Old 03-02-2011, 01:34 PM   #1861
ke70 sr20det
ke70 sr20det is an unknown quantity at this point
420 on gt2871.86 nyce numbers ..when do u get full boost on .86
ke70 corolla sr20det redtop t28 s15 7 psi stock motor
ke70 sr20det is offline   Reply With Quote
Old 03-02-2011, 01:43 PM   #1862
Pantaloons
Pantaloons's Avatar
Pantaloons is an unknown quantity at this point
I hit full boost at about 4600rpm
for that I do with the car it was a bit laggy. in close tandem i found myself falling out of boost alot. 420whp was at 20psi
so now im hoping for about 450whp with the new setup. and only run about 16psi
Facebook
Twitter
Pantaloons is offline   Reply With Quote
Old 03-02-2011, 02:48 PM   #1863
ke70 sr20det
hmmm that is sure laggy for some reason codys setup its fun but imma kinda drag guy so still if i copy setup ill throw at least 50~75 wet nos for more power on t2
Old 03-02-2011, 03:47 PM   #1864
tabasco122
tabasco122 is an unknown quantity at this point
Is anyone using water/meth injection with this setup?
tabasco122 is offline   Reply With Quote
Old 03-02-2011, 04:40 PM   #1865
Pantaloons
Pantaloons's Avatar
I am it cools down intake temps alot
Facebook
Twitter
Old 03-02-2011, 04:52 PM   #1866
tabasco122
debating on doing the 76 instead of the 71 is there any reason more people dont choose that one?
Old 03-03-2011, 04:22 AM   #1867
TFD
TFD is an unknown quantity at this point
@Pantallons: Whats your setup? Great #'s.
JDMstyle-Driftstyle-Dish-Stickerbomb-Stretch-Bye Bye Kitty...
TFD is offline   Reply With Quote
Old 03-03-2011, 09:16 AM   #1868
Pantaloons
Pantaloons's Avatar
freddy intake ported
70mm tb
blending in the head
hks 264 cams
dc sports manifold
tial 38mm wastegate
split fire coils
power fc 740cc injectors
gt2871r .86
everything else is stock
here is a little right up and video from the tuning session
Round VI – Comin’ Hard | U2NDyno.com
Facebook
Twitter
Old 03-03-2011, 12:46 PM   #1869
drag113
drag113's Avatar
drag113 is an unknown quantity at this point
Pantaloons didnt you say you were running meth as well?
Nice numbers nontheless! My setup is similar to yours with the exception of a few things
drag113 is offline   Reply With Quote
Old 03-03-2011, 01:39 PM   #1870
Pantaloons
Pantaloons's Avatar
yes i am running meth. not for the octane tho but for cooling
Facebook
Twitter
Old 03-03-2011, 03:21 PM   #1871
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
This has been the overwhelming issue with that .86 housing...it just reacts that 'little bit' slower that it really plays out huge in the real world aspectof things.
Either way you've got a very good setup. As I've been preaching forever, it's amazing at the power these things are capable of, yet so many fail at achieving when running half assed or super cheap setups.
Good cams, nice tune, solid setup will always work.
.86 housing? = upper midrange/top end
Intakake Manifold = upper midrange/top end
HKS 264's? = upper midrange/top end
Amazing at how so many people don't build their setup with all of their mods in mind, and end up screwing it up.
I assume going to race gas and adding more timing...
I know on street I see 20 psi in the 3650/3900 range. I wish the dyno I used was friendlier to turbo cars, but it is what it is.
I am, but much like Pantaloons, only for the detonation resistance, not for the power.
Peak power is ultimatly the same and response is worse. In the grand scheme of things I look at it this way
Garrett Turbo Land
300 hp = t28
400 hp bottom mount= gt2871
400 hp top mount = t3/t4 (.63 hotside, 50 trim compressor works well)
500 hp = gt35r
To me, a 3071/76 may get you to 450-475 whp, but so will a 35r...and they both respond the same..laggy. If you can deal with lag, you may as well deal with it and go 35r and make real power haha.
Good stuff. Not that it makes any difference but you're my new best Zilvia friend haha. So many people skip and wonder why it doesn't make the right power...
Old 03-03-2011, 04:14 PM   #1872
tabasco122
Yeah, well with louisiana weather I figure I may need it.
Old 03-03-2011, 04:22 PM   #1873
codyace
codyace's Avatar
Trader Rating: (58)
Oh for sure! It's a great tool to help reduce knock. Having been in LA Humidity it will be a good mod!
Old 03-03-2011, 05:01 PM   #1874
tabasco122
Its brutal. I skipped one when I was living in new jersey, and my first one back was hell.
