#211 | ||
![]() Join Date: Nov 2008
#213 | |
![]() Join Date: Jul 2011
![]() Feedback Score: 7 reviews
Back to E85 now? ![]() |
#214 |
my race motor is getting converted to E85 with tuned down rci 2000cc injectors..... cant wait to get this beast on the track.......
and for those of you talking about water as a product of E85 vs gas, water is a product of any combustion reaction, chemistry basics..... |
#215 | |
SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum - View Single Post - Formic acid? Details on your motor? |
#216 |
stroker sr22, darton sleeves, je pistons, bc rods, bc crank, pretty much all hks valvetrain, right now hks gtrs turbo, im going to see how much i can make with that, but most likely ill be switching that with my gt35r twinscroll. looking to make 550ish with that turbo on E85.. (just about everything that can be done to the motor has been done, i just dont feel like listing all the mods.....)
#217 | |
#219 |
Forgot about the 3076, that'd work too. Basically I just think a GT35 is too large for 550whp on a 2.2L and E85 and he'll be sacrificing a good bit of response. Hell, I'll be shooting for 500whp hopefully with a GTX2867 or EFR6758 on a 10:1 2L with E85. If I can do that (and I believe I can) then a GTX30XX should have no problem getting to 550whp on a 2.2L (8.5:1?)
#221 |
I wouldnt count on 500 from the 2867 and Im unfamiliar with the 6758 but it sounds like a similar sized turbo with a slightly larger turbine?
I wish I would have started a build thread on zilvia like i did on the other forums. I dont know If I listed any of the specs of the new engine I working on right now. I wish I would have sold off my 2871 and went to the 3076 and I may later on..... I went with a t3 divided housing for my 2871R with a UNDIVIDED maxworks manifold and a sound performance quick spool valve. Engine is darton sleeved and bored to 90mm and stroked to 92mm with K1 full counterbalanced crank. 10:1 compression custom made weisco pistons (mofos took 3 months to get designed and made). Oil squirters had to go. Cosworth head gasket. Tial mvs wastegate. Greddy intercooler, greddy IM, greddy fuel rail, aem fpr, in tank walbro feeding inline walbro, 4 bar base fuel pressure, ID1000s. Spitfire coils, highport se-r intake cam, gtir exhaust cam. Wanted to go for crazy spool/tq from a sr to be able to make good low end tq and didnt want to give up any hp from my last engine setup which was just a 9:1 2.0 with t2 2871r on e85. I was happy with the hp and didnt want to give any of that up, but wanted more power down low so didnt want huge cams, didnt want a bigger or smaller turbo, didnt want to budge on hardly anything so I made the engine bigger, higher compression, and quick spool valve |
#222 | |
I made 488whp on a rb25 at 22-24 psi with a 35r on pump. The customer only allowed me to rev to 7k due to the block being stock, stock oil pump and no oiling mods. Its hp was climbing strait up till the limiter and I know at the same boost level it probably could have made 550 on pump easy, that just isnt what I was paid to do though... That turbo had decent low end response (I know rb and sr is apples to oranges). Even though it didnt "kick in" until later on in the rpms, the power was still stronger that some of the smaller turbo combos I have seen people run. ![]() He was still making 240whp at 4k I would have loved to seen this thing with a built block on e85 on about 30lbs edit: On the street, this car felt like its acceleration was very lenier, it didnt get "faster" when the power came on because it just blew the 275s off at all speeds I felt comfortable being a passenger (100mph) Which brings me to a question for yall doing well over 600, are you running drag radials at all times? My car is a drift car so 600 isnt necessary to me, but it seems that it would be difficult to put down much more than that in our cars without some healthy tires. |
#223 | ||
My example build would be Enjuku Racing's 480whp 11:1 E85 SR20 with a GT2871. A GTX2867 with it's extra flow should do better. Nice build by the way and I believe I've seen your build on another forum (forget which). My biggest curiosity is that spool valve. Did you see any benefit from it? And why do you want to go to a larger turbo after you built your engine trying to keep as much power down low as possible? |
#224 |
This is my point exactly. If there are people making 630hp with the GT35 on an SR (2L?) then he should probably downsize the turbo if he's going for almost 100hp less on a 2.2L.
