Old 02-06-2014, 03:36 PM   #211
Surffer227
Surffer227's Avatar
Surffer227 is an unknown quantity at this point
Can someone here help me out, my power steering bracket on my ca is completely striped, dumbass that put it in before me -__- and I keep loosing belts cause the whole pump can flex on the bracket, so is there another bracket/tensioner setup that's useable?
Surffer227 is offline   Reply With Quote
Old 02-06-2014, 09:58 PM   #212
shogun!
shogun!'s Avatar
shogun! is on a distinguished road
You could move the pump to a lower position.
Either make a modified bracket out of the old one or buy/weld a new.
I cut and modified mine to fit it where the AC-pump used to sit.
My +700hp RS13
shogun! is offline   Reply With Quote
Old 03-18-2014, 01:59 AM   #213
jdm_rydaa
jdm_rydaa's Avatar
jdm_rydaa is an unknown quantity at this point
What is this ? I was thinking for oil pressure gauge. But I want to double check. ImageUploadedByTapatalk1395129563.926959.jpg
Live Life Sideways
jdm_rydaa is offline   Reply With Quote
Old 06-02-2014, 01:36 PM   #214
Jonathan76
Jonathan76 is an unknown quantity at this point
Does anyone know were i can find a ca18det injector resistor or(dropping resistor), oem or something else that will work?
Jonathan76 is offline   Reply With Quote
Old 06-02-2014, 01:41 PM   #215
omgwtf
omgwtf's Avatar
omgwtf is an unknown quantity at this point
4g63 dsm resistor should work
Sent from my SM-N900T using Tapatalk
omgwtf is offline   Reply With Quote
Old 06-02-2014, 01:42 PM   #216
Jonathan76
Thanks do you know were i might be able to find that? @omgwtf
Old 06-10-2014, 08:07 PM   #217
omgwtf
omgwtf's Avatar
Junkyard? EBay?
Old 06-11-2014, 04:12 AM   #218
Nategreat923
Nategreat923's Avatar
Nategreat923 is making a name for him/her selfNategreat923 is making a name for him/her self
I used a 1995 honda accord EX one. The engine was the F22 single cam vtec. Should be plenty in a junk yard near you I can even run out to my wife's and snag a picture of where it's located for you if need be.
Nategreat923 is offline   Reply With Quote
Old 06-11-2014, 07:09 AM   #219
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
http://www.ebay.com/itm/1g-DSM-90-91...item3ce15ca76f
OR
http://www.vividracing.com/catalog/j...x-p-12658.html
This is cheap.
g35gabby is offline   Reply With Quote
Old 07-31-2014, 03:51 AM   #220
scoobthadude
scoobthadude's Avatar
scoobthadude is an unknown quantity at this point
Mounts!
as far as mounts, anything aftermarket? motor and tranny
scoobthadude is offline   Reply With Quote
Old 07-31-2014, 08:43 AM   #221
Croustibat
Get nismo ones, best you could get. The tranny mount is the same for SR20/CA . Engine ones are not the same, so make sure you get the CA18DET ones or you will end up with a misaligned tranny mount.
Old 03-02-2015, 08:39 PM   #222
Canadian_S13
Canadian_S13 is an unknown quantity at this point
CA CA18DET A/C Compressor
Hi Everyone,
I am rebuilding my CA engine after blowing the piston rings, I know this is not on many people's lists when doing their rebuilds but seeing as this is a daily driver I want air conditioning. My current AC compressor is K.I.A (Seized bearings I think..) and I am not able to get a new replacement through Nissan Japan. Anyone have a working unit laying around for sale?
I have read that you can use the KA SOHC compressor with the CA pully, clutch and custom bearings... But the threads are so old and there really is not much for proof to go on. Has anyone done this? or how has anyone else fixed their AC issues?
Thanks for you help,
Canadian_S13 is offline   Reply With Quote
Old 04-10-2015, 02:11 PM   #223
wiring specialties
wiring specialties's Avatar
wiring specialties is an unknown quantity at this point
Let us know if we can assist you with anything.
http://www.wiringspecialties.com/s13ca18det.html
wiring specialties is offline   Reply With Quote
Old 05-06-2015, 02:00 PM   #224
purplove
purplove's Avatar
purplove is an unknown quantity at this point
I have a wiring specialties harness, thought it was going to be 10x better than the old brittle stock harness but ended up finding out a few negative things about it. The knock sensor plug is the wrong size and is missing pin #8. This happens to be the switched ground for the butterfly valves and made the car pretty laggy. Wiring specialties is the only company out there making a replacent harness for the ca18 so I'm not here to bash on them but to let wiring specialties/other enthusiasts know about the issue and hopefully they will make an updated version in the near future.
