06-28-2015, 08:42 PM | #18391 |
Hey all!!!! So I recently got my hands on a Tomei SR M7960 for 500 only catch is it has some wobble to it and needs a rebuild. All I can find from Tomei is a gasket and line set and various other parts but no bearing kits. I would like to avoid buying a chra SO HERE IT IS:
Can I rebuild a Tomei turbo using a kit like this- http://turbolabofamerica.com/mhi-14b...o-rebuild-kit/ Anyone with experience or who knows someone with experience, preferably no "hear-say" Thank you 😁 |
06-28-2015, 11:31 PM | #18392 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
06-29-2015, 01:15 AM | #18393 |
for s13 guys running wider wheels up front, what do you guys do for more clearance without tubbing? i rub on the stock tubs when taking turns to aggressively and on full lock.
Instagram:@juhd_ |
06-29-2015, 09:30 AM | #18397 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
well ill be buggered. i guess it is a journal bearing turbo... sorry about that. MOST turbo upgrades from bigger Japanese names tend to be ball bearing and not journal bearing. instead of guessing on an ebay kit... call Tomei directly and ask them about a rebuild or rebuild kit.
06-30-2015, 01:05 AM | #18402 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
really old ones... MOST japanese manufacturers incorporated adjustable lower mounts in the mid 2000s, those were most likely made late 90s/early 2000s.
06-30-2015, 11:33 AM | #18404 | |
I might just save up for some newer ones.
06-30-2015, 02:00 PM | #18405 |
anyone know how to get the gas door open on a s13 without prying it open with a screwdriver? I push the tab down to open it but no luck. probably bad or no cable. if not, can I open it from the trunk or anything?
06-30-2015, 02:05 PM | #18406 |
Follow the trunk/gas door cable to the rear and there should be a lever you can maually move that will pop the gas door.
06-30-2015, 05:16 PM | #18408 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
that means your cable bracket snapped at the lever next to the seat. you will need to take your seat out, pull the carpet up and rebuild the plastic bracket that gives the cable tension. it takes about 20-30 minutes with some super glue and patience. ive had to do this on every s13 ive ever owned thru the last 14 years. make sure to be careful pulling all the plastic bits off.. KEEP THEM!! put them back together with a light coat of superglue, then once dry, start layering coats of super glue over the original tension bracket that you just rebuilt. takes about 6-7 thicker coats when completed, but it will never break again after that.
06-30-2015, 06:16 PM | #18409 |
Trader Rating: (18)
Feedback Score: 18 reviews
Vacuum line question... S13SR
I have the wiring specialties kit, so no boost solenoid or EAI controller or charcoal can. First I have the wastegate hooked up right off my cold pipe (smic) is this ok? http://i.imgur.com/zPygjSCl.jpg Second, I have two extra lines on the throttle body I looped together, are there any potential issues with this? Car seems to idle abit higher like this: http://i.imgur.com/jT0KO6Ml.jpg I ran the BOV and boost gauge off a vacuum block on the brake booster. |
06-30-2015, 08:14 PM | #18410 |
Trader Rating: (33)
Feedback Score: 33 reviews
The upper right nipple goes to the bov. The bottom nipple can be capped off or used for a wastegate source since it only sees boost if you didn't have one on your cold pipe.
07-01-2015, 01:09 PM | #18415 |
Trader Rating: (24)
Feedback Score: 24 reviews
How do you figure out which bmc size to run?
I'm running ctsv front 4 pot calipers and Z32 rears. I read either use 1" or 11/16".
REVIEW |
07-01-2015, 01:25 PM | #18416 |
Trader Rating: (18)
From what I have read its based on the number of pistons and volume of fluid to be moved. Those CTSV brakes are pretty big I would consider 1", but pedal may be stiff with a larger BMC
07-01-2015, 01:54 PM | #18417 |
Trader Rating: (24)
I'd say 17/16.
Also, everyone should read this (or have read this): http://www.freshalloy.com/showthread...kes-(VERY-LONG) |
07-01-2015, 07:02 PM | #18418 |
Do you need to use copper gaskets for your turbo lines if using JGS precisions an fittings? I've heard people use nothing and just tighten it up since they are an compression fittings but I've also heard people use liquid sealant. For the turbo to line I just used thread tape should I be fine?
07-01-2015, 10:04 PM | #18419 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Teflon tape is fine for your AN lines. Personally I just tighten mine down. When everything is cranked down properly, you should have zero issues. Most of the time the fitting will go bad before it comes loose.
07-02-2015, 01:48 AM | #18420 |
My steering isn't returning to center. Got an alignment, front toe and caster set to stock specs. Still won't return to center. I can literally take a corner with my hands off the wheel. Scary shit. What could cause this issue? Binding coils? (I hope not, I have new-ish FA 500's.) Clock spring? Evil curses?