#225 |
my only thoughts were that i would rather have my setup tuned modestly to make 550 then have my setup maxed out to make it. and im talking RWHP if that makes a difference....
plus i would like to have some +/- play because im trying to match my cars handling with power, and how i like it. because yes there is such a thing as too much power.... |
#226 | |
Not the way I'd build my engine but I totally understand where you're coming from in terms of reliability. Personal preference really. |
#227 | |
![]() Join Date: Jan 2008
![]() i personalyl want a little more low end which is why im going 4.6 Gear ratio LOL. then soon ill be building another motor for whenever mine gives up but it will be a 11:1 motor ![]() sure the 30xx can do it but it will work harder, and put more wear on the turbo as well as the motor. plus depending on what you want too much low end will hurt you as your traction will be down to 3rd and up etc
MunkyW3rkz Racing |
#228 |
Oh, i know traction is indeed good for drifting and my car has good traction and stability in corners however it is easy to overcome the traction limits with the right foot.
As far as why i wish i would have went with a larger turbo, i hardly dout there would be much if any low end performance difference on my setup and i would have a higher top end potential. The turbine housing was 500 for me to put on my used 2871 too. Could have sold the 2871 and took that money and the housing money and got a new 3076. My new engine is not yet running still. |
#229 | |
#231 | |
My new engine is not going yet. The last one I deleted my file of the graph because shortly after tuning it we found that the new dyno needed some calabration and its readings were possibly wrong. The numbers were exaggerated by up to 10% and I made 437rwhp. It was a dyno dynamics. I had the oil pickup go bad and spun a bearing. I never redynoed. Im sure I have the graph somewhere still but I know I dont have the scan of it and I dont have it hosted anymore |
#232 | |
![]() if you buy the injector and rail kit u will get this ![]() |
#233 |
for those people wondering how much power u can make with a standard sr20 bottom end on E85
modifications Brain Crower 272 intake and exhaust cams Brain Crower valve spring and retainers Brain Crower Adjustable cam gear ( exhaust side only ) ARP head studs Tomei head gasket completely STANDARD BOTTOM END!!!!! POWERTUNE steam pipe manifold Precision 5557 ( .63 exhaust housing ) Tial MVS external gate fuel system consist of powertune twin pump kit powertune top feed rail ( standard inlet manifold ) head bolts starts stretching at 510hp at the rear wheels which is why we upgraded to the ARP items ![]() after upgrading the head bolts and head gasket The result was 525hp at the wheels with a 35psi spike which fell down to a stable 33psi. ![]() |
#235 |
![]() Join Date: Apr 2008
i have a 1991 sentra with a Avenir SR20DET current has 550CC injector and with a GT28RS did 311WHP at 15PSI. looking to hit the 360WHP mark what injectors would everyone reccommend, JWT said use factory R35 injector which i have seen to be flow tested at roughly 560cc not being much of an upgrade. i already have top feed fuel rail walbro 255 etc so only upgrade needed is injectors and a tune. im looking at 750cc low impedance top feed RC does that sound right?
NEGATIVE CAMBER SAN DIEGO CHAPTER |
#236 | |
i have some 850's for sell if interested only ran on C16.
MunkyW3rkz Racing |
#239 |
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
need opinion on re-doing my fuel setup,
motor built ka-t turbo gt3582r 1.06 divided t3 power goal : 600whp e85 plans for fuel setup: id1000cc ams top feed rail aeromotive fpr -8feed/-6 return 255 intank surge/swirl pot (2) 044 external (1) fuel filter external -6 to surge and external pumps -8 to fuel rail. think i can get away with only one 044 and id1000cc and make 600whp on that setup?
s14 kouki ka-t |
#240 | |
![]() Join Date: Aug 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
