Old 06-09-2010, 07:15 PM   #1861
keeeban
keeeban's Avatar
Trader Rating: (22)
keeeban is an unknown quantity at this point
Feedback Score: 22 reviews
Hey guys, I have a question about manual shifter assemblys.
I'm looking into buying a short shifter instead of having the OEM shifter since I can't seem to find anyone selling one (or I'm just too slow at offering). My question is, if the shifter comes pre-assembled, that would be all I need, correct? Other than the 5-Speed shifter trim and leather boot, I would need to buy this still right?
keeeban is offline   Reply With Quote
Old 06-09-2010, 07:50 PM   #1862
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
I have only experience with B&M short shifter and it comes fully assembled. Which means removing the 6 bolts on the plate of the shifter, remove stock shifter and place in B&M shifter. Put back 6 bolts.
From what you said you need ...yes. BUT there is also metal ring that goes over that rubber boot you have pictured, to hold it in place.
Maiku240sxS14 is offline   Reply With Quote
Old 06-09-2010, 07:52 PM   #1863
keeeban
keeeban's Avatar
Trader Rating: (22)
Alrighty, thanks for the quick reply!
Old 06-10-2010, 06:29 AM   #1864
sirfallsalot243
sirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enough
keeeban, I have two stock shifters sitting on a shelf in my garage if youd rather. Ill sell one cheap.
sirfallsalot243 is offline   Reply With Quote
Old 06-10-2010, 06:41 AM   #1865
axiomatik
axiomatik's Avatar
Originally Posted by 240cracker View Post
i had this problem with my old s14 and 2 s13s
i had the hole starter rebuilt before and still same problem which is why im looking at other options. ill check out the link though thx
If it's a very quiet clicking (not the starter solenoid), it might be the clutch interlock relay. I had an issue once where the contacts on the relay got dirty, so the relay was energizing, but the contacts were too dirty to make the circuit. Broke open the relay, cleaned the contacts, and it started up no problem.
Originally Posted by 240Z28 View Post
something i was thinkin of that i havent seen anyone do yet.. i want to build a ka24det stroker motor.. my ?.. is there anything wrong with building a turbo stroker motor?
You will have issues if your compression ratio is too high. unless you space the head or something, making it a stroker will raise the compression ratio, possibly too high for turbo.
Old 06-10-2010, 06:55 AM   #1866
sirfallsalot243
Right, but when building a stroker motor, compression ratio should be one of the first things to consider when buying parts. Theres nothing wrong with stroker motors that make them unable to take boost, you just have to be careful of your compression ratio- just like any other motor.
Do they have "compression ratio calculators" for the KA/SR? I remember back in my Honda fanboy days we could calculate our compression ratio just by plugging in what parts we were using (and what machine work being done).
Old 06-10-2010, 10:30 AM   #1867
TheRealSy90
TheRealSy90's Avatar
I think my question got lost on the last page...
I bought the Greddy Baffled Oil Pan for my sr20det RedTop, but it did not include the hardware for installation, the baffles are already installed. What bolts do I need to buy to install this pan? I'm not sure if any of the factory ones will work since the clamping area is thicker than the stock metal pan. Plus there are the four bolts that definitely need to be longer since they go through the middle of the pan. Thanks for the help!
Such a good signature.
Old 06-10-2010, 11:39 AM   #1868
DDB240sx
DDB240sx is an unknown quantity at this point
I apologize once again if this has already been asked. But with the sr20det redtop motors, are replacement thermostats specific for that motor or are they the same as the 91 to 93 Sentra SE-Rm thermostats? Thanks in advance.
DDB240sx is offline   Reply With Quote
Old 06-10-2010, 02:11 PM   #1869
sdterrible1
sdterrible1's Avatar
sdterrible1 is an unknown quantity at this point
So, i need some help. I took apart my E-brake lever and i cant get it back together.
The rod/button that u push to release the ebrake is out of the lever and i cant figure out how to get it back in? Dose anyone have an exploded diagram or anything?
oh and its on a kouki s14
sdterrible1 is offline   Reply With Quote
Old 06-10-2010, 03:36 PM   #1870
Deviance
Deviance's Avatar
Deviance is an unknown quantity at this point
is this a real nardi wheel never seen blue Stitching with Blue logo on a nardi wheel?
Deviance is offline   Reply With Quote
Old 06-10-2010, 04:37 PM   #1871
MandTPhotography
MandTPhotography is an unknown quantity at this point
Same as the Sentra SE-R.
MandTPhotography is offline   Reply With Quote
Old 06-11-2010, 06:46 PM   #1872
jing
jing's Avatar
jing is an unknown quantity at this point
Are S14 front LCA's longer than S13 LCA's?
jing is offline   Reply With Quote
Old 06-13-2010, 02:07 PM   #1873
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
does anyone know if summitracing gives discount?
or can anyone help me im bout to buy some pipes cost almost $400
killer240 is offline   Reply With Quote
Old 06-13-2010, 02:26 PM   #1874
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
Yes. msglgth
C. Anderson is offline   Reply With Quote
Old 06-13-2010, 03:17 PM   #1875
lflkajfj12123
Yep. You can run them on an s13 with a s14 spindle/hub assembly.