purplove is offline   Reply With Quote
Old 05-06-2015, 02:13 PM   #225
wiring specialties
Hey, with all of the harnesses we have sold this is the first time we have heard about the knock sensor issue happening. Any chance you can post a photo of it so we can see the issue? or even email it over so we can talk. It seems to be very odd and we would love to take care of it. As for the butterfly valves I am sorry to hear that, feel free to email or call us so we can assist and take care of any issues/problems you might have so you are 100% satisfied
Old 06-05-2015, 07:13 PM   #226
mobr86
mobr86 is an unknown quantity at this point
Maybe I'm over looking it but I'm not seeing a forsure answer. Will the 88 pulsar throttle position sensor work on the JDM ca18det?
mobr86 is offline   Reply With Quote
Old 08-23-2015, 12:51 PM   #227
neftaliesquivel0
neftaliesquivel0 is an unknown quantity at this point
Ca18det FAQ
So my brother and I import cars and I decided to buy an s13 Silvia vert k series. The problem with the car is that the engine is misfiring. I just changed the spark plugs (I used the ngk cooper spark plugs) and I also changed the oil. Before changing the oil after putting in the new spark plugs the car was literally bone dry. The car would stay at about 500rpm but once I changed the oil (I used valvoline premium 10w30) the car stayed around 600-800rpm. It runs a little better now that I gave it a bit of maintenance but I'm still having trouble trying to figure out what is making it stay below 1000rpm. Any suggestions?
neftaliesquivel0 is offline   Reply With Quote
Old 08-23-2015, 01:17 PM   #228
Croustibat
Check ECU maintenance codes, it should help. If there still is the HSS, remove it, it is known to cause problems. Clean the idle valve too, and check you don't have vacuum/boost leaks. That last one is easily the cause of 90% of the problems on this engine.
Old 08-23-2015, 01:56 PM   #229
neftaliesquivel0
Thank you so much! I will definitely consider your advice.
Old 08-23-2015, 02:02 PM   #230
purplove
purplove's Avatar
You need a ka24e tps sensor
Old 08-23-2015, 02:08 PM   #231
purplove
purplove's Avatar
Thanks for replying. I actually got rid of the knock sensor plug that didn't fit. It was too small for the knock sensor so I chopped the one off of my oem harness and soldered in. I will message you some photos of the pin on the ecu that's missing cus it's a real bummer for anyone trying to run the butterfly valve system like myself.
Old 08-23-2015, 02:09 PM   #232
neftaliesquivel0
Where in the engine is it located? How much will it cost and what does it do?
Old 08-23-2015, 02:11 PM   #233
neftaliesquivel0
Oops I thought he was talking to me lol
Old 09-22-2015, 06:24 AM   #234
codyzsilvia
codyzsilvia's Avatar
codyzsilvia is an unknown quantity at this point
I have been told a KA24DE alternator with brackets and power steering pump with brackets will bolt right up to CA18DET, can anyone elaborate if this is true or not?
Was given an RB20DET PS pump when I bought the car, it does NOT work with CA18DET, HICAS or not.
codyzsilvia is offline   Reply With Quote
Old 09-22-2015, 06:31 AM   #235
naedeloc
naedeloc is an unknown quantity at this point
I have to stop at my storage unit tonight. I can take a picture of both ka and ca brackets and pumps. If you dont get it figured out by then.
naedeloc is offline   Reply With Quote
Old 09-22-2015, 10:40 AM   #236
purplove
purplove's Avatar
They will ALMOST bolt right up. Slight modification will be needed, but nothing major.
Old 09-22-2015, 11:31 AM   #237
codyzsilvia
Sweet, I figured as much, thanks a lot. I will be buying a spare CA head and a CA power steering pump this weekend so if the new one shits out on me again, I'll just use the KA pump. Thanks!
Old 10-19-2015, 07:02 PM   #238
humilde_s13
humilde_s13's Avatar
humilde_s13 is an unknown quantity at this point
[emoji30] I still got my ca parts no buyers
Sent from my iPod touch using Tapatalk
I will give you my pistol ammo at the speed of light towards your doom
humilde_s13 is offline   Reply With Quote
Old 10-20-2015, 06:47 AM   #239
cpt_slow
cpt_slow is an unknown quantity at this point
anyone used this before?
https://conceptzperformance.com/Cart...n.php?II=24172
Nismo 30100-RS225 Sports Clutch Kit, Disc Type Coppermix - Nissan 240SX / 180SX / Gazelle S12 / S13 / S14 / S15 CA18DET / SR20DE
cpt_slow is offline   Reply With Quote
Old 11-03-2015, 08:23 PM   #240
wolf904
wolf904's Avatar
wolf904 is an unknown quantity at this point
I do not know if this has already been stated, but q45 ignitors will work on ca18det. You just use one obviously, since they are v8 they essentially are like 2 CA's thrown together lol and have 2 ignitors for each side. Have to use the earlier years, the later years are the sr20 style ignitors. I don't know how many people are still rocking CA in 2015 but figured I'd put this out here.
wolf904 is offline   Reply With Quote
