Old 06-21-2011, 03:57 PM   #1921
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
Originally Posted by ROIDMONKEY View Post
NICE WHEELS...WHAT SIZES? lol
17x9.75" 25mm offset for front and rear.
Silvia, built 5.3 turbo, 4l80e, 9.8@142
Fred Allen Burge is offline   Reply With Quote
Old 06-26-2011, 01:44 AM   #1922
nep
nep's Avatar
nep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the rough
so confused. when using the frontspace/backspace measurements SicBastard pioneered on page 26, do you add an inch to the rim? for example, a 9j wheel is actually 10 inches lip to lip, so i assume that is the correct way. the reason i ask is because SicBeard appears to have used two different methods, one where he adds an inch and another where he doesnt. an example:
Originally Posted by SicBastard View Post
Sounds great, They'll probably even fit under stock fenders with a good R&P.
For the rear though you might even be able to pull off 18x11.5 +26. that's using a Backspace of 172, and a Frontspace of 120mm (which I'm thinking is the most you could have and still get under stock s14 R&P'd fenders and not have it look whack).
here he appears to use the actual 11.5" wheel in his calculation, whereas here:
Originally Posted by SicBastad View Post
backspace 157mm
gsracers 18x10 + 18 w 275 rubber
here he appears to use 10" + 1" = 11" in his calculation
anyone clarify?
nep is offline   Reply With Quote
Old 06-26-2011, 12:05 PM   #1923
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
anyone clarify?
You have a firm grasp on it. The original post/method is usually half an inch lower than the actual BS. Like you said, the difference between a wheels quoted/tire-seat width (which is used with offset), and its actual outer width (used for backspace) is usually off by about an inch.
So after you calculate the backspace using the wheels quoted width (inner tire-seat to inner tire-seat) and offset. You have to add half an inch to that to get the real back space (one inch difference between quoted and outer, devided by 2 = half inch). Of course that ~inch difference varies by wheel manufacturer, so it's always better to measure the actual wheel if you have it.
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 06-26-2011, 03:47 PM   #1924
nep
nep's Avatar
Awesome. Thanks for introducing some logic into the voodoo that is wheel fitment
Old 06-27-2011, 02:58 PM   #1925
SicBastard
SicBastard's Avatar
I told my Dad that degree in Philosophy/Logic wasn't a waste of time!
Old 06-30-2011, 11:14 PM   #1926
gsxr141
gsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymore
i know it's not a 240, but here's what i'm working with.
i have my flame suit on, due to the ride height. lol
17x9 +24 with 275-40's and 17x10.5 +27 with 315-35's.
the car will be lowered and the fenders flared for an exact fit.
gsxr141 is offline   Reply With Quote
Old 07-04-2011, 07:48 AM   #1927
raylit20
raylit20 is an unknown quantity at this point
Gsxr, what kind of wheels are those? I've been looking for a set of 17x10.5's and am having a hard time finding any that aren't either ridiculously expensive or mustang replicas.
raylit20 is offline   Reply With Quote
Old 07-04-2011, 08:02 AM   #1928
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
I think those ARE Mustang replicas...
http://www.americanmuscle.com/17x105...el-chrome.html
simmode1 is offline   Reply With Quote
Old 07-04-2011, 09:14 AM   #1929
gsxr141
yep. the rears are reps, and the fronts are ford wheels. you can't really go wrong for the price. i actually wish the rear offset was weaker so the tires would sit in a little farther. oh well, nothing a roll and pull can't fix. lol
Old 07-10-2011, 09:52 AM   #1930
Thefugitive
Thefugitive is an unknown quantity at this point
Ive got a coupe stock suspension, and (2)17x8.25 +25 (2)17x9.75 +25 Im thinking of running 215/45-17 front and 235/45-17 rear.. You think it will work? Or will I need to do some fender rolling? Any help would be appreciated..
Thefugitive is offline   Reply With Quote
Old 07-10-2011, 11:33 AM   #1931
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Lmao GTFO with that bullshit. 215 tires on an 8.25 wheel? The only way 215 are acceptable in this thread is if you put em on bicycle rims.
R@ddy is offline   Reply With Quote
Old 07-11-2011, 12:24 AM   #1932
sr20s13abel
sr20s13abel's Avatar
sr20s13abel is an unknown quantity at this point
another drag s13 supporting...
Originally Posted by S@nt0s View Post
"we need to change the stereotype that S chassis cars are only good for the slammed look or drift. It's unfortunately a small crowd but people don't know what they are missing."
i agree, i am always asked that isnt for drifting, i say i dont do that figure skater shit lol
im going for grip/tire but in a different way
15x8 Weld RT's
235/60R15 but measured out is a 26'' x 9.5''
17x4.5 Weld Alumastars M&H 185/55
HERE IS ANOTHER S13.. ON THE DRAG MODE !!
15x10 weld racing with 275/50R15 MT ET STREET TO DRIVE ON THE STREET...
