Old 11-05-2020, 09:05 PM   #23521
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Unplugging coil pack 3 didnt affect the idle when it was running on 3 cylinders. The engine feels like it has more vibration and runs rich as hell
Sent from my SM-G950U using Tapatalk
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 11-05-2020, 09:16 PM   #23522
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
And is unplugging also how you verified spark? Or did you run the coilpack installed to an external plug or spark checker?
If you think it's a valvetrain component, do a running compression test (valve core removed from your gauge) on 2 and 3 and compare. I think it's a control issue with the coil.
mechanicalmoron is offline   Reply With Quote
Old 11-06-2020, 05:49 AM   #23523
DJTTon
DJTTon's Avatar
I simply swapped coilpack and spark plug from cylinder 2 to 3 and the issue stayed at cylinder 3 with cylinder 2 coilpack and spark plug; I swapped them back after I noticed the issue was the same, then recently took out original coilpack 3 and stuck the cylinder 3 spark plug into it and grounded the housing while a friend cranked and I saw spark while plugged into the cyl3 harness connector. Im still technically not ruling out spark either bc it could be the ignitor chip since swapping the coilpacks between cylinders didnt move the problem.
Skurr Skurr
Old 11-06-2020, 07:56 PM   #23524
mechanicalmoron
If you got a uniform white/blue spark, either try to get it to stop sparking while testing (wiggle test, etc), or jump sideways to a running compression test.
Old 11-07-2020, 01:07 PM   #23525
DJTTon
DJTTon's Avatar
Progress update, so it turned out to be a bad coil pack after all. I did inspect my valvetrain and all was good, I took the opportunity to clean up the valve cover a bit from oil stains.
When I bought the car the previous owner gave me 3 spare coil packs, it turns out 2/3 were bad. When I did my initial diagnosis I unknowingly swapped the broken coilpack with another broken one. It wasnt until the very end when everything was put back together after running the live compression test that I noticed the misfire moved to cylinder 4. I swapped coil packs 1 and 4, and problem moved to cylinder 1. I dug through my stash and kept swapping between the spares and cylinder 1 until the misfire went away. The car idled with 4 cylinders.
HOWEVER, and this is something new, when I went around the block for a spin, the car misfired really badly around 3k when I hit boost. At this point it could be a couple of things, so for my sake Ill be pursuing the Z33 coilpack upgrade as a safety precaution.
Thanks to you guys for helping me along!
Skurr Skurr
Old 11-08-2020, 11:41 AM   #23526
burnsauto
burnsauto's Avatar
How long did you drive it for? Did it backfire once or did the engine start breaking up when you hit boost? Did it do this every time the car saw boost or was it an isolated thing?
Old 11-08-2020, 02:42 PM   #23527
DJTTon
DJTTon's Avatar
After fixing the coil pack issue, I warmed it up and went for a spin around the block. It broke up every time I specifically hit boost
Skurr Skurr
Old 11-08-2020, 06:30 PM   #23528
burnsauto
burnsauto's Avatar
yeah your right, sounds like those 30 year old coils are starting to shit out on you...you know what to do at this point.
...sell the car.
Old 11-08-2020, 06:35 PM   #23529
DJTTon
DJTTon's Avatar
Yeah that's what I thought when I lost the cylinder. Oh the time has come
For the z33 coil packs can I just drop them in as is or will I need to swap the lower boot of the s14 coil pack with the z33 one? I know the harness needs to be modified and the igniter bypassed, I found a video on that. There aren't any write ups that I found with more details.
Skurr Skurr
Old 11-08-2020, 06:54 PM   #23530
S14rebuild
^theres a set of spitfire coilpacks up for sale in market place here...solid upgrade for sr20..plug and play. If u want simplicity
Old 11-08-2020, 07:33 PM   #23531
DJTTon
DJTTon's Avatar
Thanks for the thought, I ordered everything I'll need already knowing it's new. I learned my lesson when taking free stuff in faith
Skurr Skurr
Old 11-10-2020, 10:09 AM   #23532
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
The S13/S14 coil packs don't have a boot you can swap over. They're pretty old tech. The Z33 should fit anyway. May have to play with spacers or a bracket to get them to bolt in place.
Wiring is easy; bypass ignitor, flip 2 pins at the coil connectors, done. Wiring Specialties sells an ignitor bypass that's plug n play. If moving pins at a connector are above your comfort level, buy an S15 coilpack harness and you'll be good to go.
Old 11-10-2020, 11:58 AM   #23533
Club33Enthusiast
Club33Enthusiast's Avatar
Club33Enthusiast is an unknown quantity at this point
Where do the hc33 laurel builds go?
I tend to float around myself but if there is an hc33 Laurel guru anywhere hit me up please. I could use some info on my current build. Thanks!
Club33Enthusiast is offline   Reply With Quote
Old 11-10-2020, 12:05 PM   #23534
DJTTon
DJTTon's Avatar
Thanks for the boot clarification!
Im surprised how easy it is actually. I actually did opt for the WS Igniter Bypass harness so keen on using that along with modifying my WS Coilpack harness. I feel pretty comfortable with electrical so nothing scares me at this point. But you know, theres always an out...
