Old 03-27-2012, 06:37 PM   #181
omgwtf
omgwtf's Avatar
omgwtf is an unknown quantity at this point
KA24E fuel injector o-rings fit the CA18DET
omgwtf is offline   Reply With Quote
Old 05-07-2012, 09:34 PM   #182
spaten
spaten is an unknown quantity at this point
parts shop max s13 sr20 high mount inner cooler works with t28 bottom mount and s14 sr20 inlet WITH RB26 PINK MAFF with some finagling the only thing im not sure on is not running a bov im testing it as wee speak seems to be OK but has a lot of compressor surge and instant response! ill let you no how it changes my tune next time im on the dyno
spaten is offline   Reply With Quote
Old 05-25-2012, 05:20 PM   #183
EastcoastGA240
EastcoastGA240 is an unknown quantity at this point
Okay so this might seem like a noob question, but i do need some help guys..
I just got an automatic 240 s13 hatch and it had a KA in it.. I just recently bought a CA and it came with a harness and I changed the car into a manual..
I left the cars harness in.. I need help with the wiring if anyone can help me? please! If this makes any sense..
Thank you
EastcoastGA240 is offline   Reply With Quote
Old 06-08-2012, 11:37 AM   #184
KeithS13
KeithS13's Avatar
KeithS13 is an unknown quantity at this point
Thumbs up
Thank you
I have just recently got my ca18det swap done in my 89 s13 coupe and it was also an automatic ka. I made the mistake of selling the ka motor/tranny/ and harness right away. You can use the ka motor mounts and a few other things such as the dash plug. The plug on your ca harness will be brown. you need to solder in the white plug from your ka harness for a plug in installation. Pm me if you have any other questions.
KeithS13 is offline   Reply With Quote
Old 06-08-2012, 11:46 AM   #185
KeithS13
KeithS13's Avatar
Hello all. I have recently been buttoning up the last few things on my ca build into my s13 coupe. Just a few pointers that I didnt see were posted in this thread. I have just replaced the head gasket and had a rough time getting my header back on because Im running an s15 bb turbo. The reason being was because im running the stock ka motor mounts and the turbo is super close to the mount. I dont see it affecting anything but I do plan on getting different mounts. If anyone has suggestions on which mounts i should get that would be great!
Old 06-23-2012, 08:01 PM   #186
purplove
purplove's Avatar
purplove is an unknown quantity at this point
Has anyone made any time of bracket to use a ka a/c compressor? single or dual cam.
Also, has anyone ran a water to air set up on their CA? I live in Texas and its getting into the triple digits already and a fmic would be pointless for my daily as it would block my radiator and A/C condensor.
I know this thread is old but I don't want to create a new one and everyone tell me to search, because I have already.
purplove is offline   Reply With Quote
Old 06-24-2012, 03:36 AM   #187
Croustibat
You can use a bigger wing mounted intercooler. The stock one is not enough to cool the charge in winter, so anything will be better.
Old 06-24-2012, 07:51 AM   #188
purplove
purplove's Avatar
I forgot to mention, i have tubbed wheel wells. I was going to go with a high mount from pbm but i would not be able to mount my ac condensor. So back to the question on water to air. Anyone?
Old 08-11-2012, 02:59 AM   #189
xargentum
xargentum is an unknown quantity at this point
Hello,
Im going for MegaSquirt, for s13 CA18DET, but i need basic ignition and fuel maps, to get started can anyone post screenshot from VEMS,KMS,NIStune or maybe Megasquirt? I need only screenshot with values of ignition and fuel maps
xargentum is offline   Reply With Quote
Old 08-15-2012, 10:18 AM   #190
flying squirrel
flying squirrel's Avatar
flying squirrel is an unknown quantity at this point
I have been looking at a car with an auto CA18det how hard would it be to swap to a manual transmisson? if anyone has a thread or link that could help so i can further research this before i buy the car.
thanks,
flying squirrel is offline   Reply With Quote
Old 08-15-2012, 11:03 AM   #191
Croustibat
you need a flywheel, clutch, clutch line, clutch pedal, and maybe a remap (i know auto ECUs has special circuitry for kickdown and it may run degraded mode when it does not detect it.
My advice, either stick with the autobox (which is quite good actually) or get a manual S13. It will be cheaper than swapping a manual and hassle free.
Old 08-15-2012, 12:02 PM   #192
flying squirrel
Thumbs up
Thanks for the info!
Old 10-16-2012, 12:33 AM   #193
DS240sx
DS240sx is an unknown quantity at this point
So glad that there is still a ca18det forum section!
New to 240sx and ca18dets, what would you guys say are almost *necessary* pre-install maintenance I should do. I bought the engine as a *running* engine, just want this to be a pretty reliable DD, boost will be kept at 10psi on stock turbo.
Also if anyone has a ca18det power steering pump hit me up ASAP. I have cash in hand.
