Old 12-02-2010, 10:21 AM   #2101
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Originally Posted by PoorMans180SX View Post
As far as I know, no one has actually taken measurements of the Driftworks knuckle, compared to stock, and made them public knowledge.
When my friend modified mmdb's set for sphericals
they just looked like a drop knuckle to us, no special geometry corrections
granted we didn't take measurements
cheap crappy split poly bushings since they don't hold the bushings bores to a precise ID
everything shalacked with nasty thick orange paint
and as I mentioned z32 e-brake wouldn't work as advertised
they claim their new version takes care of this but I can't find nor get an answer of evidence
but for the money they're pretty good value imo
I've even considered getting a set
mmdb loves his set
Old 12-02-2010, 10:30 AM   #2102
PoorMans180SX
PoorMans180SX's Avatar
mmdb loves his set
There is a picture a page back. az_240 just bought them and his Z32 e-brakes fit, and he says the urethane bushings are nice now.
Originally Posted by SoSideways View Post
I was just thinking...
Take a look at the area I circled.
If you make this brace, do you think you can make it with a longer bracket and provide enough room on the bracket to drop the front RLCA pick up point by I dunno... an inch?
Can do the same with the rear bracket I suppose.
What do you guys think? Not gonna be strong enough?
The only thing I see is that there is that "lip" around the LCA mounting points. You'd have to grind that off or make the bracket a little wider to get around them. Kind of a pain the butt. It would be pretty simple to make the bracket longer when you drop the front.
Originally Posted by articdragon192 View Post
Wouldn't it bet better to raise the rear pick up point, instead of lowering the front pick up point of the LCA?
Depends. Changing the rear changes the relationship with the toe arm more, which should affect bumpsteer more? So modifying the toe arm mount might be necessary. But, it does move the roll center up a bit.
Old 12-02-2010, 10:31 AM   #2103
SoSideways
SoSideways's Avatar
Yeah, that can be done too.
But if the brace has to sit on top of the RLCA pick up point mounting bracket, then there might be a packaging issue of running out of room there.
You can keep going down with the front RLCA pick up point bracket and not really run into any issues, but above the rear pick up point bracket? Eh...
Old 12-02-2010, 11:02 AM   #2104
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
interesting, because the ebrake stuff would bolt
(even though it wasn't a great fit)
but there wasn't any place for the ebrake line to come out
also you need to switch the assembly sides putting the line at a local
that would require a different length
very interested to see the new set up all bolted up
Old 12-02-2010, 11:13 AM   #2105
PoorMans180SX
From az_240's post.
Old 12-02-2010, 11:54 AM   #2106
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
Did a little bit of searching and saw those arm braces are for the skyline gt-r's.
NISMO Rear Member Brace Set BCNR33 BNR34
NiSilS14 is offline   Reply With Quote
Old 12-02-2010, 12:46 PM   #2107
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Originally Posted by az_240 View Post
Some observations or 'hating' as some of you may have:
we found the fit for the bolt that holds that ebrake assembly sloppy
looks like they haven't done anything to fix that
the oem is a nice snug slip fit for a reason
if you look on the back of the oem upright
you'll notice the recess areas for the axle dust collar to fit nicely
not such provision on the DF knuckles
nor the counterbores for the bolts holding the hub to the upright
that's the reason why the aforementioned IDs are machined on the oem piece
the ebrake cable now comes out the top of the upright
mmdb found the cable length to be off after that
DF doesn't mention this nor (as far as I could search) show pictures of an installed working assembly
I'm sorry but those bushing are crap
they take two halves of a bushing and press them into their bores
not with performance in mind
but because the bores for the bushings are too inconsistent to press in OEM replacements, ES, Whiteline, etc ones.
and having said all that I still believe they're a decent value
Old 12-02-2010, 07:05 PM   #2108
VIPDRFT
VIPDRFT's Avatar
VIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura about
Would knuckles be detrimental on an underpowered car such as a stock 240? As in not having enough power to hold the angle?
Holding it and...WHEEL POPS OFF! O^O^O
VIPDRFT is offline   Reply With Quote
Old 12-02-2010, 07:10 PM   #2109
Tampa Drift
Tampa Drift is an unknown quantity at this point
Yes it will be a lot harder with the increased steering angle. Not saying you cant do it. Theres a few drivers locally with tie rod spacers running KA's, not full blown modified knuckles, and they do fine.
Tampa Drift is offline   Reply With Quote
Old 12-02-2010, 07:16 PM   #2110
VIPDRFT
VIPDRFT's Avatar
Okay, thanks! I was just curio. My "real" drift car has power and knuckles but I'm building an underpowered "missile" to practice with and wanted to verify.
Old 12-02-2010, 10:51 PM   #2111
mikerbike
mikerbike is an unknown quantity at this point
I use Modded knuckles on my KA drift car. Increase rear grip and you can use the extra angle. I found that with the slicker rear tires I used to use (and occasionally still use) I can't make full use of the extra angle, i just spin out when I get close.
mikerbike is offline   Reply With Quote
Old 12-02-2010, 10:56 PM   #2112
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I guess the fat strippers are cheaper too right?
Sorry, but I don't really buy into the orange paint hype. Awesome that they are doing their own thing, but if I made my own junk, painted it Red and called it Jap Spec 3, it would sell regardless.
Shiney paint goes a along way -- I'm glad you guys provide real world feedback.
Old 12-03-2010, 03:14 AM   #2113
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Yes the ebrake king pin hole does have 1-2mm of play. Not too worried about it... I could make a little spacer if I have to.
I was worried about the length of the ebrake cables. I have R33 cables at the moment. I'll have to pm mmdb to see what he went with.
