#2256 |
get that out of here no stretch!!hahaha for offset it depends do you want lip/concave or flatface honda wheel on there?
#2257 |
![]() Join Date: Apr 2007
Here's my 255/40/17 RT615K on a 9.5 +12 under stock metal. I posted it a few pages back and said it was ~-1* camber. Then I measured again. It's more like -0.5.
![]() ![]() I also run a 17x9 +32 and 0* camber on my other car with much less of a roll. If I had a 245/40, it would be 'flush'. I didn't take note of my inner clearance, but it sticks in my mind that I have another inch before the wheel would hit the coilover. Meaning a 17x10 +43 with a proper sized tire should fit inside and have about the same fitment on the fender side. But I've also never looked at control arm clearance. That could be a problem.
#2259 |
![]() Join Date: Mar 2003
i run an 18 x 10 +18 up front with a 265 and its pretty close to the coil over.
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com |
#2262 | |
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#2263 | |
My fingers are up to the second knuckle and have room to spare from the coilover, which seems to be about 3/8" closer to the wheel than the body at this point. ![]() Here's the clearance to the control arm. My fingers are up at the first knuckle and they are squished. I think 2 fingers at the second knuckle would be a more appropriate measurement. ![]() And, with a 17" wheel both of these measurements will be a bit different, as the coilover and control arm are sloped away from the center of the wheel. So maybe a 17x10 +43 wouldn't fit. ![]()
#2266 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
Note: the 265's I had ran kind of wide. So depending on the tires you choose you may be able to go a couple mm lower on the offset. But now we're really getting specific. ![]() ![]() ![]() ![]() |
#2268 | |
#2269 |
#2270 |
#2271 |
![]() Join Date: Aug 2008
XXR 526 18x9(+20)-f & 18x10.5(+25)-r
Michelin Pilot Sport 255/40-f & Yokohama AVS ES100 275/35-r PBM 10mm spacers-f & Ichiba 25mm spacers-r Origin 20mm front fenders & Origin Type1 50mm rear overs -2.0 front camber & -2.5 rear camber ![]() ![]() ![]() ![]() Last edited by Wreckless35; 02-20-2012 at 02:04 AM.. Reason: More specs |
#2273 | |
#2275 | ||
P.s. you're right, I could be running 3xx IF I wasn't running spacers, it's only round 1 of 1,000... Let it go! |
#2278 |
That first post was made in 2007! We've learned a lot about how much tire you can reall stuff under an s-chassis since then. People were questioning IF a 275 could fit in '07, now we're questioning how to get 315s without overfenders.
That being said, 275s are still manly tires, even if the most up-to-date MAX tires guys have moved on.
#2279 |
![]() Join Date: Aug 2006
Life begins at 335/35/17, this is the size I really want for my coupe! I think I could run them on a 12" wheel (?). But at a 12" width what offset is the highest I could run before hitting the coilover? That would help determine how much of a flare would be needed.
Silvia, built 5.3 turbo, 4l80e, 9.8@142 |
#2280 | |
i know right...... circa 08 295s 18 x11 +18 stock body, stiff suspension... ill have to look for it but i have a pic of 315s under stock sheet metal around that time ![]()
