07-04-2016, 12:02 AM | #19951 |
I just replaced my rear s14 brake pads + rotors with hawks pads and brembo rotors. After installation my e brake doesn't lock like it used to and there's uneven wear on the rotors (inner is getting more worn than outer). Any suggestions??? I'm thinking caliper guide pins are bad?
07-04-2016, 07:18 AM | #19952 | |
07-04-2016, 07:32 AM | #19953 | |
07-04-2016, 08:34 AM | #19954 | |
07-05-2016, 05:01 AM | #19955 | |
http://www.asseenontv.com/leather-an...l.php?p=295262
07-05-2016, 04:01 PM | #19956 | |
07-07-2016, 10:08 PM | #19960 | |
All of the things Sent from my iPhone using Tapatalk |
07-08-2016, 06:09 AM | #19961 |
If pumping brake pedal while car is on and rpms begin to slowly drop means I have a booster/vacuum leak, is that right?
Sent from my SPH-L720T using Tapatalk
Skurr Skurr |
07-08-2016, 04:08 PM | #19962 |
I have a 1990 single cam 240. Today I got in my car started it up, check engine light was on but it ran great, about 5 min later the check engine light turned off and the car bogged down and died. Has anyone had the happen? What could be wrong. I searched and found no similar problems. The check engine light is normally off btw. I was able to start it after a while of cranking and the check engine light came on again and ran fine. 2 min later the light went off and bogged down.
07-08-2016, 04:19 PM | #19963 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
pull your ECU, put it into diag mode, read blinky lights with handy instructions below...
http://www.240sx.org/faq/articles/ecmcodes.htm |
07-08-2016, 08:18 PM | #19964 | |
07-09-2016, 07:11 AM | #19967 |
I was wondering if someone could confirm or deny if the cause of this transmission noise is a bad throw-out bearing
s13 sr20 trans in ka bellhousing Heres a short video of the noise: https://youtu.be/EeiW2ZU7hs0 |
07-10-2016, 06:41 AM | #19970 |
Trader Rating: (24)
Feedback Score: 24 reviews
You can use moog mazda 3 endlinks (not Mazdaspeed) and those work pretty good. Two sealed ball joints instead of sphericals.
They work for s13 so I suspect they work fine for s14, too. |
07-10-2016, 12:37 PM | #19971 | |
Would you happen to know the part #??? edit: nvm http://www.moog-suspension-parts.com/moog-k9825 moog makes sway bar end links for s14s!!!
07-11-2016, 12:49 AM | #19972 |
Im new to the forum, im looking for a wiring guide for the white under dash plug for a s13
i have a 1990 240sx hatch, recently did a red top sr20det swap. the engine has good compression, fuel pressure, proper timing, and so forth. the engine will crank over and its a battle to start it, i have to keep the throttle body wide open for it to start. once it starts it dies instantly. i took the fuel rail off and had my buddy crank it over, the injector spray is puney, not very strong. my honda s2k has a way more powerful spray than these things... my local "injection" shop tested the injectors and they said they are good.... im thinking either they are full of crap or the constant 12v has intermittent problems, the red wire, should i just hard wire them to the battery and see if that solves my problem? I really appreciate any help here im starting to get really frustrated with this incredible swap. also, does anybody have a better wiring for the fuse box wires from the harness? and the white under dash plug? better than FRsports crummy one? thanks! |
07-11-2016, 03:34 PM | #19974 |
Is there a way to test popup headlight motors with them out of the car? I was thinking i could just apply power to certain prongs and get them to work, just to see which ones are working. I have 2 sets, 1 set wouldnt pop up and i went silvia front anyway. Now i need them, and i am wondering which set will work
07-11-2016, 05:31 PM | #19975 |
Bolt sizes
Going to pick up a rolling shell this week, just have to put on a few parts for the front suspension
I need to know the bolt sizes/thread for the following parts: Front Tension rods Front LCA Thanks a lot in advance |
07-13-2016, 09:19 PM | #19977 |
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
For 2 tone s13 coupes, what's the paint code for the bottom gold section on the white/gold cars?
★ ★ GRANDMIGHTY.COM ★ ★ |
07-15-2016, 01:25 PM | #19980 |
S14 t28 frsh rebuild
Blitz bov Aem ems 370cc sr injectors Evo9 stock fmic 3in dp 3in exhaust Cast manifold Aem wideband Headgasket Ngk BKR7EIX-11 255fp Fresh ka24de Can i hit 300 whp relatively safely? Last edited by jared420sx; 07-15-2016 at 02:25 PM.. Reason: Forgot stuff |
