Old 11-11-2015, 06:58 AM   #211
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
Haven't updated in a while, but I've been continuing work, mostly on the suspension. Planning on a VE head swap over the off season, so tuning got put off until spring.
Got a whole bunch of new GKTech parts, an OS Giken diff for a GTR and S14 subframe to put in soon. Need to get some 350z 31 spline diff stubs machined for the OSG and then I can put it all together. My old Nismo GT LSD is for sale btw, 6x1 Q45 30 spline stubs included... Also selling my old Driftworks Geomaster 2 knuckles, front and rear.
Anyway, here's some pictures:
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
Old 11-11-2015, 09:16 PM   #212
Hoonigan19
Hoonigan19 is an unknown quantity at this point
sick build man
Hoonigan19 is offline   Reply With Quote
Old 07-06-2016, 08:31 AM   #213
LuckyX2
LuckyX2's Avatar
Well, I haven't updated in a while since apparently whoever I was using to host my pictures sucks and went down, so most of my pictures are gone and it's a bit frustrating...
Anyway, I've been working on doing a P12 VE headswap lately after I shattered two rocker arms in my DET head. The head was at a machine shop for two months to get an hour and a half valve job, so that put me behind quite a bit this season.
Attached is a picture of the freshly cleaned up head/valves and two pictures comparing the old DET intake ports with the VE intake ports.
Also, I ordered the GKTech Z33 trans parts to eventually do that conversion.
Old 07-28-2016, 06:57 AM   #214
LuckyX2
LuckyX2's Avatar
Head build is done. Running again in a week or two if there's no issues.
Old 08-27-2016, 04:31 PM   #215
LuckyX2
LuckyX2's Avatar
Well, my dyno was today. Went well, until I started getting what I think was spark blowout around 20psi.
Still, I managed to pull out 404whp and 338ftlbs at only 20psi and 6500rpm. I think that's a pretty good sign that 550-600whp is in there somewhere with 25-30psi and 9k rpm.
Anyway, here's the printout I have that's closest to the 404whp run. I wound up not printing that one amongst scrambling to figure out why spark was cutting out.
The fluctuation is the closed loop boost controller. Never got around to fixing that.
Here's one of my earlier pulls where I was testing just the low lobe so I had the switch point set high at 5k.
Look at that jump in torque when it switches. wow.
Finally, here's a log of the backfires.
You can see AFR is good (12.2) leading into the two lean spikes that were accompanied by backfires so I don't think it was fueling. My guess is spark blowout, I'm gonna check my plugs. Thoughts?
Old 08-29-2016, 04:19 PM   #216
insa
insa is an unknown quantity at this point
Had a similar issue on the dyno once, was solved with new plugs. Good luck!
insa is offline   Reply With Quote
