09-20-2010, 04:09 PM | #2132 | |
I'm on Powered By Max's.
SPLparts.com * PoweredByMax.net Quote:
09-20-2010, 08:05 PM | #2134 |
ugh, i absolutely hate the look of over-photoshopped or poorly photoshopped or hazy pictures. It makes me rage
other than that, fucking nice
street dancer. GLEAM |
09-20-2010, 08:08 PM | #2135 | |
can't tighten spring perch either unless i want preload i think its tiem to flip the bracket and pull another collar
09-20-2010, 08:39 PM | #2137 |
u must be doing something wrong.... i have 17s up front with max camber like -4 or something and if i put one collar underneath of the bracket (not flipped) i can get within like half an inch from the rim. and maintaining a slight preload (no droop)
09-20-2010, 09:02 PM | #2138 | |
also, wheel's aren't flush. Theyre like 1.5 inches sunk cause my works havent come back from getting fixed (never had a chance to put em on) also, preload - i called stance and asked them what to set it as and they said nothing, just tighten by hand and then 1/4 turn. What does preload affect since i hear ppl adding it and shit
09-20-2010, 09:39 PM | #2139 | |
You spin the top collar (spring perch) and spin it tighter and tighter therefore giving you more height adjustment for your bottom bracket to go higher.
Pros: Makes your car look sick Cons: Makes your car ride like a go-kart
09-21-2010, 03:14 AM | #2141 | |
They can't go as low as the others, but can definitely go low. 18's in the front. Edit: I'm talking about the front, rear can drop forever.
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
09-21-2010, 04:26 PM | #2142 |
in my sig is as low as my stance's will go in the rear...it's literally perfect for a s14. I just hope you don't have an exhaust....cause I had to take mine off just to drive the car.
no removing collars/ pre-load blah blah blah...just lowered the heigth...everything else is still set up for drift. and just lowered the front last week....still have about half an inch before having to remove anything else....i'll take pictures and post them up later. |
09-21-2010, 04:49 PM | #2144 | ||
i know how to adjust pre-load, i just wanted to know the effects it had other than go-kart ride quality (full dampening to stiffest)
09-23-2010, 08:18 PM | #2148 |
front lip was knocked off at a local drift event on sat and took the bumper extensions with it.
then today with the rain in my friends slippery neighborhood. the speedbumps were put in last week. |
09-23-2010, 10:10 PM | #2152 |
low. road dots murder my shit and i scrape frame. I can't wait to have 18s so I can tuck some more tire and not have to worry about running my bumper over when it falls off due to roaddot carnage. The roads are so different here compared to ohio, everything is flat and fairly smooth but theres drainage lines for flooding on some streets so I have to plan my routes to avoid that nonsense. ohio = pothole central.
get chill. |
09-23-2010, 10:22 PM | #2153 |
Lol they're XXR 002's. if you must get them, BUY MINE duh. But seriously if you must get them, get the 16x8 +0 please. They used to be called sportmax, not xxr, therefore the name gaymax was given.
09-24-2010, 03:03 PM | #2155 |
sway bar is an inch off the ground......but I can still make it up driveways! also on the daily... and i'm in LA. Last edited by fckillerbee; 09-25-2010 at 11:48 AM.. |
09-24-2010, 05:56 PM | #2158 |
Indeed, I lost my bumper and destroyed a sideskirt. brb HUGE unmarked speed humps in the middle of the streets.
and damn you always droppin by threads and makin us all look inferior :P
get chill. |
09-24-2010, 06:12 PM | #2159 |
yeah, you kinda have to have a planned route for work, food, and gas....any unknown road is forbidden until i drive it in the dodge. lol
ayu....curious...how DID you get your car that low? custom suspension? |
