Old 11-13-2018, 11:52 PM   #22321
DailySX
DailySX is an unknown quantity at this point
How much ATF fluid will I need to flush/fill the power steering system? Also, is it ok to use DEX VI or should I stick with DEX III?
DailySX is offline   Reply With Quote
Old 11-14-2018, 10:20 AM   #22322
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
1 qt is usually plenty, stick with Dex III since that's what the FSM calls for.
Old 11-14-2018, 03:17 PM   #22323
Agamemnon
Agamemnon's Avatar
Is there any cheap alternatives for r32 GTR rotors out there? I would’ve hoped that with R32s being available for a few years that there would’ve been domestic company offering something far cheaper than OEM($300) or DBA($400+). It kinda sucks that Z32 rotors are less than $100 but R32s are more than double.
Old 11-14-2018, 06:15 PM   #22324
Jefro240
Jefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enough
Look into Mitsubishi 3000GT. 91-93 VR4 are 295x30mm.
89-93 R32 GTR are 296x32mm the 1mm x 2mm difference is fuck all. You'll get 1mm overhang on the pad since the rotor is a hair smaller. The 2mm width difference can be absorbed by the pads/pistons. But might be worth it price difference wise...
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 |
Jefro240 is offline   Reply With Quote
Old 11-15-2018, 11:51 PM   #22325
Agamemnon
Agamemnon's Avatar
Thanks for the heads up.
Are the rotor hats the same offset?
Old 11-16-2018, 05:40 AM   #22326
I'm Redline
I'm Redline's Avatar
Ill fitting parts is the dumbest shit I have ever seen posted here. That overhang will wear down to a point then waste the entire pad faster than normal...
Got use photos to prove this wrong, Jefro, I'll wait. Would you run a clutch on a flywheel with a fuck all bit of pad overhang?
My work in progress...
Old 11-16-2018, 05:41 AM   #22327
I'm Redline
Pay for the legit parts or sell the car. Or, maybe look into Z33 swapping parts or S13/S14 swapping parts which is a better idea than using ill fitting parts
Old 11-16-2018, 06:01 AM   #22328
Jefro240
It's funny how people choose to interpret the answer to a question as a recommendation... He simply asked if anyone found a cheaper alternative. I posted the only thing close to size I knew of. Clearly gave the info and said "it may be worth it depending on price". Which is a decision for him to make based on the rotor differences vs price.
And honestly. You've never seen a set of aftermarket pads slightly overhang on a set of rotors? It is quite common...
And it would be pretty hard to run a clutch with a bit of overhang on a flywheel considering the pressure plate wouldn't bolt up
Old 11-20-2018, 04:47 PM   #22329
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Are there any sites to watch for the turkey day specials?
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 11-20-2018, 04:53 PM   #22330
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
i havent seen any yet, but i believe this is the place to keep checking. i thought enjuku and TF did something last year and announced it here.
jumpman2334 is offline   Reply With Quote
Old 11-20-2018, 08:42 PM   #22331
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
ill be launching my black friday deals starting thursday night at 9pm (PT)
Old 11-21-2018, 06:16 AM   #22332
I'm Redline
Enjuku, Touge Factory(TF Works), Rays, Cosmis, Z1, Hoonigan, all are heavy promoting Black Friday on IG.
Old 11-21-2018, 08:42 AM   #22333
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
Enjuku's sale starts 11:59pm est November 22
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 11-21-2018, 09:16 AM   #22334
jumpman2334
for those of you who have heim/rod end suspension components, what are you using to keep them lubed? dry lube or graphite? how often are you spraying?
Old 11-22-2018, 06:39 AM   #22335
I'm Redline
All threads were heavy with anti seize. Fuck your spray. Anti Seize, that silver colored goopy stuff, man, it works great. If I spray anything, I grab the orange can of KROIL(ALL other suck, FTW!).
Old 11-25-2018, 09:02 AM   #22336
DJTTon
DJTTon's Avatar
Did Nissan make access holes in the trunk to the two differential bolts holding the face of the diff to the subframe? The space there is really tight.
Skurr Skurr
Old 11-25-2018, 11:31 AM   #22337
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
"Face" of the DIff?
[240sx] is offline   Reply With Quote
Old 11-25-2018, 11:42 AM   #22338
DJTTon
DJTTon's Avatar
Originally Posted by [240sx] View Post
"Face" of the DIff?
As in the cover
Sent from my SPH-L720T using Tapatalk
Skurr Skurr
Old 11-25-2018, 11:59 AM   #22339
[240sx]
^^ No holes that I know of, but you should be able to access them just fine. Unless you have subframe raisers, then maybe you'll need a swivel joint/socket.
