05-20-2016, 01:11 AM | #19771 | |
05-20-2016, 01:13 AM | #19772 |
05-20-2016, 01:16 AM | #19773 |
Damn, thanks for holding back dude, idk if i couldve handled what your input would've been, i mean shit.... why the fuck reply to a question on site designed for questions, which has a specialized section, for questions, im at a loss for words, who the fuck would think of that? Lol nah man but seriously my bad, thanks for ur input
05-20-2016, 01:32 AM | #19774 | |
Dude the danger isn't in the work itself. If you don't bleed your brakes properly... you don't stop. Clamping the line doesn't do shit for you. When you put another caliper on, you got air in the system. I know you think you're in the right by saying what you did in your quadruple post, but you aren't. There's probably about 40+ years of hardcore combined experience from just the people responding to you, who know you are not in the right. Let alone the hundreds that facepalmed at what you've said you've done, who did not respond. And we're trying to get you to see that. Not only that, I gave you the best answer anyone could've/would've given you (especially on zilvia aka flameland), and you completely disrespected me in return. You are the epitome of the loser in this community who the guys that know what they're doing hate. In laments for you, because you probably dont get it yet: you are the fuckboi. I hope you get banned. Last edited by zombiewolf513; 05-20-2016 at 04:07 AM.. |
05-20-2016, 09:39 AM | #19777 |
In for the part out when Jay crashes into something because he couldn't ......
I left that part blank because from his workmanship, it could be anything... stop, steer, accelerate.....etc
05-20-2016, 10:33 AM | #19778 | |
Intermittent issue sounds like wire shortages to me, but i would still check the sensor first. You might even be able to have a friend drive while you monitor the sensor input/cluster output pins at the ecu instead of going the whole take it out route. |
05-20-2016, 01:31 PM | #19779 |
yes i know this has probably been covered i have searched already and cant find a definitive answer. does anyone know how to wire 94 mustang harness into a 240sx s13.
05-21-2016, 07:16 AM | #19780 |
@zombiewolf513
Im fairly certain the sensor is fine bc i originally had an s13 speed sensor in there (came w transmission during prev owners 5 man swap) and the same thing happened regarding the fluttering, but it seemed like the speedometer worked less often than it does with the s14 sensor. So I agree that I'm certain there could be an issue with the transmission of the input/output signal. I guess Im just not certain on how to look into it and where to start troubleshooting the harness Sent from my SPH-L720T using Tapatalk
Skurr Skurr |
05-21-2016, 09:06 PM | #19781 | |
05-21-2016, 09:26 PM | #19782 |
That is a helluva lot easier than taking it out of the... Prior means basically. Gawsh, Ive never touched the ECU. Ill have to caress it like a child once I dismount it
05-22-2016, 07:12 AM | #19784 | |
M, I have been working on mine for a while to get it back to good form after it was wrecked. Drill out welds, replace a small portion of the frame, bust my ass in my friend's shop until it went from a wrecked red car to the beautiful gunmetal ride it is today. Currently working on replacing the head...because I learned a valuable lesson in timing and incorrect timing which cost me a nice tidy sum and lots of time. I moved far beyond bolting shit on a long time ago, and brakes, hub swaps, cat backs and intakes, that's skill level 1 stuff kids who are living in their parents basement do. I kinda rebuilt this car, bled and sweated my ass off when I saw the corr support forward and from the seam forward had to be drilled out and replaced. A years worth of work, hard work, BUILT work nah, I don't 240 at all
05-22-2016, 08:52 PM | #19786 |
@zombiewolf513
I know you're at least following, but I haven't had time to check out the pinout since I don't have access to a voltmeter yet. But I was driving today and my tachometer literally went from 3k to 0 then back up. Repeating something similar several times during my journey. I guess with this coupled with my speedo not working, do you think something is up with my cluster? Sent from my SPH-L720T using Tapatalk
Skurr Skurr |
05-23-2016, 07:05 AM | #19789 | |
05-23-2016, 02:55 PM | #19792 |
05-23-2016, 02:59 PM | #19793 | |
Trader Rating: (53)
Feedback Score: 53 reviews
It's pretty easy to do yourself. If I was local I would definitely do it for you.
: @e_lemonation |
05-24-2016, 04:57 AM | #19794 | |
Be wary of truck engines though. A 240 KA24DE made in Japan has a CRANK GIRDLE on it that the Mexican truck engines do not have, but they look the same on the outside
05-24-2016, 11:41 AM | #19795 |
Ok guys my boost gauge isn't working, I have a brand new autometer ultra lite II tha only reads boost not vaccum too. I hooked up the line to T off the fpr and still no reading. Do I have It in the wrong place? I know the gauge works cause I can blow into the line and it reads it.
05-24-2016, 11:54 AM | #19796 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
if there is no vacuum indicators on the gauge, its meant for a super charger.
i believe youre meant to T from the wastegate or BOV vacuum, not FPR. if i remember correctly, T'ing from the FPR vacuum will actually mess with your overall vacuum strength going to the FPR itself. i have mine T'd off the BOV was my wastegate is tapped directly from the turbo intake pipe at the base of the turbo. |
05-24-2016, 02:31 PM | #19797 | |
05-24-2016, 03:01 PM | #19798 | |
My boost gauge looks like this one, are you saying this is for a supercharger? |
05-24-2016, 03:04 PM | #19799 | |
