuning is a huge part of the pie. There is a reason that I was able to match a lot of these guys number with Just an intake, header and ECU tune. No cams, Stock exhaust. JWT may be mild, but it was a step in the right direction.
Now carry on...
* > Drifting
JWT powered Altima
Iceman00 is offline   Reply With Quote
Old 12-29-2009, 11:43 PM   #217
Iceman00
Originally Posted by Iceman00 View Post
Doesn't the Dynopack Rate at the Hubs, and Not the wheels?
Anyhow, Like I said, Completely Stock Cat, and 1.75" Exhaust, and Automatic Trans. Not to mention the Rediculous heavy 50lb Wheel and tire combo (Sentra SE-R wheels).
weaksauce.
* > Drifting
JWT powered Altima
Old 01-21-2010, 02:26 AM   #218
smbonn2005
smbonn2005 is an unknown quantity at this point
Well I fail at just now finding this...
I'm in the middle of building a High CR N/A KADE =)
JE 11:1 pistons
Eagle H-Beam Rods
Brian Crower Stage 3 cams, 272/272
Supertech dual spring valve springs
Extremely ported head
Lightweight pulleys
lightweight flywheel
spec stage 2 clutch
excessive intake mani
2.5" long tube header, 3" test pipe, 3" Tanabe cat-back
knife edged and fully balanced crank
q45 throttle body
and a whole bunch of other things
Last edited by smbonn2005; 01-21-2010 at 02:29 AM.. Reason: adding more things that i forgot
smbonn2005 is offline   Reply With Quote
Old 01-23-2010, 06:47 AM   #219
shinrekka
shinrekka's Avatar
Im gathering up the bits and peices of my next rebuild, and really dont have many options for high compression pistons, and my cam selection is also very limited to what im willing to use. This is my what my build will consist of.
Rebuilt KA24E, tuned for E85 on an AEM EMS
-arias 10.8 compression pistons,
-nismo R4 cam,
-OBX header, 3" apexi n1 exhaust
-Ebay $9 intake w/ k+n filter
-Lightweight fidanza flywheel
-Lightweight driveshaft
My queston is, if I use the arias 10.8 or 10.7 compression pistons will I be able to use the Nismo R4 cam and not have any issues with piston to valve clearence?
Dosent sounds like much of a build but im also going to be running this motor with E85, and tunning it with an AEM ems so im hoping to hit around that infamous 200whp mark.
Old 02-07-2010, 12:52 PM   #220
sav180
sav180's Avatar
sav180 has made poor choicessav180 has made poor choicessav180 has made poor choicessav180 has made poor choicessav180 has made poor choicessav180 has made poor choices
they sould have valve relief built into the piston for added inssurance..they should clear though..you would have 2 check the clearance when u get them or jus askin the company your buyin them from
Raw backin these honda's
sav180 is offline   Reply With Quote
Old 02-07-2010, 12:54 PM   #221
smbonn2005
put clay in the cylinder, bolt the head on, turn the engine with a breaker bar ... check clay for valve clearance
Old 02-15-2010, 01:45 PM   #222
iwannaslyde
iwannaslyde's Avatar
iwannaslyde is an unknown quantity at this point
^really? what kinda clay are we talkin?
iwannaslyde is offline   Reply With Quote
Old 02-15-2010, 07:21 PM   #223
smbonn2005
Don't quote me on this but I'm pretty sure just plain old modelling clay would work fine. Just make sure you clean the valves/pistons/combustion chamber afterwards just in case of any residue left over
Old 02-15-2010, 07:53 PM   #224
PoorMans180SX
PoorMans180SX's Avatar
Just wanted to let you know about some products from Xcessive Manufacturing that you might want to look into:
Intake manifold:
ITB intake manifold:
Old 02-16-2010, 11:50 AM   #225
smbonn2005
Yeah they have some awesome parts for the KA, just a forwarning though. If you do get their intake manifold with the plenum, check for small pinholes in the plenum itself. I did have a small one. Could have become a very annoying vacuum leak. Otherwise I love their parts!
Old 02-25-2010, 06:15 PM   #226
jonnybonds84
jonnybonds84's Avatar
jonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to all
I thought I would post this since I had a bitch of a time finding it. It is not in the FSM and it's way better to see where all the smog vacuum line go.
SPENCER DOUGHERTY RIP ME OFF. SEARCH HIS REVIEW THREAD.
jonnybonds84 is offline   Reply With Quote
Old 02-25-2010, 09:17 PM   #227
smbonn2005
Awesome find! thanks for posting it up!
Old 04-08-2010, 12:53 PM   #228
project-D180
dyno #s comin soon..school starin to do dyno runs next week so i should have somethin to post up
Old 04-08-2010, 01:19 PM   #229
smbonn2005
I'm still waiting to get my machine work done >.< lol
Old 04-15-2010, 01:39 PM   #230
project-D180
what was dyno'ed wit a basic rom tune n my timing is a lil off
Old 04-15-2010, 02:00 PM   #231
project-D180
will be postin more soon once i get it tweaked some more n better tune
Old 04-15-2010, 02:05 PM   #232
smbonn2005
Whats been done to that motor? And what were torque numbers?
Old 04-16-2010, 04:33 AM   #233
project-D180
je 11.0.1 pistons,eagle rods,xcessive intake mani,n60 maf,shaft masters aluminum drive shaft(free shippin i might add so check'em out),lightly ported exhaust side of head,obx headers and catback,264x2 brain crower cams,and polished n rebalanced crank..a retuned stock ecu from EFI Specialist (Powered by CubeCart).light tune..
Old 04-16-2010, 04:39 AM   #234
project-D180
a/f and torque # didnt print out cuz somethin was wrong with the computer thats pose to get fix.sucks cuz i wanted to kno that as well..wasnt really surprise at the out put cuz the tune is crap.i still need some cam gears,shim my cams again,bigger injectors,a/f gauge n a real rom tune.lookin at nistune or enthalpy..i should be able to put 200 or more to the wheels when im done(crossin fingers)lol
Old 04-16-2010, 04:40 AM   #235
project-D180
its not bad for the most part
Old 05-15-2010, 10:52 AM   #236
project-D180
what u guys think??if i had money for a stroker kit i would make over 200 easy bored over at 20~40 over
Old 05-23-2010, 05:39 PM   #237
project-D180
???no more guy's with n/a build eh???
Old 08-11-2010, 03:23 PM   #238
comatoseculture
comatoseculture is an unknown quantity at this point
Nothing in the works yet, just lurking...
Have you^ (D180) had any advancements? Get to do another dyno run?
comatoseculture is offline   Reply With Quote
Old 08-14-2010, 06:36 AM   #239
project-D180
unfortunately no... had some duush shop do my clutch n flywheel o got n they f'ed up my damn trans n clutch..so it was makin noise n not disengauging..so im dealing with that at the moment.but i did find somethin interesting 200whp NA Dyno - Page 2 - Nissan Road Racing Forums...check this out
Old 09-03-2010, 11:35 PM   #240
Durty
Durty is an unknown quantity at this point
Anyone spray on top of their high compression set up?
Durty is offline   Reply With Quote
