11-05-2008, 10:50 PM | #2221 |
awesome 300zx
TRUE thing: True ////OFFSET\\\\ is acheived without spacers Running on E85 570whp Precision 5862....laggy as fuck. hate it |
11-06-2008, 12:35 PM | #2222 | |
Trader Rating: (22)
Feedback Score: 22 reviews
So do i need much more pull? |
11-06-2008, 12:56 PM | #2223 |
My old car needed 30mm over fenders with 12's and a 265 feddy BUT I had absolutely no negative camber in the back. If you keep the negative camber that you have now and stretch it a bit, you should be fine but with a 275 you will rub if you don't pull it a little bit more. Up to you, but either way can be done with the camber settings that you have. If you go up on the rear tires one notch for the 12's, you MIGHT be able to get away with it.
Battle Idol Works 2015 |
11-06-2008, 05:56 PM | #2225 |
Trader Rating: (22)
Yeah, i know i've been trying to get my jack back from Los but that SNIP is never around and im too lazy. I'm going to eventually drop it another inch and the front's i woudl like to drop a tad as well but even now it scrapes my baby drive way. I wonder if im going to need some 4x2's ?? The rear wing is egay and it's awesome for 40 dorraaa! Just ordered the GP sport style wing to see if it would flow well with the roof wing. Someone photchop me with those Andrew deep dish wheels please!
11-06-2008, 06:07 PM | #2226 | |
And how much of a pull would you say that is? I'm trying to put a 18x11 -16 S1 on my S13 with 245/40/18 and 30mm fenders. Trying to get and Idea of how much camber I need....
Blow me, bitches. Last edited by Slammed180; 11-06-2008 at 06:11 PM.. Reason: I felt like it, fuck off. |
11-06-2008, 07:25 PM | #2227 |
not sure exactly but its alot.i think my stock ruca's are maxed(like maybe 4or5 degrees).i can teel you this if your not wanting a shitload of camber i would say atleast 50 mil fenders.but i want the lip to almost touch the fender.oh yeah and wait until you go and try to stretch tires on these wheels it is a MEGA BITCH because they have drop centers on the barrels.get back to me and let me know how it goes cuz if you have trouble i can give you some pointers....ross
" NEO VVL BABY FTMFW!" Originally Posted by shagspeed Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines |
11-07-2008, 09:02 AM | #2229 |
Assuming this is for an s13, front fenders just need the lip flattened and the rears it depends what you want to do. I pulled mine a bit so i could run -1 camber, but if you can run -2.5 to 3* you'll be fine with just a roll.
613DriftWerks.ca |
11-07-2008, 10:20 AM | #2230 | ||
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
I scraped some of the paint off the lip of the wheel because it was rubbing. Keep in mind the brand of tire you run also determines the width. Consistently get the same brand of tire if you want to keep the same alignment specs and tire size. I'm running Falken Azenis ST115 on that wheel. O yeah and I peeped this on Hypebeast. Scion TC
11-07-2008, 10:56 AM | #2231 |
fronts 18*9 rear 18*10
offset f+28 r+29?? will they clear my current set up? 17*8 +35 with 10mm spacer 17*9 +47 with 1.5 bolt on (not MAD TITE FITMENT)
unionautoclub.com |
11-07-2008, 11:00 AM | #2232 |
They will fit. Just throw them on and if you need to, just stretch your tires more or run a little more negative camber. Fronts you might need to roll
11-07-2008, 11:18 AM | #2233 |
thanks man. fronts are roll already i have 225 all around the tire rubs fender.
also i think ill run into problems cuz im running the megan ext brackets
unionautoclub.com |
11-07-2008, 12:08 PM | #2234 |
You have PLENTY to go out in the rear, your fronts you may need to pull slightly. How much camber are you running on the fronts?
11-08-2008, 03:06 PM | #2236 |
Are these not them?
http://zilvia.net/f/wheels-tires/221...ata-green.html
Brandon Kelly 1990 Nissan Silvia |
11-08-2008, 11:57 PM | #2239 |
that car belongs to a member on this site
I believe he has some meisters now? not too sure but the wheels was up for sale before so look through the TEs in the wheels & tires section maybe try searching the keyword "takata green" with the quotation mark, since IIRC the wheels were not originally that color but powder coated hope this helps
91' 240sx Fastback LE |
11-09-2008, 12:39 AM | #2241 | |
awesome that does help, thanks mate
11-09-2008, 01:07 AM | #2242 | |
found it!
http://zilvia.net/f/wheels-tires/204...14-3-22-a.html Quote:
on a side note, i used to live in sydney...damn i miss that place....
11-09-2008, 08:47 PM | #2246 | |
11-10-2008, 02:55 PM | #2247 |
[quote=mclarenf1kid;2431982]^BTW, your S14 is sexy as hell. I've seen quite a few pics of it. Way to pull off Mustang wheels!
I don't have too many other pics of wheels on the car other than test fit stuff. [quote/] thanks, u make me wana sell my s14 and dump the money into my 93 2+2... even tho i hate 2+2's... not really sick fitment, but i think its cool to tuck 10.5's with 255's. |
11-10-2008, 04:14 PM | #2248 |
Still tweaking coilovers, fronts are maxed out no collars, gonna try to frankenstein some chit. 2009 "the year of the SnS" My boy Jorge is the first to take the plunge into debaucherytown.
18 by 11 -6 outback 17 by 10 +3 up front