I believe I can get the dust boots to work.
As far as the bushings go I think you are a bit biased since you help make spherical housings. While sphericals are no doubt better these are still a good solution.
Once the arm is bolted on they are nice and tight... no play from side to side or front to back. I'm not sure if these ones were split down the middle or not but with the arm attached it really shouldnt matter. Others have split their ES bushings without any issues.
What suprised me is the stiction is very little compared to the ES bushings. Also they give full range of motion unlike the stock/nismo bushings.
So how are they crap again? Just because they are split poly?
Also how can anyone hate on the color they were powdercoated? Don't like it paint it another color haha
Old 12-03-2010, 08:49 AM   #2114
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
lol... never turn down a fatty
I don't really buy the hype either
and feel that these knuckles were thrown together without out much real
research behind them.
they're put together well enough that they work though
and four corners for ~$1100 IS a pretty good deal
(remember how much the GP Sports wanted for the fronts alone)
If you can provide something similar for or under that price
then my hat's off to you
I don't think he's done anything about it yet.
Just riding without ebrake for now
Was talking to a shop about making custom length cables iirc
Cool, in for pics when you do.
perhaps, but that's not what I was getting at
The bushing we took apart had inconsistent wall thickness
and were chewed up where they were split
air bubbles here and there
in other words: crap
I'm not saying you need sphericals or you suck
(actually think that they're too much on a daily)
Nismo, oem or ES ones are better quality
but good luck getting a consistent fit on those arms
I don't hate the color per say
is not to my taste but that's inconsequential
What we didn't like is that it was sloppy applied
varying thickness throughout the part
this even in the places where the oem knuckle has been machined for precise slip fit with the hub
this tells me DF didn't put a lot of thought into this, or didn't care enough to
Old 12-03-2010, 03:37 PM   #2115
GripTerror
GripTerror is an unknown quantity at this point
aah you guys got to it
Yeah those braces are neat and super simple they are nismo gtr ones... someone already posted it.
Keep in mind s13 and s14 subframes are different mounting points.
Somone SHOULD make that and the axle spacers.... to widen track without wheel spacers... these are so cool simple and someone should make them...
GripTerror is offline   Reply With Quote
Old 12-04-2010, 03:47 AM   #2116
az_240
az_240's Avatar
Trader Rating: (41)
Mine do not have any visible air bubbles or noticeable variations in wall thickness. The bushings do look a little sloppy like they were cut with a dull blade or something where as the nismo/oem/es are cleaner looking.
Despite how they look I do not believe those bushings would be any better than what is already in the DW hubs. My main concern was stiction and these don't have much issue with that where as in my experience the ES and Nismo bushings do. OEM has more range of motion and less stiction than Nismo but they are quite a bit sloppier.
Old 12-04-2010, 03:59 AM   #2117
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
KTS makes these...just saw it in the newest DoriTen while I was taking a sh!t! lol Best reading material ever! haha! Oh, and they are surprisingly cheap!
Slidin' Sam is offline   Reply With Quote
Old 12-04-2010, 07:15 AM   #2118
GripTerror
link to kts product
Old 12-04-2010, 09:31 AM   #2119
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Very good idea, but this would only work if you had rod ends on your lower control arms, otherwise you would put way too much bind on the lower control arm with stock bushings.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 12-04-2010, 10:35 AM   #2120
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Agree, plus they look like a pain in the ass to install
Personally, I think boxing the pick up points and welding reinforcements on the sides is a more practical method of adding rigidity to the pick up points
Old 12-04-2010, 10:36 AM   #2121
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
cool, when do you plan to have them installed?
I'm looking forward to you impressions
Old 12-04-2010, 10:46 AM   #2122
PoorMans180SX
Except it's illegal in Formula D and a lot of other racing classes.
Old 12-04-2010, 10:53 AM   #2123
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
damn, now I'll have to give up my dreams on becoming an FD or racing driver....
Old 12-04-2010, 11:38 AM   #2124
GripTerror
id love to get these for an s14 subframe. I plan to put an s14 subframe in my s13 so def would want some of these braces for an s14 subframe.
I care not for any D1 or whatever rules i am building an unlimited car any small bit added that benefits even slightly is a win win to me
If they are available do let me know where...
Old 12-04-2010, 11:40 AM   #2125
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
I hate FD rules.
You can build a RWD Scion TC and drive it, but you can't swap a subframe from an S14 into an S13.
In any case, I'd be interested in a set of braces should someone make them or find a source for them in the ~$400 range.
thefro526 is offline   Reply With Quote
Old 12-04-2010, 11:40 AM   #2126
PoorMans180SX
Johnnie Fraz will be making them shortly it seems.
Hahaha, I know, right? I don't care much either, I was just saying.
Old 12-04-2010, 11:47 AM   #2127
GripTerror
i hope he does
And yeah rules are bullshit
Old 12-04-2010, 12:45 PM   #2128
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
I hope none of you are planning on raising your subframe with those braces.
Not gunna happen.
I can barely get a wrench in to the "circled area" to loosen that nut.
nieko is offline   Reply With Quote
Old 12-04-2010, 12:50 PM   #2129
GripTerror
uh not looking to raise subframe but looking to reinforce the flimsy thing as those braces intended to be used.
I plan to raise it with offset subframe bushings from spl and drop car with pbm/dw knuckles but this wold be nice to keep the suspension tight. I have all arms spherical already.
Old 12-04-2010, 04:18 PM   #2130
PoorMans180SX
He's talking about raising the subframe and having those braces because of clearance issues.
Not gunna happen.
That's what big hammers/welders are for.
anti-squat, best thread ever, kpi, roll center, steering angle, suspension
