#1861 |
![]() Join Date: Feb 2010
![]() Feedback Score: 15 reviews
^^ wrong thread, max tire on x10 were looking 265+ if its a truck you better be running 305+
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3 |
#1862 | |
![]() Quote:
What he said. ^ I have the anniversary 350z wheels and they're 18x8, 18x8.5. I have 225f and 245 rear. The tires look a little stretched. I think I'll run the 245's up front next time and go with 265's rear. |
#1863 |
![]() Join Date: Jun 2007
18x9 +24 265/35/18 f , 18x10 +22 285/30/18 r , soon to be 285/35 rear. stock fenders all around. i want 30mm overfenders for the rear.
TEAM NO PULLOUT !!! |
#1865 |
Finally some proper Max!
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#1866 |
![]() Join Date: Jun 2005
255/40/17x9 +15 30mm fender
315/35/17x10 +4 30mm fender ![]() Photo by dijitil Flickr: dijitil's Photostream
INTENSE POWER RIPPED ME OFF |
#1869 |
is that a t25 housing hanging from your towhook?
I don't quite qualify for this thread. ![]()
#1870 |
It's actually a GT15 off my diesel Jetta. I'm kind of surprised nobody has stolen it yet.
Edit: Those Hoosiers are going on my other car. 28x13.5-15 with a 15x10 +13 wheel. Yes, They're going to be flush and tucked.
INTENSE POWER RIPPED ME OFF Last edited by godzillarb; 05-03-2011 at 04:16 PM.. |
#1871 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Bad photos, but I finally put 255s on the front of my car after two or three years of 235/255 stagger. Front wheels are 17x9 +22, rear are 17x9.5 +38, but I have s14 subframe installed so it's +33 effectively. I would buy four 17x9.5 +38 wheels if I were to do it over again, and then run 10mm spacer in front. I still may...
![]() ![]() Now running 255/40/17 rs3s all around. Might need some more fender modification to clear, but not 100% sure yet. |
#1872 |
GodZillaRB, this is the first time other then last night that I've gotten to see the car with paint, well fucking done champ.
http://garagemakeshift.blogspot.com/ |
#1873 |
![]() Join Date: Nov 2005
Godzilla, congrats on having wide tires that fit.
I'm tired of seeing cars that look like they're about to go off roading in this thread.
#1874 |
Thanks. I'd be running some 17x12s in the back if I had the money... maybe someday. Wide tires + proper fitment = pure awesomeness.
#1876 |
The 15x10 +13 wheels I ordered two weeks ago still haven't shown up yet... so I'm not sure what I'll be running. I'm going to see if the Z32 brakes fit, if not, I'll just have to figure something else out. There is so many other things to do on the build that brakes are the last thing I'm worried about.
#1877 |
Trader Rating: (24)
For sure, I was just curious as I've been thinking about running 15s just to run hoosier a6s in 275/35/15, but wasn't sure if there was a 15" wheel that would clear z32s.
#1878 |
![]() Join Date: Jun 2003
Not all will, but they do fit under some 15s. It's not the diameter that's a problem, it's the spokes. Some S13 SE wheels fit over the 26mm calipers.
#1879 |
Trader Rating: (24)
I know I know, but when you venture into 15x9 and 15x10 land, the wheel faces are usually all wrong.
Just curious to see what might actually work. |
#1880 |
True, they're usually made for trucks (though tacomas had big brakes I think, that might be worth searching with) but custom 15x10s are easy to get from spinwerks and others and SWs aren't terribly expensive. I'll be ordering a set here in a week or two.
#1885 |
![]() Join Date: Apr 2007
Hey guy's just checking to see your thoughts.
S13 Coupe. Coilovers. aftermarket links. 17x9 +35 275/40/17 (REAR) stock body (rolled fenders, can pull if needbe) looking to go with 0 or as close to stock camber as possible for most contact patch. Whats your thoughts. i think they SHOULD work.
#1887 |
yeah , thanks. this is with slightly better pix and all settled and the wheels painted (not like it matters) but i'm really happy with the way the car feels and drives, hopefully when my rb swap is done i can put them to better use, i really like the front settup, it feels very secure.
#1889 | |
![]() Join Date: Aug 2006
315mm on a 10" wheel is pushing it isn't it? Do you think I could safely fit them on a 9.75" wheel or is that pretty much going too far?
Silvia, built 5.3 turbo, 4l80e, 9.8@142 |
#1890 | |