They grant you another degree of camber.
Old 06-13-2010, 04:02 PM   #1876
Drose
Drose is an unknown quantity at this point
I have a quick question. My car is only running on 3 cylinders, number 2 is not firing. There is spark and fuel and my ecu is throwing 34, knock sensor. If the knock sensor was bad would it only cause one cylinder to not fire?
Drose is offline   Reply With Quote
Old 06-13-2010, 04:06 PM   #1877
CrOW
CrOW's Avatar
CrOW is an unknown quantity at this point
95 240sx wing fits on 97 kouki 240sx? all the wings are the same?
CrOW is offline   Reply With Quote
Old 06-13-2010, 04:14 PM   #1878
lflkajfj12123
No.
I would guess the fuel injector is stuck open or closed. Happens to me all the time.
Old 06-13-2010, 04:18 PM   #1879
Tom25666
Tom25666's Avatar
Tom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choices
No.
yep. probably clogged injector
I have 1000 hp. This thread is dumb.
Tom25666 is offline   Reply With Quote
Old 06-13-2010, 04:27 PM   #1880
Drose
Ok thanks the problem went away after is let it sit for a day. Then when I pulled out of my neighborhood it started again. Does that sound right?
Old 06-13-2010, 04:54 PM   #1881
Wake
Wake's Avatar
thats what happened when my ECU got wet.
try fuel injector cleaner. Lucas works pretty tits.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 06-13-2010, 04:57 PM   #1882
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
What are the bulbs that go in the JDM front bumpers turn signals (ambers) on a s14? (the blinkers)
i bought the ones sylvana or w/e told me, but like a noob i forgot it was for usdm.
they are a push in type, not twist.
RIGHTWHEELDRIVE.com
Drifting-pedobear is offline   Reply With Quote
Old 06-13-2010, 05:01 PM   #1883
raz0rbladez909
raz0rbladez909's Avatar
Will powdercoating effect/weaken the strength of my fn01rc's?
2004 Corvette Z06 / 1971 240z
raz0rbladez909 is offline   Reply With Quote
Old 06-13-2010, 05:11 PM   #1884
Drifting-pedobear
NO.
i think you are mistaking that with the chroming process. it will not weaken them.
RIGHTWHEELDRIVE.com
Old 06-13-2010, 05:58 PM   #1885
raz0rbladez909
Originally Posted by Drifting-pedobear View Post
NO.
Are you sure on this? I've heard of enkei voiding wheel warranties for powdercoating, which is why i'm asking. Do you have a reliable source of information?
Old 06-13-2010, 06:43 PM   #1886
Drose
ok so i just put a new injector in and hooked everything back up. Now the car will crank over and it sounds like the starter is making a loud bang noise on the flywheel. Any ideas??
Old 06-13-2010, 08:08 PM   #1887
Phat_Ass 14
Phat_Ass 14 is an unknown quantity at this point
s14 power fc pro & sfc
hi,.im new here. next week i am going to buy my buddy's power fc pro complete with z32maf + 660cc inj.but no handset .the thing is we dont have any qualified tuner near around my place.. btw our setups are abit similar,.since we dont have any tuner yet.can i just try to fine-tune it by using a sfc??? helpp mee..any idea ? my ride is a s14zenki..
Phat_Ass 14 is offline   Reply With Quote
Old 06-13-2010, 10:07 PM   #1888
Nizmo_max
Nizmo_max's Avatar
Nizmo_max is an unknown quantity at this point
took out the dash..and the metal bar that runs under the dash too both driver and pass. side...unplugged the air connectors..went back and put everything back including air bag connecters..and now my s14 is flashing the air bag sensor light on the cluster...what do i do to remove that? what i was thinking is reset my ecu? i did unplug the battery when doing this soo...i dont know whats going on here...dont really want to remove dash agian..or does anyone one how many of the airbag sensor are there and the location i mean..i know theres one under the pass. side dash.. and the steering wheel..is there another one that i forgot to plus it onto...thanks in advnce
Nizmo_max is offline   Reply With Quote
Old 06-14-2010, 02:51 AM   #1889
Drifting-pedobear
no i dont.
but i just cant see it hurting anything at all: it has nothing to do with the metals structure. all they do is "paint" it with the powder coating... idk. maybe im wrong.
RIGHTWHEELDRIVE.com
Old 06-14-2010, 03:21 AM   #1890
badicalradical
badicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of light
NO.
no i dont.
I'm quoting on this and I don't entirely agree, but there are numerous articles, none entirely conclusive except for experiences. Go on s2ki.com I believe and they had a huge discussion. Apparently there have been a large number of quality forged wheels (supposedly, including volk, ect...) that have cracked on track after powder coating. Such wheel's warranties have been voided due to such factors. We all know companies will view this as modification and thus void their warranty, but why is it more common on the powder coated ones. Now I don't entirely buy it because of obviously reasons but at the same point a FN01R-C is a cast wheel and vulnerable to possible heat used by the powder coating process. Also I think wheels crack due to something the driver did (if they're a good wheel) and not due to powder coating or what such. Just stating what I've read.
badicalradical is offline   Reply With Quote
