#22232 | |
![]() Join Date: Feb 2012
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
Sent from my SM-G955U using Tapatalk |
#22233 | |
#22234 |
![]() Join Date: Nov 2005
Material wise (not including compressor and gun)
how much would it cost to paint a car? I am just weighing out the possible experiment of doing it myself
http://www.nissanroadracing.com/ |
#22235 |
A few hundred for a good air dryer and oil separator, another hundred or so for a gun fine spray kit, and more than one paint bottle, about 2 or 3 hundred for the paint or more, then maybe a grand in different sand papers, primers and fillers and time to prep it right before painting, wet sand it after and coat again...really hours of time and sanding to make it look good and not like a golf ball was rolled over it
#22238 |
Need to know ASAP
This question might be stupid but does anyone know if the side markers for the kouki and zenki are the same, need new ones and trying to see if the zenkis would fit on my oem kouki bumper, oh and usdm by the way
Thanks! |
#22239 |
Can I remove the factory black stripe on my s13 with an eraser wheel?
#22240 |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
yes... but id recommend using a heat gun and some plastic razor blades as paint on these cars is shit. eraser wheel will probably take paint with it!
#22242 |
Do yourself a favor and take teh entire exterior, trunk, and door jambs down to primer. Then use flat black primer, and wet sand it smooth. Then start applying that semi translucent red, 8 layers nice and even. Now wet sand it smooth. Now here's where you go from wannabe to star...apply a coat of orange pearl mist, just one, or if you like the highlights to seriously pop, two. Now wet sand and clear 3 coats. light wet sand, and done. You will have a seriously beautiful red and in the sun, the highlights will look 🔥🔥🔥🔥
#22243 |
I tried searching, but couldn’t find anything useful. I’m wanting to import a s15. It will be used for show purposes with maybe a few road races a year. Now, is it worth my time or have a chance of it getting passed by the NHTSA since I won’t be trying to drive it in the streets or anything? I know there’s a few already here in the states, just trying to figure out what exactly I should do or need to do.
#22244 |
![]() Join Date: Nov 2015
![]() ![]() Feedback Score: 6 reviews
Does anyone know if BallerBolts is still in business? Their site is active, I placed an order a week back and I havent gotten any updates; even after following up.
Skurr ![]() |
#22246 | |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
http://zilvia.net/f/showthread.php?t=362128 |
#22247 | |
Sent from my Moto G (4) using Tapatalk |
#22248 | |
![]() Join Date: Jun 2010
You're gonna have to search a bit harder if you want to learn how to smuggle a prohibited item into the US. I would imagine that the people who've done it already weren't stupid enough to document how they did it on the internet. Last edited by derass; 10-08-2018 at 05:26 PM.. |
#22249 | |
Skurr ![]() |
#22250 | ||
BASF Onyx paint system, Nissan Red. That was my beautiful zenki before that bitch ran through a safety zone and hit me. Only option was to sand it down and go cheap with it's BMW Gunmetal Grey and black roof...which I like but really really loved that red. Next paint is going to be taken to metal, then same translucent gunmetal with candy blue pearl Quote:
You can get them in on a show car status 2500 miles or less. Check with the importers like RIVSU (who brought in Bear's coupe) Check Sickspeed on Amazon, and NR*G. Also, your local hardware fastener shop(NOT hardware STORE, but guy who sells fasteners only) will have stainless anodized bolts and stuff too
#22252 |
Original Nuttah's rare ride.
Leopard has high tech for it's year, VG30DETT. Nice rare ride! https://imgur.com/4jfExyF#
#22253 |
Are SA3R Version 1 center caps all the same size? Aka will center caps from 16" or 17" SA3Rs fit directly on 18" SA3Rs?
I'm looking for a set of them for the 18s I have... |
#22254 | |
![]() Join Date: Jan 2010
ive ordered from Toronto cycles before and haven't had an issue. their website looks like it was made/designed around the time the caveman discovered fire, but id still recommend buying from them. I haven't ordered from pro bolt, but my dad does fairly frequently for the sprint car he works on. pro bolt is sorta pricey, but ti isn't cheap to begin with. their black Ti is also DLC. |
#22255 | |
#22256 |
Whats the part number of the oem gasket for the ka24e upper downpipe, where the 4 runners go to 2. If there isn't an oem gasket what gasket could I use.. maybe from another car
#22257 |
Is there such a thing as a Wideband that does NOT come with a gauge pod? I basically want to replace the stock O2 sensor, have the output available for logging, a narrowband output fed to the ECU, but be able to hide the box somewhere.
#22260 |
so, when the photobucket-gate thing hit, there was a link that was going around that would pull up a previous version of the site, prior to pb screwing us. does anyone have that link?
its getting tiring finding old lexus threads with a lot of good info, and the pictures don't work. |
