Old 10-22-2011, 09:15 PM   #181
NoPistons!
NoPistons!'s Avatar
NoPistons! is an unknown quantity at this point
Stock is smog legal in california. The rest, you have to know people or pay people to get your inspection pass. $100 under the table goes a long way.
Just another broke ass drifter
NoPistons! is offline   Reply With Quote
Old 10-23-2011, 01:22 AM   #182
Turbo Nismo
Turbo Nismo's Avatar
Trader Rating: (18)
Turbo Nismo is an unknown quantity at this point
Feedback Score: 18 reviews
Originally Posted by JuniorsSr View Post
I have s14 turbo/manifold/370 injectors/ front mount/piping/255 walbro/z32 mafs still need safc/2 this is for kade I'm only planning on 230-250 rwhp do I need to change head gasket or will it hold up? Thanks
Lots of ka-t owners recomend to use Felpro hg when your going to be under 400hp. I personally always used Cometic hg, and Im currently using one. I think it could hold 230-250 hp.
IG: chris___s14
Turbo Nismo is offline   Reply With Quote
Old 10-23-2011, 01:31 AM   #183
Turbo Nismo
Trader Rating: (18)
Originally Posted by nis-son View Post
Has anyone ran the calum realtime ecu on there ka-t I'm thinking bout using that ecu for my setup. I'm aiming for 350 to 400hp
Im using a DSM ecu, it was really cheap and works awesome. My car has 400hp right know. The ecu has 2 step and anti lag option, data log in, i eliminated the maf and Im using a 3 bar map sensor and much more.
IG: chris___s14
Old 12-08-2011, 01:07 AM   #184
je_decoy
Trader Rating: (33)
je_decoy is an unknown quantity at this point
Feedback Score: 33 reviews
Originally Posted by Turbo Nismo View Post
Im using a DSM ecu, it was really cheap and works awesome. My car has 400hp right know. The ecu has 2 step and anti lag option, data log in, i eliminated the maf and Im using a 3 bar map sensor and mucho more.
wanna share on the details?
je_decoy is offline   Reply With Quote
Old 12-13-2011, 09:00 AM   #185
WolfpackDoc
WolfpackDoc is an unknown quantity at this point
Just got back from iraq bought a 93 s13 over deployment. Its completely bonestock, What are some good idea's for starting out a build, I was thinking intake manifold, clutch, injectors, cams just a good point to start a build on?
WolfpackDoc is offline   Reply With Quote
Old 01-02-2012, 04:38 AM   #186
Slims
Slims's Avatar
Slims is an unknown quantity at this point
Im guessing your wanting simple upgrade that will benefit a KA-T setup as well posting in this section?
Slims is offline   Reply With Quote
Old 01-18-2012, 09:33 PM   #187
supakat
supakat is an unknown quantity at this point
Aren't you cursing cometic now?
12.96 @ 116.36 - Build Thread
supakat is offline   Reply With Quote
Old 02-17-2012, 11:56 PM   #188
WolfpackDoc
well im now in afghanistan and it seems that my car is at home and my parts list has just started growing. being deploied and single makes things i want alot easier and having to wait on what i want just doesnt happen. Ive done alot of research on all of it, Thanks for the imput though
Old 02-18-2012, 07:47 AM   #189
Turbo Nismo
Trader Rating: (18)
I was using one and got blewn also, but it was my fault. I didn't resurface the block, I only did it to the head. That's what happens to lazy people like me, "do it once correctly or do it twice". But this time I'm going to RA on both, put the fire rings on the cylinders and use felpro this time.
Sure, you need:
-DSM 2G ECU
-DSM 1G CAS
-Ralliart coilpacks
-3 bar map sensor
-DSM 2G wiring harness
Then you need to cut your tps plug, injectors plugs, coolant sensor, RPM wire and rewire then to the DSM harness on the correct pins. Then remove everything from the inside of the ka's ignition and insert the CAS with its plug and wires. Then get a datalog cable to connect it from the DSM ECU to a laptop and start reflashing it.
IG: chris___s14
Old 02-26-2012, 10:26 PM   #190
je_decoy
Trader Rating: (33)
I guess getting this on as many forums as possible haha thanks you sir.
Old 02-27-2012, 06:08 AM   #191
Turbo Nismo
Trader Rating: (18)
No problem.
IG: chris___s14
Old 02-27-2012, 06:14 AM   #192
supakat
The more the merry.
