Old 06-14-2018, 08:31 PM   #21901
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
^^ moderately lowered, and wired tucked...even still, I checked & nothing's harmed. ¯\_(ツ)_/¯
Sent from my SM-G930P using Tapatalk
[240sx] is offline   Reply With Quote
Old 06-15-2018, 11:02 AM   #21902
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
This is a relay setup question,
would it be better to run one relay to turn on two fans simultaneously
or two relays, each getting the same inputs, to run one fan each?
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 06-15-2018, 12:59 PM   #21903
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
I would say go with 2 relays so you can control the second fan when you need it (hot days, track, etc...).
instagram
1on1 is offline   Reply With Quote
Old 06-15-2018, 01:02 PM   #21904
DJTTon
DJTTon's Avatar
I was thinking of running both on a thermostatic switch, if not that then off the of ECU fan control pin. Let me know if anyone can see any foreseeable issues with that.
Skurr Skurr
Old 06-16-2018, 07:32 AM   #21905
I'm Redline
I'm Redline's Avatar
Stand alone fan controller, one relay, both fans all the time, fat ass radiator and shroud, based on temperature. FAIL PROOF. FTW
My temp runs exactly lower center, idle, traffic, back roads, freeway. no problems.
My work in progress...
Old 06-18-2018, 07:33 AM   #21906
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
Quick question guys, I removed the bumper and bumper support on my silvia and I am currently installing the fmic. I plan to run an aftermarket vertex front bumper and I was just curious if anyone has been able to maintain the stock jdm bumper support? Specifically if it clears the ic, and can be used with the aftermarket aero. thanks.
e30gangsta is offline   Reply With Quote
Old 06-18-2018, 07:39 AM   #21907
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
You can fit the big fmic with the support if you clearance the support (depends on the fmic but I've always had to cut them). This goes for JDM or USDM bumper supports.
Old 06-18-2018, 10:01 AM   #21908
derass
Just make sure amperage rating for the relay meets that of the fans.
For example:
Two fans wired to one relay:
2 15A fans = 1 30A relay
One relay for each for:
2 15A fans = 2 15A relays
Old 06-18-2018, 10:13 AM   #21909
TheRealSy90
TheRealSy90's Avatar
IMO no reason to not run one relay for each fan. Worst case scenario you have a relay go bad one day you aren't dead in the water with no cooling and could wire the fan to the other relay to get home or run home with the one remaining fan etc.
Such a good signature.
Old 06-18-2018, 07:39 PM   #21910
oLemurs
oLemurs's Avatar
oLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura about
does anyone know if you can just plug the coolant lines that go into the heater core on the sr20det?
oLemurs is offline   Reply With Quote
Old 06-19-2018, 01:40 AM   #21911
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
I believe you should loop them back to each other, then cap off the heater core side to keep stuff from getting inside in case you want to hook it up later.
Old 06-19-2018, 08:51 AM   #21912
SRswappedSE
SRswappedSE is an unknown quantity at this point
Anyone have any S14 driveshaft bolts in good shape they don’t need?
SRswappedSE is offline   Reply With Quote
Old 06-19-2018, 03:40 PM   #21913
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Garrett T3 5 Bolt exhaust discharge flanges the same as T25/28 ones? I know the 4 bolt is larger...
Will this bolt up to the T28 exhaust housing? (I am external, so I don't care about the flapper).
https://www.atpturbo.com/mm5/merchan...egory_Code=FLS
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 06-19-2018, 09:10 PM   #21914
MAHALOHAWAII
MAHALOHAWAII is an unknown quantity at this point
anyone selling some PS13 Silvia Bumper turn signals? (amber/clear) left and right? also willing to ship to FPO AP 96351?
B6125-44F00 (LEFT)
B6120-44F00 (RIGHT)
MAHALOHAWAII is offline   Reply With Quote
Old 06-20-2018, 10:05 AM   #21915
oLemurs
oLemurs's Avatar
would the car overheat if you blocked them? im just asking because one of my lines has a kink in it and i have the hose at my grandmas house but was wondering if that was the cause of overheating on the highway
Old 06-20-2018, 10:15 AM   #21916
TheRealSy90
It's possible, those hoses are designed to flow from the water inlet behind the thermostat, through the core, and to the head coolant passage. I would not block them.
