#181 | |
Some LS1 info: -Aftermaket or custom intake =10-12rwhp -Porting MAFS & Throttle body =2-3rwhp -Under Drive Pulleys =5rwhp -Push rods of 5/16" diameter, 0.080" wall thickness, 4130 chrome-moly(reccomended), 1.85:1 Rocker arms, Upgraded valve springs w/titanium retainers =20rwhp/13rwtq Total:37rwhp The valve terrain of the LS1 is the weak spot so upgrading whil the engine is out would be a good idea, plus gaining some hp/tq. These are not going to be the exact same numbers for everybody but came from a reliable resource.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
#183 |
Admin Asshole
![]() Join Date: Mar 2002
Got to www.google.com and type in Longblock vs. Shortblock. Then come back and ask your questions.
#184 |
Pearl White Mike
ive been talking about diong this swap for years, and used to just get called a redneck. im glad to see so much fucking interest in it now, i know a couple people who are on board now too.
this ford vs chevy argument is fucking stupid. i build mopar performance crate engines, and feel the LSx is the way to go. if you want a cost effective simple swap do a used LSx motor. if you just have to have F(athers) O(ld) R(ubber) D(ick) power and want to be different, do the 302. just expect to upgrade alot more in the process of trying to make some decent power if you got a little more money to spend, and want a new motor, go to SDPC and they have some specials going on right now. a 408ci iron block with forged steel rotating assembly is going for $3500 shipped, $4500 for a 402 using a new LS2 block. a set of L92 heads (6.2 escalade motor) goes for $800 assembled. you can find everything else you need to run the motor cheap and used all day
"He who makes a beast of himself gets rid of the pain of being a man" ~ Samuel Johnson |
#185 | |
#186 | |
Pearl White Mike
if you want big cubes without sleeving and not worry about warping the cylinders iron block is the way to go. that would allow you to run a huge nitrous shot or forced induction however i guess even a stock bottom end ls1 or ls2 with cam and LT's should be more than sufficient for most 240 owners power needs, but im sure someone out there wants to drag race...
#188 |
![]() Join Date: Aug 2003
Yeah, back in the 60's and partly 70's
more like F(irst) O(n) R(oad) D(isabled)
Petition Nissan to Make the IDx on http://IDxClub.co ! |
#189 |
i got a question. i only know of 3 ls1-s14 before mine (hinson, someguy on ls1tech.com and that ebay one). but can anyone help me with my parking lights and blinkers. when i pulled the ka ecu and the harness, if it didnt unplug from the engine harness it came out with it. everything works (as far as i know at this time) but no parking lights or blinkers. is there a part of the engine harness that has something to do with them?
and a link to my build http://www.ls1tech.com/forums/showthread.php?t=578081 i will also be doing a up-to-date cost soon. |
#190 |
seen a few question about price so here is mine up to today (cant find fuel system reciept so add 500 i think). still a few more things to get.
motor, tran, ecu, wire, shaft, shifter 3800 volt, oil, water temp, gauges 176.26 oil pan 355 hsc nissan mod master cylinder 79 hsc new ss clutch line 83.5 shiping 18.5 steering wheel and plate 51.87 hsc headers plus shiping 896.63 hsc cooling package and shiping 667.58 cpu vats and rear o2 removel 125 j30 rear end 253 4" exhaust tip 24.99 18" of 3" exhaust pipe 5.99 new thermstat ,houseing, gasket 38.27 plugs for gauges, hood pins, toggle switch 30.62 12' of battery cable,battery top post, more wire stuff 53.93 6' of 3" exhaust 18 18" of 3" exhaust pipe 5.99 6' of 1 1/2 by 1 1/2 angle iron 21 total 6705.13 |
#192 |
Admin Asshole
3" exhaust is better, PERIOD.
Better for Stock KA, better for V8. I used to run 3.5" straight pipes on a 327 small block. Of course that was in a classic Chevy, but still... Big exahust is Gooooooooood.
#193 |
Pearl White Mike
yes youll see some ls1 guys running dual 3" with a y pipe to 4" exhaust. good luck finding somewhere to hide that piping though
if i end up buying another s14 and doing this swap, i plan to just do an X pipe after the headers, keep it true dual 3" with bullets and turndowns, as short as can be done reasonably. this is a really popular setup with the camaro guys and if done right can maximize gruond clearance and save a little weight while sounding ground im just still debating if its worth blowing that much money on another 240sx or if i should be trying to save up for a down payment on a house..