DS240sx is offline   Reply With Quote
Old 10-24-2012, 07:00 AM   #194
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Question about running a SRt25g (s13 T25) on the CA18det...
For oil return lines, will I need a SR or CA return line? I've searched and searched but cant seem to find the answer. ALthought the turbo placement is simliar, I'd like to have everything installed first. I have already clocked the compressor housing and tapped the outlet pipe for the wastegate source.
Luvs2slide is offline   Reply With Quote
Old 11-08-2012, 08:25 AM   #195
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
^ nvm. Used the CA oil return line and fit like a champ.
Old 05-17-2013, 09:47 PM   #196
HakosukaJustin
HakosukaJustin is an unknown quantity at this point
This is urgent!!!!
I am driving across canada back to Ottawa and my Silvia has gone kaputs on me.
my battery blew and melted my fusebox and my alternator is toast as well.
Can I use any fusebox from other schassis? I assume I can only rebuild me ca alternator.
Any answers and help would be appreciatted. I am currently stranded in Calgary while i try and source parts. Luckly i have friends in town who took me in.
Cheers
HakosukaJustin is offline   Reply With Quote
Old 05-25-2013, 10:23 PM   #197
Drift-Freak
Drift-Freak is an unknown quantity at this point
what clips can i use from the ka24de harness for the ca18det harness?
Drift-Freak is offline   Reply With Quote
Old 09-11-2013, 09:22 AM   #198
obito_uchiha
obito_uchiha's Avatar
obito_uchiha is an unknown quantity at this point
CA ca18det lightweight crank pulley vs. stock
Hey everyone! I am new to the forum and have searched high and low for some answers on the possible issues with using a lightweight crankshaft pulley on my ca18det. I have seen mixed reviews on the subject of putting the lightweight pulley on. Some say it is bad since the stock is harmonic. I havent read anything saying that once it was own the person had issues but a lot of people have advised against it. If anyone has a solid answer let me know. I greatly appreciate it.
obito_uchiha is offline   Reply With Quote
Old 09-11-2013, 09:47 AM   #199
shogun!
shogun!'s Avatar
shogun! is on a distinguished road
Originally Posted by obito_uchiha View Post
Hey everyone! I am new to the forum. If anyone has a solid answer let me know. I greatly appreciate it.
Don't!
My +700hp RS13
shogun! is offline   Reply With Quote
Old 09-11-2013, 10:07 AM   #200
obito_uchiha
That answers that haha. Thank you. Now I have had a hard time finding a good oem crank pulley as well. Any suggestions?
Old 09-11-2013, 10:31 AM   #201
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
give raw brokerage a ring. They did ATI (IIRC) CA crank pullies back in the day. They also may have an OE one laying around.
g35gabby is offline   Reply With Quote
Old 09-11-2013, 10:35 AM   #202
obito_uchiha
I'll look into it. I appreciate it.
Old 09-11-2013, 11:06 AM   #203
shogun!
shogun!'s Avatar
Powerbond dampers
My +700hp RS13
Old 09-11-2013, 02:12 PM   #204
Croustibat
Dont.
I believe 2 companies make a good crank pulley, with harmonic balancer and all. Cant remember the name on top of my head though, 1 is australian. This is going to cost quite some money anyway so i suggest you dont get one, unless your stock pulley is broken.
Old 09-11-2013, 02:15 PM   #205
g35gabby
g35gabby's Avatar
Trader Rating: (26)
Dont.
ATI i believe is the one, they did a group buy a few years ago through RB on nico. RB makes their own now according to their site, but it is ~$600
Old 09-11-2013, 02:33 PM   #206
obito_uchiha
SR
Yeah my pockets aren't that deep haha. I may call raw brokerage and see if they have an oem one laying around. I think I may have found one. I could go through Nissan motor sports and get my dealer discount but they only stock Sr and rb parts. Can't wait 8 weeks for one from Japan. My stock one is bent so it's no good.
Old 09-11-2013, 02:34 PM   #207
g35gabby
g35gabby's Avatar
Trader Rating: (26)
you try Dee (boostboy) on Nico? he always has random OEM crap laying around.
Old 09-11-2013, 02:44 PM   #208
obito_uchiha
No I haven't. I'm not a member on there. I have a guy at need more motor sports in Birmingham doing some hunting for me as well.
Old 09-11-2013, 04:32 PM   #209
obito_uchiha
Found one!! JDM Parts and Racing Accessories direct from Japan: RHDJapan.com has one and a bunch of other stuff. I appreciate the help. Can't wait to get the motor back from the machine shop and put it all back together.
Old 10-12-2013, 05:47 PM   #210
omgwtf
omgwtf's Avatar
KA24DE clutch and pressure plate work you just have to drill out a hole for the dowel pin and use a 7/16 drill bit to enlarge the mount holes along the outside and it will work fine.