Old 06-21-2018, 08:46 AM   #21917
oLemurs
oLemurs's Avatar
what would cause there to be no throttle response after a hard 1-3 pull (sr20) btw after coasting with WOT (no power) the power just slowly came back
Old 06-21-2018, 01:32 PM   #21918
TheRealSy90
Your car has some serious issues. Maybe stop flooring it 1-3 while it's overheating.
Old 06-21-2018, 01:36 PM   #21919
oLemurs
oLemurs's Avatar
not serious issues, it only overheats on the highways and i changed the thermostat and wanted to really put some heat into it to see if it would over heat
Old 06-23-2018, 08:46 PM   #21920
DJTTon
DJTTon's Avatar
Does anyone know if the Greddy oil relocation kits are interchangeable between S14 and S13 SR20 engines? I see FRSport list two types, what are the differences?
Skurr Skurr
Old 06-24-2018, 06:56 AM   #21921
I'm Redline
Summit Racing for longer hoses, adapters, connectors, and DIY the stuff that does not fit to make it work correctly.
Old 06-25-2018, 09:19 PM   #21922
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Hoping someone has an Apexi noir or a hks hi power laying around...
What's the length of the typical resonator box on the aftermarket s14 exhausts? Gonna add something similar to my resonator-less HKS sport. Here's an s14 apexi noir midpipe as an example:
Thx!
spooled240 is offline   Reply With Quote
Old 06-25-2018, 11:23 PM   #21923
GeneStarWindGSW
GeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant future
answered my own question
GeneStarWindGSW is offline   Reply With Quote
Old 06-26-2018, 05:25 AM   #21924
I'm Redline
Thx!
Just hit up Summit for a black Moroso Spiro Flow muffler. You'll like the way your car sounds after using it for a resonator, and it's only some 4" in diameter
Old 06-26-2018, 08:58 AM   #21925
DJTTon
DJTTon's Avatar
Can someone please clarify if only the sunroof equipped cars have the drain tubes going down the sides of the interior? And how many drain tubes are there for sunroof equipped S14s?
Skurr Skurr
Old 06-26-2018, 10:33 AM   #21926
derass
Biggest difference is the thread of the sandwich plate nut. S13 and S14 SR use different threads on the oil filter stud, so the oil cooler kits use different nuts. 3/4" vs M20 thread, IIRC.
Good idea. Never understood why the Hi-Power has a mid-muffler, but the Sport doesn't. Should make for the ultimate, quiet street exhaust.
Old 06-26-2018, 11:31 AM   #21927
DJTTon
DJTTon's Avatar
Okay that makes sense.
Sent from my SPH-L720T using Tapatalk
Skurr Skurr
Old 06-26-2018, 02:47 PM   #21928
spooled240
spooled240's Avatar
I've never seen those types of mufflers before. Seems like a good way to quiet things down without sacrificing too much flow. Thanks for this, I may just give it a try.
Yeah it's weird. HKS probably didn't think a resonator was necessary. It is pretty quiet for what it is..ONE muffler, but it's still a little too loud for me and there's is a bit of drone on the highway.
Old 06-26-2018, 11:01 PM   #21929
brokeboi01
brokeboi01's Avatar
brokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enough
This place is a safe haven for my stupid questions and I’m thankful for that. Anyway I recently picked up a set of G7s with federals for what I assume is dumb cheap. I’m just wondering what these usually go for on the market? Not planning to resell, just curious. Haven’t seen many of these up for sale.
brokeboi01 is offline   Reply With Quote
Old 06-26-2018, 11:27 PM   #21930
Almighty So
Almighty So's Avatar
Almighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond reputeAlmighty So has a reputation beyond repute
$1000-$1400.
Google “panasport c5c zilvia” and you can see all the sets that have sold here recently
Originally Posted by Phlip View Post
This pissing match is getting old
Almighty So is offline   Reply With Quote