#194 |
HOUSE HOUSE HOUSE HOUSE HOUSE
go get some.
#195 |
i comeing out the headers with 3" and then a y pipe to 3 1/2" out the back. the only size i could find at local shops was 3". the next was a 18 wheeler shop and the smallest was 5". i got the 7' (which is way too much) of 3 1/2" for free. so im useing it. i got alot of little stuff for free. misc size metal to make mounts and brackets and some pipeing. some alum brackets custom made for my fuel lines. my mufflers will be custom made (cost me $20 i think, will be a simple design), 2 small ones for the 3" and 1 for the 3 1/2". and a new shifter boot. just little stuff that i know where i can get for free or have made for free. maybe a total of $500. some of it gheto and some of it nice.
#196 |
*laughs*
The KA motor and Transmission combo Don't weigh 600lbs, and the LSX motor and tranny don't wiegh Sub 500lbs. GM list the LS6 motor with a manual Flywheel at around 496lbs, and Corvettes has the transmission mounted SPERATE from the Motor. A T56 trans will weigh in over 130lbs. Transmission http://www.ls1tech.com/forums/showthread.php?t=2930 http://www.chevyhiperformance.com/te..._transmission/ Engine: http://www.corvetteactioncenter.com/...06/ls1ls6.html (notice it says NOTHING about transmission) |
#199 |
So the differnece between the Manual and Automatic engine weight is 40lbs, which means that the flywheel on a manual LS1 weights 40lbs???? It just so happens that I pulled the Ka with all acc. and tranny out of my 240 yesterday so tomorrow I will weigh it and get back to you... Oh yeah, who wants an automatic tranny unless it is state of the art Ferrari/Mercedes style?
So for $3500 you can have a reliable 350hp out of a stock engine. This is a FAq about V8 swaps and you bring you stupid ideas into here. When you show me a time slip that you ran 11's with a SR, KA-t or VQ swap and have a breakdown of price then maybe I will take what you say serious. THe LS1 is going to be cheaper and more reiliable.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts Last edited by ledzeppelin240; 10-16-2006 at 01:26 PM.. |
#200 |
YOu can grab a VQ block for a Lot cheaper than a LSX motor. Not to mention its Lighter.
NO need to be rude though, because If I were considering this swap, I'd be upset that someone gave me the wrong info. And Sport Compact Car has the Wieght of a Fully dressed KA with 5 speed manual as around 497. Only10 or so pounds more than a full SR20DET swap, and Still loss than the 630+lbs of a LSX swap. ![]() Vq swap s14. I doubt the LS motor does that to the front end. |
#201 |
Well my car looks that high in the front end and has no engine or tranny. So thats loosing 596 lbs. I would like to see the engine that is actually in that car, cause I doubt it has an engine. The VQ does not compare to the LS1 anyways, it is a 6cyl and this is a V8 FAQ... So for $3500 get a LS1 with a 6 speed manual tranny and go run 11's stock. The LS1 is a lighweight engine due it its all aluminum block/head/composite intake. So I am going by what people have weighed the engines in at because that site makes no sense how a flywheel for a V8 engine weights 40lbs.
#202 |
Pearl White Mike
a stock ls2 makes more torque off idle than the vq's peak all the way to redline
instead of hating on the LSx swap and arguing for the vq swap, why not go participate in a VQ swap thread
#203 |
YOUR WRONG. Accept it. The LSX series motors with thier inferior drivetrain are NOT lighter than the KA. They Are NOT lighter than a VQ, and for cost of this swap, your better off with a VQ swap, and some spray.
It wasn't ment to be a flamefest. I call it how I see it. |
#204 | |
Freshalloy Has a Whole archive of VQ swaps on 240sx's, be my guest and prove me wrong. There are a few reasons to do this swap, and Weight reduction is NOT one of them. |
#205 |
Unfortunately it is true that the stock LS1 flywheel approaches 50 (not 40) lbs! It's sad because the flywheel in the T56 equipped cobras only weighs 12 lbs. I don't know what GM was thinking. No fear though, the after market is starting to come alive with new cluthches like the textralia dual, that weighs under 50lbs with the pressure plate and clutch attached!