Old 03-03-2011, 07:47 PM   #1875
u_contempt
u_contempt is on the path to ruinu_contempt is on the path to ruin
@Pantallons:
wow, nice numbers! i'm running the gt2871r .86a/r with Power FC and 740cc as well. but i have a fully built bottom end and head... i would love to hit that hp! here's hoping when i dyno that i make what you made!
just curious though i've only run up to 18psi but i seemed to hit full boost before 4000rpm. i have s14 motor with 264/264 cams with vtc didn't know if you had s13 motor.
u_contempt is offline   Reply With Quote
Old 03-03-2011, 08:42 PM   #1876
Pantaloons
Pantaloons's Avatar
that and run higher compression going to 10.5:1
Facebook
Twitter
Old 03-03-2011, 08:44 PM   #1877
Pantaloons
Pantaloons's Avatar
Originally Posted by u_contempt View Post
@Pantallons:
i have a s13 sr20. my motor only made 385whp before i did some head work. it helps alot.
plus i really have no idea when i hit full boost. i was just going by the dyno graph...
Facebook
Twitter
Old 03-03-2011, 08:51 PM   #1878
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Originally Posted by Seraphim38 View Post
I have to admit that reading this thread made me think that I should see a 300rwhp number from my 2871r setup, but noting that it was only boosting to 13psi since I didn't want risk blowing my stock head gasket, I figured my 254rwhp number would be worth posting up.
Is there anyone who thinks that there's something wrong with my setup and results as posted?
What???? What other mods do you have?
Im on 7psi with a T25 making 234/240. Realistically 225whp 230wtq, had a spike in power for no reason that sent the graph to 234. I could make your same numbers on 1 Bar, just a shittier power band :P
Stock top end
Wiseco .040 over pistons
Eagle rods
APex HG-for the life of me cant remember the thickness but it bumped my compression a bit
GReddy RSPL FMIC
3" turbo back exhaust, hi flow cat, no resonator
PFC D-Jetro
Got a boat load of parts waiting to be put in right now. AVCR, ISIS intake manifold, 550cc Inj, 256/256 cams, springs retainers, stuff of the sort. Just missing a 2871 .64.
I gotta break 300whp on this T25 lol
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 03-03-2011, 10:00 PM   #1879
codyace
codyace's Avatar
Trader Rating: (58)
I dunno, a summer in NJ is just as bad...maybe not as humid though
Nice man, that should get the turbo spinning fast!
You will never EVER see it.
Old 03-03-2011, 10:09 PM   #1880
Pantaloons
Pantaloons's Avatar
put it this way... meth rules
and saves motors
Facebook
Twitter
Old 03-03-2011, 10:31 PM   #1881
EsChassisLove
Trader Rating: (26)
^It's wonderful stuff.
I would on meth/water lol
Old 03-03-2011, 10:41 PM   #1882
HiImBrandon
HiImBrandon is an unknown quantity at this point
I want a gt2871r, but no one has one up for sale :/
HiImBrandon is offline   Reply With Quote
Old 03-04-2011, 03:12 AM   #1883
TFD
@U Contempt: keep in mind the S13 engine is highport while S14 is lowport... getting the head "done" may have more effect on the s13 as on the s14 engine??
Gonna keep the intake stoc to see the vct effect on my setup. If not ok, then get a freddy or so.
Old 03-04-2011, 07:23 AM   #1884
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
and saves motors
WHat meth setup are you using?
Anyone here use meth for drifting?
BiG MiKE86 is offline   Reply With Quote
Old 03-04-2011, 08:05 AM   #1885
codyace
codyace's Avatar
Trader Rating: (58)
300 whp
on a stock T25
is not possible
I don't care what you run at it. I'll paypal you 2 dollars if you post up results. If I don't, then you can post this in every thread I ever post in.
Old 03-04-2011, 08:21 AM   #1886
tabasco122
Engines are basically air pumps. more air an engine can move (and adequately provide fuel for) the more power it makes. That turbo cannot flow enough air to hit that power goal. the only way possible would be to build the car for a huge shot of nitrous (which is like liquid air).
Old 03-04-2011, 08:54 AM   #1887
codyace
codyace's Avatar
Trader Rating: (58)
So anywho, It will be interesting to see the differences in powerband with the 70mm TB and the better sparkoutput...I still think one of the weak links is are the low spark energy...we'll see!
Old 03-04-2011, 11:01 AM   #1888
u_contempt
[QUOTE=TFD;3910843]@U Contempt: keep in mind the S13 engine is highport while S14 is lowport... getting the head "done" may have more effect on the s13 as on the s14 engine??
yeah, i understand the differences in their porting. i was just curious if to maybe the reason to my faster spool was the vtc. because with my 52trim gt2871r .86a/r that i have i start getting positive boost pressure at around 2000rpm and it's full boost around mid 3000rpm's. i'm sure it's more than just that though. i have higher compression pistons over stock... but not by much though. and a slight over bore on the motor, which i am sure helps! ha
personally, i love this turbo and my setup. putting coilovers, new bushing suspension pieces and Z brakes on it here in the spring. and then i'm hopefully going to do dyno your power numbers!
Old 03-04-2011, 01:21 PM   #1889
Pantaloons
Pantaloons's Avatar
aem meth kit with actually water/ meth used... not washer fluid like all the cheap kids
and i use it for drifting
Facebook
Twitter
Old 03-04-2011, 01:51 PM   #1890
EsChassisLove
Trader Rating: (26)
Trust me I'm not actually going to try for that much on a T25. I don't want a power band that shoots straight up then straight down after it peaks lol.
I just discovered two broken studs on my turbo anyways so a 2871 is happening now.
