#2041 |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
okay so plugged in the same numbers and this is what i got from willitfit:
old/new Diameter 615mm 606mm Circumference 1932.1mm 1903.8mm Poke 42.6mm 101.6mm Inset 122.6mm 101.6mm Speedo error 0% 1.49% Reading at 30mph 30mph 30.45mph Reading at 60mph 60mph 60.89mph Ride height gain 0mm -4.5mm Arch gap loss 0mm -4.5mm So how would I go about seeing if I will hit lock to lock and not rub? acutually it gives to reading from the speedo. well from the two diff sites....
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
#2042 |
![]() ![]() 18x10 +25R 295/35/18. stock rolled fenders. I have a question. I want to go 18x11 so I can go 315 and im having trouble finding any wheels that are 17x11 or 18x11 with a +35 offset? When i installed the 18x10 +25 it seems like I had almost more than a inch before i hit the coil overs. Anyone knows what offset I can go before i max out on the coilovers? I really want to go 12 in wide if i could also. I done some research but can't really find any s14 doing some 18x11 +35 or +40 offset with a 315 tire which fits perfectly on a stock rolled fender.
98 Kouki / ID2000's / 6266 / Full Z32&Q45 drivetrain |
#2044 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
#2045 | |
![]() Join Date: Nov 2008
#2046 |
okay so plugged in the same numbers and this is what i got from willitfit.com:
old/new Diameter 615mm 606mm Circumference 1932.1mm 1903.8mm Poke 42.6mm 101.6mm Inset 122.6mm 101.6mm Speedo error 0% 1.49% Reading at 30mph 30mph 30.45mph Reading at 60mph 60mph 60.89mph Ride height gain 0mm -4.5mm Arch gap loss 0mm -4.5mm rimnsntires.com old/new Wheel size 15x6.5 ET 40 / 15x8 ET 0 BackSpace 135 mm (5.3'') / 114 mm (4.5'') 21 mm (0.8'') shorter. Rim Lip / 59 mm (2.3'') wider Typical Weight ~ 15 lbs / 7 kg ~ 18 lbs / 8 kg Tires: Tire 1 / Tire 2 Tire size 195/60-15 / 225/50-15 Section width 195 mm (7.7'') / 225 mm (8.9'') Sidewall 117 mm (4.6'') / 113 mm (4.4'') Tire diameter 615 mm (24.2'') / 607 mm (23.9'') 8 mm (1.3%) shorter. Rim sizes 15x5 to 15x7 / 15x6.5 to 15x8.5 Circumference 1931 mm (76'') / 1906 mm (75'') Revs per mile 833.4 / 844.4 Speedometer Assuming that this is OEM tire and speedometer readings are correct >>> When speedometer reads 60mph (96.6km/h) actual speed will be 59.2mph (95.3km/h): 1.3% slower. So how would I go about seeing if I will hit lock to lock and not rub? height wise it looks like a go from both sites just not sure about hitting c/o's inner fender etc. can someone help me out please. thanks! acutually it gives to reading from the speedo. well from the two diff sites....
#2047 |
Yeah Boardfield its going to be a close one. Maybe +30 18x11. Inch is 25mm so 23mm is freaking close. =/
skilz my tire is already some what rubbing since its 295/35/18. Damn so +35 won't work huh? I got cusco coilover is your some what fatter? I guess i can't really do 18x11 with a 315 unless I really pull that fender. Could i get some pictures?
#2048 | |
![]() Join Date: Apr 2007
The 225/50 on an 8" +0 is 70mm further out (POKE). So look at your car and figure out if you can add 70mm more tire toward the outside. Simple. And stock S13 wheels are 15x6, not 6.5. I'm not sure if that's what you meant or if you have some aftermarket 6.5" wheels. |
#2051 | |
![]() specs 15x6.5 +40 stock tires are 195/60/15 4 LUG. like so with usdm front: ![]() Well I measured just now and it looks like it will fit... Thats what she said... but I measured on the front most area of the tire and the back most area of the tire as well. I'll measure again with the wheels turn to full lock. about to go to bed. I measured with the current wheels, but that would change by a few mm of clearance, like credit card thin, correct? Sorry guys I'm trying to understand this! 6th time editing...
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict Last edited by hellion240sx; 09-12-2011 at 11:32 PM.. Reason: gettin way too sleepy, I shouldn't be on forums this late |
#2052 |
A 11" wide +35 just MIGHT work with zero camber but i personally don't have much faith in it. I have Stance Gr+Pro coilovers, im not sure how fat they are in comparison to your Cuscos. IMO a decent pull is a must to fit a 315 under the fender. I'll post a pic of my set up a little later but I'm only running 275's out back.
#2054 |
I'm planning on getting the same wheels(been saying that for 2 years) but in 18x10+15 in the front and 18x11+30 in the rear. Like you I'm running the stance gr+ pros, and I am curious as to how much clearance you have between the wheels and the coilovers, along with the rest of the suspension.(before and after the spacers)
#2055 | |
#2056 |
I did, and the only thing you said is that you had a little bit of rubbing in the rear between coilover and wheel, which explains the spacer, but you didn't say anything about camber settings. You also didn't say anything about the clearance in the front, or why you are running a 3mm spacer.
#2058 |
anyone? Btw update. So i measures 3 inches but not sure if I measured from the right spot. It doesn't hit anything when I measured. around the tire.
#2060 |
Yeah man, i plan to do highway rolls. I'm making 800rwhp+ and can't get any traction. I need to get some 315's bad. I really don't wanna get some wheels that 18x11 +30 and not fit a bit. lol
Shiftdriftz and skilz. How much space ya have between your wheel and coilovers. This will help me get an idea.
#2061 | |
#2062 |
Yeah got prostars 26x11.5x15 for track only. People don't like to race if you got slicks on the back. =/ I want some clean 18x11's.
#2063 | |
#2064 | |
#2065 |
Oh wow so 18x11 will sit in more than a 18x10 even with a +22 offset. So it rubs the coilovers huh. fuckkk.. guess im gonna have to get my fenders professionally pulled.
#2066 | |
I recommend this very easy calculator if you cannot do it in your head or visualize it: Wheel Offset Calculator |
#2067 | |
#2068 | |
![]() anyone else wants to take a shot? when I measured with the 3" I added it to the side wall height. Is that right?
#2069 | |
I'm almost positive that with less camber and a +25 will have no issues with the suspension , and it shouldn't take to much to clear the fender, I'm almost tempted to give +25 a shot.
#2070 |
Thanks board field ill try to comprehend what you said and get a pair of rears soon.
Here's the dyno but there was ignition issue. Not sure if the LS1 coils are just bad or needs upgrade. We might be upgrading LS2 or cbr coils soon. We already stepping up to a 6765. Im not there yet unfortunately. Sorry i made it sound like I already got 800 but wanted some answers. lol ![]()
