02-25-2020, 02:09 PM | #23072 |
Kouki taillight center garnish
I have a brand new one center garnish from Nissan. (The metal piece that sits below the tail lights.) my question is, is this ready for paint or do I still need to primer it? It is a black color so I’m not sure if it already has primer on it..
02-25-2020, 02:53 PM | #23073 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
if youre doing this yourself, shoot it with etching primer. if youre taking it to a shop to have it professionally shot, dont touch it and let them do everything. using spray paint on anything with the plan of having it professionally painted later will only cost you more money in the long run. 2 part paint and primer that paint shops use do not mix with previously spray painted items due to the aerosol chemical mixed in with the paint. whatever part or piece you shoot with spray paint will have to be taken back to metal for the professional grade primer to stick properly to (otherwise it will most likely fail) |
02-27-2020, 12:35 PM | #23075 |
What have people used to rebuilt a Garrett 69f00 turbocharger? This is the single BB "S14 T28" found on S14 SR's as well as auto S15's. Correct me if I'm wrong, but after sifting through like 5 threads of confusing info, I believe that is the correct description.
I'd like to think twisted motion's rebuild kit would work with everything except for the journal bearings themselves. Is there a *semi-good-quality* rebuild kit available for the 69f00? |
03-04-2020, 02:23 AM | #23077 |
HSD coilover - damaged stud thread
The other week as I went to chuck my strut brace back on, one of the threads stuffed itself. Tried a few dies to try repair the thread but no luck. The only option i now have is to purchase a whole new top mount from HSD. Which is $170nzd. Which is annoying because other brands like BC sell the studs seperately. What should I do? I can't justify spending $170 on a new top mount for 6+ year old coilovers which will probably be removed in a years time for an upgrade anyway. Help would be appreciated haha |
03-04-2020, 02:25 AM | #23078 |
03-04-2020, 08:50 AM | #23080 |
03-04-2020, 11:23 AM | #23081 |
That's what a friend reccomended. I'm a bit skeptical about it as I would prefer a stud. As I'll probably sell the coilovers in a year or so.
I wonder if I could just buy a bc racing stud and hope it'll be the right size? |
03-04-2020, 12:16 PM | #23082 | |
Definitely don't guess on the stud, press it out, and measure it with a micrometer.(not sure if they're knurled) |
03-04-2020, 08:59 PM | #23084 | |
The right size stud, fucking obviously. Life gets a lot better when you learn about bolt gauges. |
03-09-2020, 10:31 PM | #23085 |
Trader Rating: (53)
Feedback Score: 53 reviews
I have wiring question for you guys. I just recently got the majority of the wiring in the car tamed and reinstalled the under dash components as well. Somehow I’ve lost the piece of paper that I was using to document all of this stuff and I don’t remember what these last two wires (Yellow/Blue and White/Red) are for...
From what I can tell from my research, the Yellow/Blue wire is in plug E201 and was used for the Oil Pressure Switch. The other end of this wire is in my junk wire box, so I know I trimmed it from something I felt that I didn’t need any longer. In this pinout I found online it says that the Y/BL wire on E201 is for the oil warning lamp on the cluster. If that’s the only function that it served, then I’ll just delete the pigtail that’s still attached to E201 and only have the big Black/Yellow wire for the starter on that plug. Can you guys confirm that this wire served no other purpose than the warning lamp? For the White/Red wire, I genuinely don’t know where to start. Just like the Y/BL wire I have the other end trimmed off and sitting in my junk box. Having nothing else to go off of, I tried to match it up to the pinout I found online and it looks to me like this W/R wire is part of plug E202. The wires that I haven’t trimmed off of that plug seems to match what’s listed in the pinout. With that said it looks like this wire was used for Alternator Signal. This wire also looks like it was used for a warning lamp in the cluster, but if I remember correctly, I believe that this wire actually broke out into multiple branches. I just happen to have a 7.5A fuse (on battery power) sitting in my fuse panel with no wire going to it...I THINK the fuse was labeled Alt-S, but I don’t remember. I may have gotten too aggressive during the wiring removals, trimmed this off, and forgot to hook it back up. Can I just terminate this W/R wire with a ring terminal and hook it to that 7.5A fuse? I believe it’s the wire that the alternator uses to sense battery voltage, but I’m not totally sure. For my last question, I just simply ask...what is this connector? It breaks out on the harness in the same section as the wiper motor and wiper amp. Sent from my iPhone using Tapatalk
: @e_lemonation |
03-11-2020, 12:19 PM | #23086 |
Can some one confirm the bulb type for the instrument cluster warning lights on a S14?(CEL/Battery/Cruise control/wiper fluid,etc.) I know the main bulbs are #194(x3).
03-11-2020, 12:25 PM | #23087 | |
First off, what chassis and what engine are you working with? Those look like the S14 connectors around the fuse box area, so I'll try to answer some of your questions based on that assumption. Just ignore me if you have an S13 or something.
At this point, I would highly recommend you grab a FSM for your chassis and following the wiring diagram accordingly. Deleting wires based off basic internet research alone is a recipe for a bad time. That said, it matches the pinout for the alternator signal. Again, I'm assuming this is the 8-pin S14 connector under the fuse box. If you have both wiper motor and amp plugged in, and that connector is roughly next to the amp, then it's the cruise control plug. |
03-11-2020, 12:26 PM | #23088 |
03-11-2020, 01:17 PM | #23089 |
03-11-2020, 10:17 PM | #23090 | |||
Trader Rating: (53)
And yes, you are correct, these are both old connectors from the fuse box area. Quote:
: @e_lemonation |
03-12-2020, 05:48 AM | #23091 | |
03-12-2020, 03:44 PM | #23092 |
In order to remove/replace the emissions lines and egr on the back of a Ka24e, is it required that you remove the engine or can it be done without pulling the motor out?
03-12-2020, 04:45 PM | #23093 | |
Trader Rating: (130)
Feedback Score: 130 reviews
just make sure to spray TONS of pb blaster or kroil on all the fasteners, and that stupid pipe that goes from the exhaust manifold over to the intake. |
03-12-2020, 07:01 PM | #23094 | |
Haven't had a motor in mine for years, but I don't recall the clearance to really do that without a miserable waste of time. EGR is probably the hardest part of pulling the motor, generally. The motor really needs to come out and have the PCV hose disaster under the intake replaced and refreshed and the separator cleaned, if it needs the stuff on the back done. You CAN do anything you want in the car, but it's a waste. The KA is very hard to work on in place, if it's got all the original brackets and braces, and especially if you plan to put them back properly. Just pull it, which is pretty easy, and which will expose things that need to be addressed anyway. |
03-17-2020, 09:38 AM | #23096 |
I can't seem to find it, can anyone point me to the guy who makes the gauge pods that fit into the rotating vents on the cluster surround? I can't seem to find them anywhere and they are not in the 3D printing thread from what I can see.
03-17-2020, 10:19 AM | #23097 | |
Trader Rating: (31)
Feedback Score: 31 reviews
Sent from my Galaxy Note 10+ using Tapatalk |
03-18-2020, 11:38 AM | #23099 | |
Trader Rating: (53)
Anyone?
: @e_lemonation |