15x8 welds with 26X8.5 mt et drag to race !! (going 26x10)
MORE TO COME !!!
YouTube - ‪Tuned by Nelson S, Indio Drag S13,SR20store GT35R 622WHP *‬‏
sr20s13abel is offline   Reply With Quote
Old 07-12-2011, 10:05 AM   #1933
WISH ONE
Finally put on wheels 285/35 rear and 255/35 front.
I would really like to run a 285/275 or 275 all around or 275/265 but this is what I've got for now.
20mm wide fronts
50mm rears. running a 25mm spacer in the rear.
Old 07-12-2011, 10:16 AM   #1934
GripTerror
GripTerror is an unknown quantity at this point
That looks hot seriously good job
GripTerror is offline   Reply With Quote
Old 07-12-2011, 10:26 AM   #1935
SicBastard
SicBastard's Avatar
S13abel 1.459 60' is NO JOKE! Right on!
Wish, looks great. What wheels are those?
Old 07-12-2011, 10:34 AM   #1936
sr20s13abel
Thanks.. Its a nice feeling.. Lol
Old 07-12-2011, 11:53 AM   #1937
WISH ONE
Thanks! 18x9.75 xxr 527s +25 I believe.
Nothing fancy and at 500$ a set I couldn't resist and I bought 3 sets. lol
I have a set of gold Im waiting to put tires on.
Old 07-12-2011, 01:07 PM   #1938
noucamp
noucamp is an unknown quantity at this point
s14a all ET5
FRONT: Rota GTR 18x9,5 230/35
REAR: Rota GTR 18x9,5 255/30
[url=http://www.fotosik.pl]
noucamp is offline   Reply With Quote
Old 07-12-2011, 02:21 PM   #1939
WISH ONE
why dont you run 255 all around?
Old 07-12-2011, 02:52 PM   #1940
Karlitos
Karlitos's Avatar
Karlitos is an unknown quantity at this point
@WishOne Really Nice job looks sick. Just wondering, what front overfenders are those? They dont have a vent which makes them look better.
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3
Karlitos is offline   Reply With Quote
Old 07-12-2011, 03:15 PM   #1941
Fred Allen Burge
20mm wide fronts
Sweet, now I can order fenders! I was wondering if I'd need 20mm fenders on my coupe running these wheels, I've got the same size front wheel/tire as you (17" though) and 275/40 rear tire. Hoping I can get by with just a roll/pull in the rear though.
Old 07-12-2011, 03:32 PM   #1942
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
X2 i what fronts?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 07-12-2011, 05:14 PM   #1943
WISH ONE
Thanks guys!
b-magic fenders, the vents have been shaved.
Old 07-12-2011, 05:39 PM   #1944
Skilz10179
Skilz10179 is an unknown quantity at this point
18x9.5 +10 245/35
18x11 +25 275/35
Stock body, no rivets, and no fiberglass panels...
Crap cel phone pic!
Skilz10179 is offline   Reply With Quote
Old 07-12-2011, 05:46 PM   #1945
Flicktitty
Flicktitty's Avatar
don't know if the rears are quite "MAX TIRE" judging by the stretch. clean car though.
Old 07-12-2011, 05:58 PM   #1946
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
While I slightly agree, I would think it's "max tire" for the given car/body, not given wheel width. Mine is slightly stretched at a 285 on an 11", but it's a god damn tucked 285 on a stock bodied(pull) S13... thereby making it a MAX tire on said vehicle. With all of that being said, a 275 is not that max on an S14.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 07-13-2011, 04:30 AM   #1947
Skilz10179
I agree for the most part but more than 50% of this thread is cars running 255-275's out back so i thought i could share my set up here too. It's funny, i didn't hear shit when i shared my old set up here which was the exact same width tires and smaller rims lol.
Old 07-14-2011, 09:55 AM   #1948
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Just because I saw this thread still alive while looking for wheels for my fiance's car.......
Trying to figure out how to make this work:
18x12 CCW (6.75" backspace)
315/30R18 Hoosier A6
Up front:
Might need to build up some new front fenders...
AceInHole is offline   Reply With Quote
Old 07-14-2011, 10:48 AM   #1949
SicBastard
SicBastard's Avatar
PJ, Hope you don't mind but I've got a ton of questions for ya:
-What's your ground clearance to the lowest part of the powerbrace?
-How much compression travel do you think you have at the current ride height?
-How much strut clearance do you have with then18x12 and 6.75" backspace in front? I pressume you're running at least a 0.5" spacer?
Thanx a million! I've got to get out to the Meadowlands to watch the Panda some day!
Old 07-14-2011, 11:16 AM   #1950
Flicktitty
Flicktitty's Avatar
ok, this is may be a goofy question. but i came across some wheels today i really like and am considering buying them.
they are 16x13 with a 5 7/8 backspace so + 24 (correct?)
if i got 50mm rear over fenders on a S13 coupe, i SHOULD be able to fit these on with a 315 tire correct?
