#2071 |
Man w/ CTSV & a Car Seat
Throw the 595 in the garbage. Is this for a grip or drag setup? If you're on a budget, I'd got Nitto NT05 drag radials for drag. Only catch is the shallow thread depth but for the price, you can't complain. Grip would go Hankook RS-3. If you're not a fan, Dunlop Star Spec IIs or best all around street tires, Michelin PSS but expensive a fuck.
#2072 |
stupid simple question(confused)
hi, i have a dumb question to ask, im still learning about offsets.
anyways I am replacing one of my rear rota p45r wheels. here are the current measurements- 17X8.5 17X9 235/40/17 225/40/17 my question is, I just ordered a replacement wheel for the rear. same measurements 17x9 5x114.3, cept the offset on this one is 30mm. my current offset of the rear is 12mm. Do I need to get a 18mm spacer for the 30mm offset wheel? i know this is dumb but it was the only wheel i could find. any input would help thanks! |
#2074 |
![]() Join Date: Apr 2003
Trader Rating: (33)
![]() Feedback Score: 33 reviews
FLIP...actually just for street use. I have MT Bias Ply for drag use. I am trying to figure something out that's rather budget friendly and still help me keep the rear end planted "decently" for street use.
#2075 |
Cheapest out of the bunch is probably Nitto NT05s. Only catch with them is the shallow thread depth. Right now, I've been running General G-Max in the rears. They're decent tires, not super sticky compared to what I listed above, they're not bad for all season tires and pretty predictable when they lose grip.
#2076 |
Trader Rating: (33)
Are the Rs-r that bad? Found a set for $120 each shipped and the reviews were pretty good. If you want to take the convo to pm that's cool.....don't want to cog the thread.
#2077 |
Well, they're not bad, but for extreme high performance summer tires, they're in the back of the pack. But since they're cheap, that kinda makes up for it. $120 shipped? Those brand new? In your case, since you're looking for meaty tires, and you found them for $120 shipped, I'd probably jump on them. Cant say I've ever seen them that cheap for wide tires and nothing else out there will touch that price. Even NT05s are gonna run atleast $160-180 per.
#2078 |
Trader Rating: (33)
Yeah was traveling for work recently and found them on a site I saved. I will try and post the site here once I find it. It was $120 without shipping though.
#2079 |
![]() Join Date: Nov 2010
anyone experience achilles atr sports, do they run true? will be going on my daily wrx 18x10. opinions on other tires welcome
All I read was "I'm a little bitch and don't belong in this thread". |
#2080 |
They run a tad bit wider than most I've seen. But either way, 235/40-18 will still be a stretch. I personally prefer 225/40-18s on 10js, thats all I've run in the last 5 yrs. Currently running Michelin PSS up front on these specs.
#2081 |
![]() Join Date: Jul 2010
![]() Feedback Score: 8 reviews
alright first, is a 225/35 on a 18x9.5 + 12 a good set up for stock front s13 fenders (rolled, not pulled) Second, what size tire should i run on a 18x10.5 +15 (gonna add 15mm spacers) thatll be on a s13 with 50mm rear overfenders. Takidashi orgin overfenders to be exact. trying to stay away from alot of camber. i was thinking maybe a 245/35? i will be dropping it some what flush as well. thanks
#2083 | |
![]() Join Date: Jul 2006
DODOlogic.ca |
#2086 | |
The front should be fine but the rears will need lots of camber. front and rear will require a decent stretch.
Instagram: @Yokosukanights |
#2088 |
Pretty much ^^^ new question. I have 50mm tatakidashi rear overs and have 18x10.5 +15s, is a 275/35 to much to fit in the back?? I will add spacers to get as flush as possible without rubbing.
http://img34.imageshack.us/img34/2687/p1310622.jpg Found this pic of 18x10.5s +15 with 275/35s with charge speed overs, pretty sure they're 50mms too but he never mentioned if he had used spacers, but I know a 10.5 + 15s not gonna sit all the way out there |
#2089 |
![]() Join Date: Aug 2010
Trader Rating: (39)
![]() Feedback Score: 39 reviews
^^^ i hear u but at least u have overfenders. i am on stock. which be converting to silvia metal fenders..maybe that will help if i roll or pull fenders..lets see what happens
#2091 | |
I went through the same on my new wheels. 235/40 on a 10.5 was a disaster for rubbing. i couldnt even turn the wheel all the way anymore....but since I mounted 235/35s....NO issues yet again
#2092 |
I've been searching but haven't quite found and exact answer. I'm looking at a set of wheels. It's going on an S13 with TEIN coilovers, stock body no rolls or pull. I'm not trying to get flush, just want them to clear the suspension safely.
17x8.5 +45 and 17x9 +38 with 215/45 all around I pretty sure the front's won't clear at +45. I'm guessing with a 12mm spacer up front it will clear and i could leave the rears as is? |
#2093 | |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
I would go as far as to say 15mm would be the minimum in terms of looks. As for the rear, that's cool, but I'd throw in a slip on spacer--again for aesthetic reasons only. |
#2094 |
![]() Join Date: Feb 2013
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Need help I've looked threw over 80 pages in 2 days...97 s14 cusco coil overs c.s. Rlca and Isis arm kit the car is dd and i want it some what low like tucking a 1/8 inch of tire in rear and like a finger gap in front wheels are 18x10+25 all around I think i got the rear tire size 265/35/18 with a roll and might need a pull not shore please chime in? I don't kno what will fit in the front I'm lost I kno 225/40/18 will work with a spacer but I was hope to run some thing wider like 245/35/18 I don't want to rub and no crazy pull I'm ok with a sight pull please help tires are the only thing keeping me from dd it thanks
#2096 | |
#2097 | |
225/45-17 fronts and 235/40-17 rears |
#2099 |
fliprayzin240sx thank u for your reply sir. I knew I was going to have to run a spacer in the front. if 225/40/18 is the widest tire I can fit, I'm thinking a 20mm/25mm spacer in the front. Do u know if the kumho ast runs wide/big? I'm just running out of cash, lol, and my damn pivot ball broke today before even driving the car so I will be pulling the trans in the morning.
What do you think spacer-wise for the front? How much of a pull in the rear will be needed with 265/35/18? Should I get 255/35/18? I have a buddy with a eastwood I just don't want a crazy pull; slight pull is all good. Thanks for the help! |
#2100 |
I am dying trying to find a set up with 16x8s all around. I am having troubles trying to figure out the best offset for me. My s13 coupe is slammed on Pbms and has a fully adjustable suspension all around. I'm picking up a set of diamond racing wheels soon. Can someone please help!
