#1924 |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Nothing big. I made a simple holder for my paint guns that way it makes my life a little bit easier when I have to put in the primer, paint etc. in the gun. I got the material free so it was no biggie.
I used flux core so grinded down the splatter and fat welds because I'm using .030 wire and that seems pretty thick for my thin material. w/e it got the job done ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#1926 |
Well this is my first post and I figured this would be a good thread to get started. There is some awesome fabrication going on here!!!!
Here are a few pics of parts I've built recently. External wastegate on o2 housing DSM T3 manifold Evo forward facing manifold ![]() mounted ![]() I'll see if I can dig up more if anyone is interested |
#1928 |
![]() Join Date: Feb 2009
thought you guys might be interested in this one,
this is a space frame im in the middle of fabricating for a customer, its a off road buggy, or dune buggy, theres a 1.3 corolla engine going into it, but the customer is putting a glanza turbo engine in in the future. its a full custom mandrell bent frame, made from 1 7/8th tubing, and 1 1/2 tubing. on this one im only doing the frame, and all suspension mounting the engine and fab work, should be a prety cool little machine. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
"Racing is life. Everything else that happens before or after is just waiting." ~Steve McQueen [Le Mans -1970] |
#1930 |
maybe? i dont know, what are ya seeing?
#1931 |
hey guys, i primarily lurk in this thread and i've finally got some funds to get a welder. i found a good deal locally for a lincoln weld-pak 100. I'm a beginner and have never welded but want to learn. From research, this looks like a great welder to learn on. it's marketed as a flux core/MIG. any personal experience or any advice on whether or not this seems like a good starter welder?
thanks for any advice! |
#1933 | |
thanks for your input! |
#1935 |
![]() Join Date: Jan 2005
it works well
the only thing i dont like about it is the fact that its not really powerful enough to do cages easily, i mean it will do cages but barely works great for anything else though one day i will upgrade but its definately a good starter the guide for settings it comes with is pretty accurate too
Need automotive work done in the antelope valley? Ask me how i can help. |
#1937 | |
![]() Join Date: Aug 2007
do not try to do cages with that welder it will not penetrate the wall of the tubing. if you like i can prove it |
#1938 | ||
![]() Join Date: May 2006
Although the Lincoln 110V welder says it'll do 1/8", and most roll cage tubing is .090" or .120", a lot of stuff I've seen shows that you just can't get the penetration - whether that's from duty cycle (the small 110V stuff has a duty cycle of like 20%, can't go laying a continuous bead around 1.5" tubing and expect penetration all the way through to the end), or bar placement at the joints. In any case, it's fine for everything else (seam welding, brackets, exhaust piping, etc).
#1939 | |
ive tried it and i know it doesnt work its great for exhaust piping and steel intercooler piping though and stitch welding our tin can cars
#1940 | |
ahh now i see it, no it is square, it must just be the pic, i squared all the tubes, and she sits level, just a funny angle.
#1941 |
just small update, finished the rear shock turrets
made them out of 1 1/2 tube, and just triangulated them back to the main frame. there very strong and should hold up well in a roll. ![]() ![]() ![]() ![]() ![]() ![]()
#1946 |
thanks, some of it is CREW, and some DOM. the guy im building it for just wants it for leisure so he doesnt want to get the wallet out for CDS seamless or even DOM throughout.
#1949 |
its basically just different processes in which metal tube is made, and each have different properties for certain jobs. CREW would be your industry standard metal tube. used in construction, metal works, etc. its basicaly long metal strips of a required size, drawn through a die to round and the butt welded at the seam. DOM is CREW drawn over a mandrel or die, its cold drawn, and makes the wall uniform thickness and is tougher than CREW,. CDS, is a completely different process in which a large billet of solid steel is heated and pierced through the center and then drawn over mandrel, even though DOM may sometimes look seamless its not as it started out as CREW, CDS is true seamless tube. The cold-drawing process creates a uniform, precision product with substantially improved tolerances, surface finish and tensile strength, increased hardness and good machinability. In this process, the tube is cleaned and annealed, and one end of each length is squeezed to a point so it can be gripped by the drawing mechanism. The tube is then drawn through one or more dies and over mandrels. This reduces the diameter of the tube and thins its walls to the required dimensions in a controlled fashion to provide the qualities desired in the finished product. theres loads of more details and facts, but thats the basic rundown.
