03-14-2016, 03:47 PM | #19381 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
fat 02 sensor wont work on a redtop... ECU wont understand it as it reads differently; go get a skinny 02 sensor so it functions properly.
03-14-2016, 04:01 PM | #19383 |
Hey guys im doing a brake swap on my 240sx coupe, i just bought a tt z32 e-brake set up and z32 26mm brakes and rotors and lines, i was wondering if it work with my 4-lug or i have to get the 5-lugs or what else do i need?
Thanks in advance |
03-14-2016, 04:41 PM | #19385 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
have the front Z32 rotors turned and then redrill the lug pattern into them, same with the rears. the rear drum assembly doesnt rely on the lug pattern since it bolts to the hub and doesnt slide on over the studs.
03-14-2016, 05:20 PM | #19386 |
Have a weird no crank no start problem. Things I replaced are the Ignition Switch, Battery, and Starter. I also bypassed the clutch safety switch to rule that out. Car still doesn't crank nor start, I hear clicking from a relay under the driver dash, but no clicking to the starter solenoid otherwise no other noise. Dash lights and headlights all work fine and can be turned on as well as all accessories. Anything else I could have missed? Grounds were all refitted and cleaned and checked as well. There was one ground wire that was weird though on the engine block near the exhaust manifold it had a plug ground which was unplugged, but I could not find anything to plug it into to. If it helps I found out my ENG CONT fuse was blown and replaced it, but it didn't seem to do anything.
03-14-2016, 05:44 PM | #19387 |
03-14-2016, 05:49 PM | #19388 | |
03-15-2016, 12:10 PM | #19390 | |
If you type 240sx rack and pinion into an eBay search there a bunch of reman ones for pretty cheap on eBay. They just require a core or whatever. Other people will probably mention rock auto or whatever, but I haven't used them so I dunno Sent from my iPhone using Tapatalk |
03-15-2016, 12:19 PM | #19391 | |
03-15-2016, 12:21 PM | #19392 |
Does anyone know of like a more liquidy form of body filler than bondo? Reason I ask, is that I recently body fillered my tubs, and it kept drying like super fast so it is kinda rough with small little divots . I already sanded it and I don't think sanding more would help. It was also my first time body fillering something. Kinda would rather not have to go back, and sand it off.
Is there anything that is kinda like a thick paint that I can use to smooth it all out? Sent from my iPhone using Tapatalk |
03-15-2016, 12:25 PM | #19393 | |
Damn I said they were cheap, but I didn't really check the s14 ones. The one I have on my watch list is for an ae86 so I just sorta assumed they would be similar in price. Maybe someone else knows of a sight that sells racks, I thought I saw someone list a link a while back in this thread that had them for sub $200 but I don't remember what it was Sent from my iPhone using Tapatalk |
03-15-2016, 02:15 PM | #19394 |
I know the S14 brake MC looks different. But is there a definitive way to determine whether I have an S13 or Z32 brake MC?
'S13 brake MC' in google image seems to only bring up Z32 ones. |
03-15-2016, 02:29 PM | #19395 |
Size. Should be a stamp on the side somewhere. S13 is 7/8" if I recall, Z32 would be 1" or 1-1/16"
03-15-2016, 02:32 PM | #19396 | |
03-15-2016, 02:37 PM | #19397 | |
Cool, thanks man Sent from my iPhone using Tapatalk |
03-16-2016, 05:29 AM | #19398 |
Before you run the glazing putty, wet sand your bondo with 400 grit then 800 grit. The glazing putty fills in the pin holes well, but you need a softer, more flexible blade with it, like a tint blade or what you would use for vinyl decals.
Glazing putty is also what you use to fill in the pinholes on your regular paint as well when you wet sand down to a hard scuff. Schooled by King's Customs, Clarksville, TN. Thanks Jimmy, Ron, and Houston
03-16-2016, 09:53 AM | #19399 |
sorry if this has been covered BUT what is this part called and were can I get one.
here the formula: +10 (-5) .. EX: 205/55 becomes 215/50 |
03-16-2016, 10:06 AM | #19400 | |
could also be called breather elbow. I searched oriellys and they dont have it |
03-16-2016, 09:07 PM | #19401 |
Hey guys, so excuse my not having any wiring knowledge, but I need some help. Wiring is very intimidating to me, i couldnt even wire up my stereo lol, or Couldnt when I had tried a few months back probably can now. Anyway. I rebuilt my KA's top end three everything back together and it won't start' how fun. It gets fuel(sometime), and spark(sometimes) it cuts out, i messed around with the ECU and i get fuel and spark at certain angles. Sooooo what do I do? Is it grounding out maybe? I don't know how to do this at all haha
03-17-2016, 11:40 AM | #19402 |
a 1992 Pathfinder and 1995 Maxima popped up at my local U-pull yard. I want to get a consult port. Anything else that could be usefull in my 1992 240sx? The fuel pump hanger maybe?
03-17-2016, 12:06 PM | #19403 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
control arms (ALL OF THEM) subframe spacers strut bars sway bars bushings (ALL OF THEM) SR20det GT30R turbo Power FC DJetro recaro seats 17x9 +35 wheels all around with meaty tires (non of that stretch BS) body and paint work interior restoration walbro fuel pump aeromotive FPR bigger injectors FMIC kit thats a good start right there |
03-17-2016, 12:08 PM | #19404 | |
The fuel pump hanger on the pathfinder looks identical from the top but I don't know if it's actually the same depth. |
03-17-2016, 12:12 PM | #19405 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
you already have a consult port in your car, its in the lower kick panel on the drivers side... ALL S13s came with them, even zenkis. |
03-17-2016, 01:31 PM | #19406 | |
03-17-2016, 01:40 PM | #19407 |
How much was it if you don't give them your core?
03-17-2016, 01:57 PM | #19408 | |
I can only assume the shit it's pact with is a mixture of dirt, road salts and fabric adhesive it gathered while it way laying on the floor. Last thing I want is continuity issues while flashing ROMs so if I can get my hands on a nice one I'll do that. |
03-17-2016, 02:15 PM | #19410 |
So without the core, you would have to pay $376 for their rack?
