#2192 |
At least some people are willing to give things a shot themselves.
The whole entire S-chassis suspension tuning pretty much halted since like the mid nineties and not a whole lot of development has come out for the whole scene until recently, when the close minded drift kids actually opened up their minds about roll centers and how to make their cars handle better, then the flood gates opened. So yeah, if things don't work, fine, at least you gave it your all, and I bet you you would have learned a shit ton by going hands on about all the details of something, whether it works out or not. |
#2193 |
![]() Join Date: Jul 2005
I was thinking of caster as the wheels position in the wheel well, not the angle of the shock.
Anyway, my stage 2 roll center modifications up front will involve a tubular LCA with 1" spherical bearing and 3/4" straight bolt so I don't have to worry about binding on the bearing. By then I'll have made some caster plates as well. I had not seen those GC caster plates, that is a much simpler design but would also effectively raise the car up higher then a double plate method, not much, but still.
![]() Instagram - SJKnoop |
#2194 | ||
![]() Join Date: Nov 2005
![]() Quote:
I think it's funny how we always misread each other, and usually have the same idea in actuality. ![]()
#2195 | |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
I'm running a 225/40/18 in the front with a 18x9 +3. I've already hammers the crap out of the firewall, but its still pretty close. I'm going to go take some pics later today.
![]() ![]() Friends help you move. Real friends help you move bodies. |
#2196 |
You probably installed the tension rods incorrectly then.
Or the shop adjusted them incorrectly. This is the proper way to do it. http://splparts.com/instructions/SPL_TR_S13.pdf Basically you screw the rod into the adjuster, and the rod end into the adjuster until neither can go in any more, then you extend the rod by only turning the adjuster piece, which should thread the rod and rod end out at the same rate, so you don't have one side longer than the other. |
#2197 |
I had 7.5* castor on my S14 using SPL ver. 2 tension rods. Had plenty or room to go further if I needed.
#2198 |
![]() Join Date: Apr 2007
I disconnected my front sway bar today just for fun. I didn't like it at all. It made the steering feel mushy until the car rolled over a bit, then it gripped pretty well. It seemed like it pushed a lot more through the turns, unless I was really close to the 'limit'. And then it just felt like it was going to lose rear traction. DID NOT LIKE.
I went to a local drift spot (race track, all legal ![]()
#2199 |
![]() Join Date: Jan 2005
its all on the your cars full set up. We ran no front swaybar with ISIS coilover set on 10 front stiffness and the rear full soft. It made the car very predicable with lots of grip up front and out back. Its all on your style and how you drive the car. My setup may not be the same as yours. I set my car up for aggressive driving and making the car handle while in drift. I like to initiate fast and early, thus needing a lot of front bite.
Depending on the track our tire pressure up front will range from 28psi to 42. on the rear we usually start around 65psi depending on tire wear and grip. Also remember that this is a KA24de car and your setup might be different.
1994 FD3S Drift // 945garage // |
#2200 |
Yeah, I definitely like running a front sway bar. The car felt like a bag of dicks without one. I was pushing because the rear had more grip then then front (at least thats what it felt like), as soon as I put the sway bar on the car suddenly became more predictable and I had way more steering feel and grip. Still not as much front grip I was wanted, but a stickier tire should fix that (I hope). I know not drifting in freezing temperatures will help that a whole lot!
#2201 |
I personally cant stand driving with out sway bars. On the S14 had 6k/4k springs on KTS coilovers and a progress front sway bar and it was the best handling DD set up ever. I also had way more confidence on the back country roads with it on the soft springs/big bar set up because it wouldnt bounce and hop over every little bump. It was insanely easy to drive fast. Lots of front end bite and a slightly loose back side yet still had insane traction. It was perfectly balanced for my driving style.
I out ran a C6 Z06 and a few Exige S Lotus's at an auto-x back in june with only about 275hp. (only my second DE) |
#2202 |
![]() Join Date: Apr 2004
No sway bars is horrible for our cars. They need more roll stiffness, not less.
I can only think the people that like no bars only pull like .5 Lateral Gs or something so it "feels good." most drift cars rarely pull many lateral Gs so maybe that's why drifters like it sometimes.
#2203 |
No sway bars with coilovers feels like stock suspension with blown shocks in the corners, SO much roll.