Old 11-25-2018, 03:52 PM   #22340
Themenace1289
Themenace1289 is an unknown quantity at this point
s13 sr harness plugs
I'm trying to wire my s13 sr20det into my 91 240sx hatch enough to start, and don't wanna fry my ECU. The 02 wire plugs in, but doesn't match the https://frsport.com/SR20DET-Swap-Eng...SR20_t_26.html
this is a picture of my 02 sensor https://photos.app.goo.gl/NKQrX296rqSuerJY9
I know I don't need my water temp plugged in to start, but I'm not sure why the sub harness plug doesn't fit. I tried to include the wire colors in my picture https://photos.app.goo.gl/2j2ZNFsYESX48c9T8
Themenace1289 is offline   Reply With Quote
Old 11-25-2018, 07:02 PM   #22341
MisterDoodle
MisterDoodle is an unknown quantity at this point
Headers for KA24DE
Hello guys,
I'm a new member here and I was just wondering what brand of headers would you guys recommend that is California legal and will pass smog. I've been looking online and I can't seem to find any that is compliant with the rules. Do you guys know any of any places that have headers that have the EO# (sticker)? I have a 1993 S13 240sx if that helps, thanks!
MisterDoodle is offline   Reply With Quote
Old 11-25-2018, 08:41 PM   #22342
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
on an OBD1 car, a header shouldnt matter as long as you still have your EGR hooked up along with your primary catalytic converter and O2 sensor. basically OBD1 cars are require to pass visual inspection along with a sniffer test. if ALL emissions parts are in place and the car passes the sniffer test, then there should be no reason for it to fail... aftermarket header or not.
Old 11-25-2018, 08:52 PM   #22343
MisterDoodle
Thank you so much for taking the time to respond! Btw I love your work! Would it matter if I'm no longer using my stock catalytic converter anymore? I recently bought a ER Magnaflow Catalytic converter :O
Old 11-26-2018, 12:11 AM   #22344
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
did you buy the cat in state? catalytic converters are usually only 49 state legal... in the state of CA, you have to buy in in state for it to be legal for smogging.
Old 11-26-2018, 12:27 AM   #22345
MisterDoodle
Oh noooo... I bought a catalytic converter from enjukuracing for Black Friday and it looks like they’re stationed in Florida 😐
Old 11-26-2018, 05:54 AM   #22346
I'm Redline
As long as everything is present, cat cover, all the things like that, no one really gives more than a cursory look.
The OBX Racing header can be had for way cheap on Amazon direct from OBXR's page. Buy the header with prime, apply for the $50 gift card from Amazon Credit Card, apply the $50 to the header, in 30 days, cancel the card. If you run a 2.5" system, instead of the Enjuku 3", a Vibrant muffler sounds great with it(I have Megan 'Test' pipe though becuase Tennessee)
Old 11-26-2018, 10:36 AM   #22347
MisterDoodle
There’s a chance that the magnaflow catalytic converter I bought was okay because I just got the confirmation that enjukuracing just shipped out to me! If it were illegal wouldn’t they not ship out to me? Because I do see a law stating that it is illegal to sell non-califnornia legal products to anyone living in California.
I just checked on amazon and it looks like there is a possibility that the OBX headers are illegal down here because all the listings on the site say they cannot ship out to my location. So is that another way to check if a specific product is illegal in CA? If they aren’t willing to ship out to you?
Old 11-26-2018, 03:23 PM   #22348
LoSt180
LoSt180's Avatar
Trader Rating: (18)
If they're in Florida, then I doubt they know or care about CA laws. "But they shipped it to me" is probably the worst way to assume something is street legal.
It might pass a visual inspection though. As long as it bolts on, and has a heat shield, it probably looks close enough to stock. I know my catco one looks practically stock, just it's 3".
Old 11-26-2018, 03:56 PM   #22349
jumpman2334
apologies if this wasnt clear enough in my original post, but im asking what is everyone using to lube the actual heim/rod end. not the threaded portion of the rod/heim end.
Old 11-27-2018, 05:46 AM   #22350
I'm Redline
Same stuff, man. It's all lube.
The stuff from Magnaflow is 50 state legal. I just replaced a Y pipe w/cats on my Dodge Dak, and the tags were all 50 State legal. Magnaflow makes their stuff 50 State, not 49.
Header to ship to you?(If you use a mock up heat shield, no one sees 'header'
The ISR header at Enjuku is a direct copy of the old Hot Shot/OBXR version. It even has the EGR port. Who cares if it says off road only? They pass here in Nashville(Who has 49/50 state smog laws and testing).
|The trick is how you present it. It has to look and appear OE. OE uses SHIELDS, mod that heat shield to cover the header, make sure the magnaflow cat has the OE cover on it then go to a pep boys and look for the youngest kid there to run the test
