#19891 | |
![]() Join Date: Oct 2009
Must I install an S14 subframe? S13 hatch is car in question
As long as you're not a ham-fisted retard there shouldn't be a problem. |
#19892 | |
#19893 |
Are these O.E bushing or Polys?
Parked the car, and put it up on jack stands in preperation for the subframe drop tomorrow. Noticed these don't look like old oem bushing I've seen on google. ![]() |
#19894 | |
![]() Join Date: Nov 2015
![]() ![]() Feedback Score: 6 reviews
Sent from my SPH-L720T using Tapatalk
Skurr ![]() |
#19896 | |
Skurr ![]() |
#19897 |
Does anyone what these two connectors go to? They're next to the audio wiring. Fsm says they're not used. I want to use them for gauges.
![]() Last edited by NiSilS14; 06-16-2016 at 09:41 PM.. |
#19898 |
I think that black one is for that 12V source where you can put like a cig lighter and that second one has something to do with automatic transmission. Im assuming your car is manual at this point (mine has the same "extras") and theyre not plugged into anything. I would view the FSM section regarding anything A/T to really get the idea of what it connects to.
#19899 |
#19901 |
![]() Join Date: Apr 2016
I think that's for the cig lighter and illumination. It's m78(illumination) and m47(lighter) page el-204 and 205 in the fsm.
The CD player connections should be bundled together with the radio wiring |
#19902 | |
![]() Join Date: Jun 2010
#19903 |
I did just clarify. Those are cd changer plugs, I used the wires for my Kouki triple din gauges. The cig lighter and light are 2-pin connector. And the auto trans stuff is down by the shifter, not poking out under the dash.
I even drew up the pin out info a few years ago. ![]() They're M45 and M46 connectors specifically. Not bundled with radio, more like in the same area. Last edited by LoSt180; 06-17-2016 at 07:15 AM.. |
#19904 |
#19905 |
I stand corrected. Out of curiosity, I checked my car(no CD, auto) and sure enough, those connectors are just dangling there.
Should have known better, since my last 97 had the CD changer. But that was 7 years ago. |
#19906 | |
#19907 |
Maybe they've gone bad also? Check other bushings in that area, rear lower control arm ball joint could be bad, also could be bad diff bushings as well.
#19909 | |
Did notice one of the "L" bracket captured nut(in the chassis) is broken free and won't tighten. ![]() Oh, and appearently I have a bad wheel bearing. F**k. |
#19911 |
![]() Join Date: Jan 2014
![]() ![]() Feedback Score: 13 reviews
Im turboing my ka at the moment. but still havent figured out what to do ab exhaust system. I was told to go 3in straight pipe. How loud would that be? I dont want attract alot of unwanted attention and get pulled over all the time but i also dont wana sound ricey or pay $800+ for a decent exhaust.
Edit* sorry for double post didnt realize. |
#19912 | |
![]() Join Date: Dec 2013
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
The isis one with the muffler is very quiet, its the dual tip one, not the gt one. I have it on my rb25 and it is very quiet The welds look pretty good too I would say go hks, but pretty sure the hi powers are pretty loud The isis one, i Think its called msbe or something, just look on enjuku Sent from my iPhone using Tapatalk |
#19914 | |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
http://www.frsport.com/Sport-Exhaust...FYqPfgodDJMFkQ pic of my car from when i first installed it... ![]() |
#19916 |
While checking the timing on my sr20det with Ecu Talk I've noticed that the timing is very sporadic, ranging from 15*, 5*, 10*,12* and everything in between at idle. I'm just wondering if the timing should be pretty consistent, maybe jumping up or down a degree, or is what I'm seeing considered normal? The car starts and idles fine (around 900- 1000 rpm's) even on a cold start and will adjusting the timing at the cas help the issue? The ecu is not showing any fault codes. Thanks for the advice in advance.
under cover brother |
#19917 | |
#19918 |
Anybody know what skid plate fits a C33 Laurel? I need one for mine but am unsure if a s13 one will fit as it uses a rb20 crossmember and a s13 lower rad support and r32 skyline upper rad support
![]() Sent from my SM-G920W8 using Tapatalk |
#19919 |
Does anyone know what could cause sudden increase of brake travel to brake with the same force?
Went out for a drive today, was coming back and was going down a hill noticed that at the usual point where the brakes start braking, the car wasnt stopping much so I had to press the pedal harder. Tried it again later in the drive on a flatter road and the issue still persisted. So, suddenly, I have to push more of the brake pedal to stop the same amount. Im starting to think there is air in the system. Hopefully someone can chime in. *I opened the bmc and saw an air bubble on top; idk if that means anything. |