Nothing says racecar like a stock car with no interior. |
#2204 | ||
#2205 |
![]() Join Date: Nov 2009
i second the no swaybar thing.. i ran without one in the rear and thought the car was utter crap and all over the place not to mention understeer city.
Went to a hicas swaybar in the rear.. and boy oh boy the car felt more stable and just better. Internetz advice = fail. |
#2207 | |
Thats like me saying my old S14 is comparable to the Exceed Moat S14's. |
#2208 | |
Fact - tires generate less lateral traction when they're sliding than when they're not. Same tire, all things equal, you will pull less lateral G's in a drift than not - this has been proven time and time again. My statement wasn't knocking drift cars, but most use pretty cheap/hard tires just because they're burning through them quickly (I would too). So that gets back to my statement that most drift cars pull low lateral G's - somewhere around 0.5 in a drift. So it wasn't a knock, just simple physics. I know I know, your scraping low mad tite S chassis looks so cool drifting and all the local hard parkers say you're super fast as you initiate at 27 mph into your "street drift" - that still doesn't mean you're pulling many lateral G's, even though you might pop on over to MotoIQ once in a while and read about your drift heros. BTW - transient G readings are stupidly meaningless when you're throwing the car around, of course they can peak much higher than your steady state. Note they didn't mention much about steady state lateral G's in a drift...
#2212 | |
Loosen the endlinks up, put the sway bar back on, and tighten them up, it's okay if they are pushed out a little.
#2213 |
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
gripterror and singlecamslam = Def fanbois.
chumps. Edgar(arcticdragon) isn't a fanboy at all... He was just posting info that he saw. At first i was like wo thats a lot of gs while drifitng. but then as Def stated, those arent steady state gs, thats probably while hes throwing the car, transitioning, etc... |
#2214 | |
and please don't resort to calling me a drift fan boy. That's uncalled for. I do actively road race my car. And I don't drive an S chassis. My super lowness doesn't affect my suspension as much as it does an S chassis, so my scraping low mad tite Z32 chassis looks so cool drifting as it does road racing ![]() all poking fun aside, please don't be little me just because I enjoy drifting and posted one link from MotoIQ that had drifting in it. I have been following this thread since day 1 looking at way several of the things you guys are doing to the S chassis can be transferred over to my Z to improve its performance while still being chassis scraping low. EDIT: btw, if you look at the chart of Gs vs. Ti,e on the second page, you'll see dips from initioation, but you'll also see the car sitting at around 1G sideway for a decent amount of time. That would be considered transient wouldn't it? Not to mention its still on street tires. |
#2215 | |
The link he posted up and the stupid quote had nothing to do with my post. He might not be a fanboy in your eyes, but anybody who tries to talk about how super fast drifting is or how many lateral Gs they're pulling are just missing th point IMO. The whole point of drifting is to slide the car, tar laws of physics state that if you didn't slide the car it'd have more grip to go around a corner faster or pull more Gs. That's cool if you like it, but as far as speed/Gs go, you'd be faster if you didn't drift that same section of road. So that brings me back to my original statement, which holds true for 99.9999% of the cars on this forum, no matter how butt hurt it makes the fanboys.
#2216 | |
I could probably hit 1.3 G peak lateral if I threw a Geo Metro into a cambered corner, it doesn't really mean much other than it just hit it for a few microseconds. Like I said, my original statement still stands about why drift guys seem to sometimes like no sway bars.
#2218 |
![]() Join Date: Dec 2006
ya thats the only thing i could think, i just couldn't remember them pushing out that much before. But maybe b/c i never took it off. idk. i'll prolly try and handle it tomorrow
#2219 | |
I have a ~12% stiffer S13 25mm solid front sway and a ~15% stiffer hollow 19mm J30 rear sway right now. These cars *NEED* sway bars front and rear to actually corner well. There's nothing you can do to the car to get enough roll stiffness without having a comical amount of spring which will have the car skittering over any bumps (I'm talking 750+ lb/in).
#2220 |
![]() Join Date: Aug 2006
Thanks Def!
It was something that was on my mind. I am still running both bars, I didnt remember where I read or who said that they ran no rear bar for their grip car (s13), so i thought id ask and see if could get someone to elaborate a tad more. |
