#1981 | |
With just lowering springs, you should be able to get close enough. Maybe not exactly within factory specs, but not far enough out to really matter. When I had lowering springs, I had also bought camber bolts, but never ended up installing them.
#1982 | |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
My car is dropped 1 1/2" and my camber up front is -1.9 on one side and -1.2 on the other. The rears arent terrible, but RUCAs would be ideal. I mean, yeah, you can slam it and just drive it... if you dont care about tire wear. |
#1983 |
![]() Join Date: Feb 2010
![]() Feedback Score: 15 reviews
Body Kit Help!
So I have a question on an origin front bumper. I have an s14 *zenki* and have the origin streamline kit. I realized i will need new jdm front blinkers. But as far as fitment it wont go all the way in because the bumper support seems to get in the way. Does it need a jdm bumper support or do i need to sand out the kit to make it fit? Thanks
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3 Last edited by Karlitos; 06-23-2010 at 01:17 PM.. Reason: specifying zenki |
#1985 |
![]() Join Date: Oct 2009
![]() ![]() Feedback Score: 11 reviews
i stripped my rear driver side studs because i was drifting with spacers
![]() so now i need to replace the studs, does anyone know how to do this that has a press? i need a press to push the studs into place, if anyone local to fontana is willing to help i'll buy you a six pack or something haha
@dangerdamian |
#1986 | |
![]() Join Date: May 2008
#1987 |
okay im looking to buy a set of enkei mesh rims but im not sure if they will fit on my car . i have a 91 240. well the guy told me his offset is 13x6.5+38 and 4x100
so will they fit my car? im trying to go buy them tomorrow.. thanks |
#1988 |
#1989 |
![]() Join Date: Sep 2009
Well first of all your S13 is 4 x 114.3 so these will not fit. Second is it originally came with 14" wheels for base or 15" for teardrops. Why would you go 13" wheels? That offset also is too high and will be pretty much sunken in.
#1990 |
well i didnt really care about them being 13s didnt think it would br a problem; so when lookin for this rims what should i look for ? anything with 4x114 should fit then correct ? sorry first time lookin for rims.
#1991 |
#1992 |
Thanks for everyones help. Also would the 2.25'' drop in front should I be concerned about rubbing the fender liners? It is still a s13 with the stock rim and tire. I'm not looking for a slammed ride height, I just had a blown front strut on the front and I came up on a deal for lowering springs and shocks all around.
#1993 | |
does anyone have a diagram of the lock mechanism. ?? i have an FSM but catnt locate it.
@UpshiftEngineering |
#1994 |
can any1 give me that link, or tell me, what are the maximum/good offset ranges for our cars
i know there was a thread and someone posted it, like 16x6.5 has 45+ or w,e idk im just making the numbers up but i know its somewhere can i get them from 16x6 to 19x10 thanks |
#1995 | |
if the handle doesn't work then see if you can pop out the cloth cover and that should give you enough room to get in there and open the latch that locks the door |
#1996 | |
thanks ![]()
@dangerdamian |
#1998 |
Nah, thats the right way to do it. There are aligning teeth on the stud that "should" make it idiot proof. Put the stud in the hub, and tap it in. It should go most of the way in without much force. Then just put the wheel on, and torque the lug to spec. It'll pull the stud into the hub.
#1999 | |
Anything from 15x6 up to 19x10 can fit on our cars. You didnt say if you had an S14 or S13. 95% of the guys who buy aftermarket rims go with 17's or 18's. I think 17's are perfect for s13's, and 18's for s14's. Ideally you want something at least 8" wide up front, and with an offset UNDER +30. Any higher than that and itll look gay. The lower you get, the further out theyll stick, and very low offsets (+15 and under) may require fender rolling, depending on rim width. I run 18x9.5 +22 front and rear on my S14 with 225/40 fronts and 255/35 rear. If I did it over, Id probably go with a 235 tire up front. |
#2000 |
new to zilvia.net but not new to automotive forums or the 240, i searched just a little but figured id just ask here. i might be in the market for a 240, sr20 swapped. how is the motor for daily driving assuming im running low boost and a few bolt ons.
#2001 |
New to the forums have been reading them for a bit though. I just purchased a S13 with a SR20. It was a track car and the previous owner mentioned the person that did the wiring skipped a decent amount of stuff in the cluster. I'm wondering what I need to do to fix/hook up the Tach and Speedo. Any help would be appreciated trying to get these two items working any kind of direction you could point me in would be great.
#2003 |
4x114 will fit. Make sure center hub is the right size (or get hub centric rings to fit) and around 25 offset or below to be flush (depending on width). The 13's will also make your car lower depending on the tire size you choose. I believe there is a sticky on this subject though.
#2005 | ||
#2007 |
The temp works and the lights for the parking brake. The fuel gauge doesn't work either. He said only the bare minimums were hooked up/wired up. I'll look on the trans and see if it's plugged in or not the tach just sits on 0 revs of course but the speedo floats and has just settled somewhere around the 80s I think it was. Do I need to do some wiring? Also the lighting for the cluster doesn't work either that i'm aware of.
#2008 |
Yeah I'd say youve got some wiring to do. You can tackle each problem one by one, or re-do all of the wiring. I cant offer much help for wiring- Im getting a wiring specialties premade harness so i dont have to do jack shit. Wiring is not my forte, sorry.
#2009 | |
thanks anyways bro - im buying 17s also ![]() |
#2010 | |
![]() Join Date: Jul 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
Are there any advantages with Nismo pilot bushings to a stock one? |
