05-08-2013, 05:48 PM | #2041 | |
I just tried to start my car last week but my starter wouldn't crank, I'm attributing that too a poor ground or something from the engin to chasis.
BlackHand |
05-08-2013, 10:45 PM | #2043 |
with the aem i follow the aem pinout. i never have to look at the factory manuals. the aem uses a lot less of the crap that a factory system uses. only one cam sensor. i remove all the auto crap and the traction stuff. basically left with some sensor wires and the injector and coil wires. everything else on the ecu plug is power and ground.
plus the aem allows me to add oil temp and pressure sensors better map sensor and what ever else i want. |
05-09-2013, 12:15 AM | #2044 |
Trader Rating: (79)
Feedback Score: 79 reviews
My Build: The "Coupe De Ville" 1JZ Build!! |
05-09-2013, 12:48 PM | #2045 | |
On a side note, anyone selling this bracket? It connects the power steering pump to the side of the engine block. May need stock pulley as well. |
05-09-2013, 03:06 PM | #2048 |
Hey anyone willing to test my 1jz jza70 ecu for me. Willing to ship it and you test it and your car. I'm kind a wits end trying to figure this car out or if anyone can chime in why Im not getting injector pulsing I would love to listen. Pretty please.....
05-09-2013, 05:27 PM | #2049 | |
I removed all auto/traction wires/pins. I need to go over my wiring because I can't check anything when I plug in a I-Scan to check values and codes.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
05-10-2013, 09:39 AM | #2054 |
05-10-2013, 10:04 AM | #2055 |
1jzvvti
Is any one using stock fuel lines. I have a s14 and debating braided or leave the stock lines. But with exhaust on the same side now worries me. Or maybe just have one -8 feed and could I use stock feed line as a return or not good enough? My goal is around 600whp.
05-13-2013, 12:24 PM | #2056 |
Trader Rating: (53)
Feedback Score: 53 reviews
Ok so i bought the oil cooler bypass adapter and i was wondering, when i thread it into the block, do i need to add any type of thread locker (red or blue)?
05-13-2013, 09:55 PM | #2059 |
Trader Rating: (53)
Ok, from what i have gathered, i believe the white thing pictured here is called a fuel pulsation dampener. Is this something that i need to keep if im installing the Aeromotive FPR kit? i wouldnt think i would need to keep it, but i want to make sure. Also, what is this red sensor that is pictured? it had 2 vac lines going to the back side of it, but i cant tell what the hell it is...
05-14-2013, 09:20 AM | #2062 | |
some people get away by just putting in a AFPR, and some people dont.(they have braking up issues around 3k rpm with it off) but if you gave after market fuel system and/or aftermarket ecu then you will be fine. |
05-14-2013, 11:05 AM | #2063 |
Trader Rating: (53)
Engine is mostly stock, just with a single turbo conversion, AFPR, and a few other things. i was reading the same thing about breakup issues a little earlier, so i guess i'll just be keeping it installed.
05-14-2013, 05:49 PM | #2064 |
I removed mine and it works and drives fine, but i have a t67, i still have the stock fpr also...
93 s13 coupe 5 speed- Ls2 swap in the works 97 sc300-gte/v160 |
05-14-2013, 07:22 PM | #2065 |
Trader Rating: (53)
i may just remove it and then if shit messes up, i'll put it back on. i think that the aeromotive FPR would be a hell of a lot better at regulating pulsations than the stock FPR.
with that said, does anyone know what the red sensor is? |
05-15-2013, 07:25 AM | #2066 |
so here is my ac delete bracket. pushed the steel collars out of the ac pump bracket and then just used 3/8th round bar. we were able to use the ac pump as a jig.
05-15-2013, 08:50 AM | #2067 |
Recent 2JZGTE VVTI Install into a Nissan S13.
Built Bottom End - Supertech Dual Valve Springs & Retainer Kit - Tomei VVTI Pon Cams Precision 1200cc Injectors - Ross Machine Fuel Rail - Garrett GTX3582R Turbo - Tial 44mvr Koyo N Flow Radiator - Mishimoto oil cooler - Mishimoto 4" Intercooler - Intake Manifold with Q45 Throttle Body - and much more.
Contact: Phone - 513-874-2508 AIM - ZLR0bert Email - [email protected] Zerolift facebook - http://www.facebook.com/Zerolift |
05-15-2013, 08:54 AM | #2068 | ||
Sent from my iPhone using Tapatalk 2
05-16-2013, 11:47 AM | #2069 | |
05-16-2013, 12:15 PM | #2070 | |
BlackHand |