Brian Hinson weighed the KA (with auto tranny attached) that he pulled out his S14. It weighed 596 lbs. Also, a lot of the weight of the LS1 swap is in the 140 lb T56 6 speed. Which is lower and further back than the engines, something to think about. Besides you don't get the glorious, (used in Aston martins, designed for vipers) gimme 500 ftlbs anyday T56, with any nissan swaps. And PS... If you have nothing to contribute to V8, I'll repeat it... V8 silvias... GET LOST
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html Last edited by SicBastard; 10-16-2006 at 09:16 PM.. |
#206 | |
#207 |
my finshed car price. been driving it for about a week or so, just little short trips to keep an eye on things. tires dont spin as bad as i thought but if you want em to spin they will. front end just pulls up real hard and goes. only thing i dont like about it is now im broke
![]() motor, tranny, harness, pcm, shifter 3800 volt, oil, water temp, gauges 176.26 oil pan 355 hsc nissan mod master cylinder 79 hsc new ss clutch line 83.5 shiping 18.5 steering wheel and plate 51.87 hsc headers plus shiping 896.63 hsc cooling package and shiping 667.58 cpu vats and rear o2 removel 125 j30 rear end 253 4" exhaust tip 24.99 18" or 3" exhaust pipe 5.99 new thermstat ,houseing, gasket 38.27 plugs for gauges, hood pins, toggle switch 30.62 12' of battery cbale,battery top post, more wire stuff 53.93 6' of 3" exhaust 18 18" of 3" exhaust pipe 5.99 6' of 1 1/2 by 1 1/2 angle iron 21 more wire stuff, toggle switch 16.47 main battery fuse 54.49 intake clamps, k&n filter, new check rngine light 65.67 heater hose, clamps 15.84 new steel drive shaft 275.32 misc exhaust 17.53 fuel system, dip stick, intake 90 618.85 total. 7769.3 btw:i got the blickers working. i didnt have the emergency flasher switch pluged up cause the dash wasnt in the car. the only thing not working now is the front parking lights (dunno why, maybe just a fuse). and wipers will not work cause the plug to them was part of the engine harness. but i found a thread with some wire info for them. |
#208 |
I already sold my engine harness... doh! I was pretty proud of myself for not damaging/crushing a single connector. I've got an s14 as well. So if you figure out a solution for the wipers PLEASE please post it up! Do you know of anything else that relies on the engine harness?
Did all J30s come with limited slips? Was it a direct bolt in to the s14? Does it always lay two nice stripes?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#209 |
only thing i found thats was part of the engine harness was the wipers. as i said my front corner light aint working. dunno why for sure. but everything down to the electic mirrors work.
link to info on wiper wires. http://www2.freshalloy.com/showthread.php?t=157283 yet to test the info. but im only going to hook up my wipers for high and thats it. and im not useing the plug for the wiper. just some 1/4" wire connects will fit on the wiper plugs. im sure with some work you could use the stock wiper switch but im not going to. on the rear end. from everything i heard all infinty cars come with lsd. just turn the output shafts and both should turn the same way and should be harder to turn then a open one. they say 95+ j30s are bolt on. the one i got was a 95 and its a bolt-on. get your drive shaft made after you get your rear end cause its got a abs sensor on the front making it 3/4" longer then the 240 (unless yours has abs). they say the q45 is a bolt-on but the one i saw at the yard wasnt. cause i wanted the q45 for the higher gears. just look at the output shaft before buying it. they should have 3 sets of 2 bolts. like a triangle shape with 2 bolts and each point. the q45 i saw was a 5 star bolt pattern. i havent really got out and looked at the tire marks but atm im not running matching tires. i have one odd rim and tire on the back. 3 stock rims and tires and one thats a 17x7 rim that im useing as a spare. and the tire thats on the 17x7 dont grip like the ones on the stock rims. as hard as it pulls i pretty sure they are both griping. |
#210 |
http://forums2.freshalloy.com/showth...hlight=vq+swap
I don't see were the extra 100lbs is comming from.... 500lbs > 630. Stop unsing weight reduction as a reason for this swap. Distrubition may be better though. |