... sell the car.
Thanks for all the tips gang!
Skurr Skurr
Old 11-11-2020, 03:47 PM   #23535
mechanicalmoron
Coils won't fix your drivibility problem. That's a sensor, or wrong tune, mismatched engine management bits, etc.
Old 11-13-2020, 06:29 AM   #23536
Thursday7
Thursday7's Avatar
Does anyone know if the shape of the spare tire well is different between hatch and coupe? I'm talking basically the well itself, maybe an inch outward of the depressed area, I'm sure they get different further out than that. Looking at pics of them together and they look to be the same. Asking because I need to weld new shit in
Old 11-15-2020, 05:48 PM   #23537
truckmtrS13
truckmtrS13's Avatar
truckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the rough
My trans is leaking from the speed sensor. Is the fix as easy as a new o-ring or should I replace the unit?
truckmtrS13 is offline   Reply With Quote
Old 11-15-2020, 05:54 PM   #23538
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Just need an o ring for that.
Old 11-15-2020, 06:25 PM   #23539
truckmtrS13
Thanks mate!
Old 11-15-2020, 07:12 PM   #23540
Yycschassis
Yycschassis is an unknown quantity at this point
Why is my sr20 misfiring?
i have a 180sx, with a blacktop sr20det in it, and a t28 turbo. It runs alright when cruising around, but it feels like i dont have much power. When i go full throttle, it misfires, over and over and it happens pretty much as soon as i put the pedal to the floor. Anyone know what this could be? I was thinking maybe injectors, or the FPR, but im honestly not sure about anything. Feel free to message me on instagram or reply here, my instagram is: that_180sx. Thank you!
Yycschassis is offline   Reply With Quote
Old 11-15-2020, 08:47 PM   #23541
imbored205
imbored205 is an unknown quantity at this point
Replaced the upper timing chain tensioner and now my 95 KA wont start.
Ran normal and no problems starting before. Now when I try to start it, it just cranks and never starts
Both distributor sensors and intake sensors are in. I don't think anything else was disconnected when taking off the valve cover/front cover. The chain wasn't moved.
Followed these two guides and cant get it to start.
https://www.nicoclub.com/archives/24...or-timing.html.
What do?
EDIT 11/16/2020
Nevermind I got it to work after trying 10 more times... I guess it has to be 100% precise and not a nanometer off.
imbored205 is offline   Reply With Quote
Old 11-16-2020, 09:19 AM   #23542
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
did it run good before, and you changed something, and NOW it misfires?
gotta start with the basics
F. A. S. T.
Fuel
Air
Spark
Timing
Old 11-16-2020, 01:57 PM   #23543
Yycschassis
F. A. S. T.
Fuel
Air
Spark
Timing
It was like this ever since I bought it. I didn?t notice until a couple days after I bought it, but it was definitely from the last owner. I changed the spark plugs already as well.
Old 11-16-2020, 05:38 PM   #23544
deolio
deolio's Avatar
Vacuum and/or boost leak would be my first guess.
Old 11-18-2020, 06:31 AM   #23545
DJTTon
DJTTon's Avatar
Hey all, wanted to follow-up on my ignition break-up issue. The Z33 coils with new NGK Iridiums (gapped to 0.3) cleared everything up. The idle is noticeably smoother, revs are smoother and acceleration response is much better overall. Reved the engine out during a wide open pull till redline, no breakups! Im a happy camper
Cheers fellas!
Skurr Skurr
Old 11-23-2020, 01:04 PM   #23546
Elroyson99
Elroyson99 is an unknown quantity at this point
Rps13 tailights
I have a set of rps 13 taillight for my s13 and I want to install them, but I don't know what kind of bulb housing these require. Does anyone know where can I find the bulb housing for on of these? Are there cars that have this type that I can take it off of?
Elroyson99 is offline   Reply With Quote
Old 11-28-2020, 09:46 PM   #23547
kevinyvng
kevinyvng is an unknown quantity at this point
Anyone by chance have done an universal condenser + custom AC lines? How much $$ does it cost.
Can't find a used WORKING condenser for my 92 240sx. None on ebay , offerup, nor facebook lol.
kevinyvng is offline   Reply With Quote
Old 11-29-2020, 05:23 PM   #23548
S14rebuild
https://www.ebay.com/itm/CNFP1225KT-...Cclp%3A2332490
This kit and have lines made at ur local hydraulic hose company set u back maybe another $100-200
Oh keep an eye on here for s13 part out
Oh n on ebay theres an used s13 condensor listed 89-90yr
Old 11-30-2020, 10:10 AM   #23549
kevinyvng
Thank you for the reply! I've noticed that the 89-90 condenser's fitting in the front is completely different. And was told to find a 91-94 only unless I want custom lines.
Currently I'm not able to find any proper custom AC line shop nearby, I live in SoCal. But I'll be looking around more and even calling the out of state shops.
Old 11-30-2020, 04:06 PM   #23550
S14rebuild
Any hydraulic hose supply company can make the lines for u..just bring them the correct ends and line lenght and diameter, they can make them