Old 06-04-2012, 02:23 AM   #193
lilrookz
lilrookz's Avatar
lilrookz is an unknown quantity at this point
looking to boost my ka24de here soon, running a T3/T4 turbo. what ecu tune programs do some of you recommend? i wanna hear your personal experience not what your buddy is running. Im leaning towards Jim Wolf....
lilrookz is offline   Reply With Quote
Old 06-04-2012, 06:26 AM   #194
Turbo Nismo
Trader Rating: (18)
IG: chris___s14
Old 06-04-2012, 08:23 PM   #195
driftracerx
driftracerx's Avatar
driftracerx is an unknown quantity at this point
thinking of Twin charging a Ka i know it sounds crazy but if an Sr can do it i dont see why my Ka cant ..
driftracerx is offline   Reply With Quote
Old 06-04-2012, 08:26 PM   #196
je_decoy
Trader Rating: (33)
yeah you "can" do it but why bother unless your just wanting to say you did it. its just not worth it
Old 06-04-2012, 09:06 PM   #197
driftracerx
s13
True ... it would be more or less be for saying i did it, but on another side the iron-ness of a beefy Ka could actually put out some sturdy numbers , just wish full thinking i guess
Old 06-04-2012, 09:13 PM   #198
je_decoy
Trader Rating: (33)
its alright man i think everyone thats gone ka-t was thinking about that at one point
Old 06-04-2012, 09:37 PM   #199
driftracerx
s13
lol right on the nail after i went ka-t is when i started thinking about it ...
Old 06-27-2012, 05:55 PM   #200
fl240sxown
fl240sxown's Avatar
fl240sxown is an unknown quantity at this point
I got a noobish question.... Wanting to build up my 95 S14 KA24DE for turbo later on. Just wondering if I can put forged internals Rods and Pistons .40 over basically a built shortblock. And not change anything else until the turbo and head work is done??????
fl240sxown is offline   Reply With Quote
Old 06-28-2012, 12:20 AM   #201
WolfpackDoc
Ive herd of some guys running LS1 coil packs on their ka-t. High boost blows out the spark or something, Just wondering how all that would get wired up to run correctly
Old 07-23-2012, 04:55 PM   #202
shalezzz
shalezzz's Avatar
shalezzz is an unknown quantity at this point
Can anyone point me in the direction of a good write up for ka turbo coolant lines? I searched all over Ka-t, and the only one ive sen on zilvia used rubber hoses bypassing the throttle body.
shalezzz is offline   Reply With Quote
Old 07-25-2012, 01:40 AM   #203
LBK S13
LBK S13 is an unknown quantity at this point
Ok so I may be new to the site but I found this thread by actually typing in KA--T FAQ and I expected to find some questions yes but answers right behind them. I read all 11 pages of this thread and saw a lot more stupid questions then answers.
To contribute to some answers. I have a 91 s13 KA24DE T
I originally bought a used turbo from eBay. That was shit and lasted a few weeks. They warranted it and give another. That lasted a month. I found a localish tuner club and a guy had to t3/4 turbos that had their own problems and I pieced them together and have gotten about 20000miles out of them. I am running the cobra MAF and SAFC with 370cc injectors and I got it tuned more than once to make sure as far as the rest of my turbo kit it was pieced together by buying things similar to a complete kit found on a brand name website. My turbo set up has only given me one problem and that was when a drink spilt on my SAFC and shorted it out. For questions on parts and set ups there is a chat section where you can start a thread. Hope this helps someone
LBK S13 is offline   Reply With Quote
Old 07-25-2012, 02:39 AM   #204
booey13
Trader Rating: (91)
booey13 is an unknown quantity at this point
Feedback Score: 91 reviews
Are you using a bb turbo?
www.monkeyboysyo.blogspot.com
booey13 is offline   Reply With Quote
Old 08-03-2012, 06:35 PM   #205
LexSan
LexSan's Avatar
LexSan is an unknown quantity at this point
can somebody help me with a code? its for a bone stock ka. i got 1400 i told its egr related but im not sure what exactly it is. i was told maybe like an egr vaacum solenoid? or just maybe a new gas cap im not sure
LexSan is offline   Reply With Quote
Old 08-03-2012, 06:42 PM   #206
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
What are you guys hooking your wastegate vaccum too? I have a t28 turbo
roboticnissan is offline   Reply With Quote
Old 08-04-2012, 04:23 AM   #207
supakat
If you have a nipple on the compressor housing, use that. It does not need vacuum, only pressure signal. You can use a true vacuum line. It does not matter.
Old 08-04-2012, 10:30 AM   #208
roboticnissan
Can you explain a pressure signal? I obviously dont have a nipple on the compressor housing or id use it.
Old 08-04-2012, 10:15 PM   #209
supakat
Just get a vacuum line from the IC or tee off from FPR vacuum.
Old 08-06-2012, 09:34 AM   #210
roboticnissan
Ive read fpr is BAD on a lot of sites.
