#1801 | |
Honestly the best way to go especially with the VTC motors is leave the IM stock go with a 264 duration camshaft and a .86 housing GT2871R, kind of get the best of all worlds and with solid tuning with a good EMS we are currently seeing 350-400 whp on PUMP gas down here! finally! granted these are all Haltech cars with the dyno dyanmics tuning... The larger turbine housing really does open up power capability with aggressive cams and some basic head work though... Redtops seem to always make better overall power, but the VTC motors with this turbo are trending better overal torque. Problem is they seem to be less efficent in RPM ranges over 6000 rpms compared to redtops, a lot has to do with the port design, high port vs. low port on the motors
Like Me on FaceBook ![]() |
#1802 |
i've searched and searched but i can't find a 100% answer where i can buy and what lines to get for my T2 .64ar 56 trim GT2871r...? codyace can you shed some light my setup is closely based on yours... or any other knowlegeable GT2871r owner help plz...
#1803 | ||
![]() Join Date: Oct 2004
#1804 | |
![]() Join Date: Mar 2006
Is this as simple as chopping off the current IM flange and welding one on that can bolt up to the Q45 TB? If so, to what extent does the size of the coldpipe matter? IIRC, the Greddy kits have 3 inch (~75-76 mm) coldpipe pieces. The q45 TB is like 82 mm, right? I believe in practice that the throttle body makes a difference, as you have said. However, on the theoretical side, the throttle body is so short relative to the length of the coldpipe, that it seems that the coldpipe provides (nearly) all of the resistance to flow (fluid mechanics). I am interested, however, to see how much of a difference it makes. Clearly it can't HURT! Becasue
Daily driven |
#1805 | |
Is this as simple as chopping off the current IM flange and welding one on that can bolt up to the Q45 TB? If so, to what extent does the size of the coldpipe matter? IIRC, the Greddy kits have 3 inch (~75-76 mm) coldpipe pieces. The q45 TB is like 82 mm, right? I believe in practice that the throttle body makes a difference, as you have said. However, on the theoretical side, the throttle body is so short relative to the length of the coldpipe, that it seems that the coldpipe provides (nearly) all of the resistance to flow (fluid mechanics). I am interested, however, to see how much of a difference it makes. Clearly it can't HURT! Because I am busy now, I will search later, but is the Q45 output voltage versus throttle position the same as an SR TB? Any electronic/signal modifications required for that?
Daily driven |
#1807 | |
![]() Join Date: Dec 2009
First fix the idle (lean) / bogging problem with the DW injectors. Lag time seems to be the problem. Swap injectors to Nismo's or get Nistune instead of JWT ecu? I think Nistune...
#1809 | |||||
![]() Join Date: Dec 2004
Trader Rating: (58)
It would be intresting to compare a .86 housing car and some big boy cams, JWT C1's maybe and some bigger RPM (9000 would be nice huh)...Although I think we'd fight two things: The turbo can't support power up there, and the cams would have to much overlap as well (unsure of the HKS overlap in their 264's, may be less and possibly help more) Quote:
#1810 |
I'll dyno my setup in februari and then afterwards get ahold of an F(G)reddy intake and see what gains are made or lost in the powerband.
#1811 | |
Will work best for you. -Ken
#1812 | |
![]() Quote:
![]() The camshafts made the car considerably louder. I love how it lopes at idle. Compression tested 160 across the board. Martin at RS Enthalpy will be tuning it shortly. Stuck with the last tuned map on stock setup and is running like shit around the 2k rpm range. Will update this soon! |
#1813 | |
You should REALLY be able to squeeze out good numbers!
Daily driven |
#1814 |
![]() Join Date: Sep 2005
/\ werd...
i thought martin and i were becoming "friends" because i talked to him so much during my tune...then he just stopped talking to me. kinds sucks because i have lots of questions |
#1815 |
Sunday, January 30, 2011
Here’s the dyno story: Before I replace the head & cams on my SR20DET I figured I would run a baseline dyno on my current configuration. It feels very strong in its current form. I keep the boost controller set at 14 psi because I am running a SR20DET with completely stock internals other than the Greddy rocker arm stoppers. The car is stripped down and is running staggered Enkei RPF1s with 255/40/17 Falken Azenis in the back, but it will spin them up when the boost hits even in 3rd at 70 mph when going straight. I am shopping for 275/40/17 or 315/35/17s right now so that I can get more grip, and can swap 235s on spare rims if I want to go drifting. I attended a dyno day held by some local Volvo owners. The dyno shop has a Mustang Dyno. As part of the event owners were asked to guess their rw corrected hp and I guessed 270rwhp @ 14.0 psi before I found out it was a Mustang Dyno and that it was supposedly running about 30-50rwhp low, so I was told I should expect about 240rwhp. Before me a modified Volvo S60R (turbo 5 cylinder) just barely hit 200rwhp when people were expecting 240-250rwhp, a Lotus Esprit SE hit 253rwhp and a new Shelby GT500 hit 452hp. The owner of the shop strapped it down and ran the first pull. 254rwhp at 6600 RPM, 248lbs of torque at 4700 RPM, at a steady 13.0 psi of boost. He said that SR20s with 2871s typically run 230hp to 240hp on his dyno and that it was a good result, likely because he thought the timing was aggressive. Given that it was running 13 psi on a supposedly conservative dyno relative to the other car’s results on the same dyno and the comments by the dyno owner, I wasn’t disappointed with the results. Drivetrain: s13 JDM black top sr20det motor Garrett GT2871R .64 Megan turbo manifold Apexi racing suction kit for GT2871 & N62 MAf z32 N62 MAF 550 cc injectors in OEM SR20 fuel rail stock FPR Enthalpy tuned ECU Greddy fmic Greddy rs bov hot pipe with Greddy flange Greddy/TRUST Stainless High Flow Turbo Outlet Greddy 3” down pipe 3” Magnaflow spun metallic catalytic converter 3” Invidia exhaust with extra magnaflow 4” round resonator/muffler Greddy racing oil pan Koyo Racing Radiator Twin electric fans Samco blue silicone Radiator hoses Walbro fuel pump new oem water pump stock pulleys newly rebuilt alternator Small light Miata racing battery RPS Max stage 2 clutch B&M shift kit Nismo rubber shift knob KAAZ 1.5 Limited Slip differential On hand waiting to be installed, all new in the box: Red top reworked head with 3 way valve job Greddy valve springs Brian Crower Titanium retainers BC stage 2 264 degree 12.0MM cams HKS top feed fuel rail Aeromotive FPR with Billet Aeroquip push lock 90 degree fittings -6AN fuel line Still need to buy: STI 800cc top feed injectors Maxworks / ARP head stud kit Apexi metal head gastket 86mm x 0.8 Stance billet water neck adapter Stri DSD-SLM II water temp gauge with smoke lens black face white letters Stri DSD-SLM II oil pressure gauge with smoke lens black face white letters single DIN dual gauge panel Bigger rear tires ![]() Dyno video: YouTube - SR20DET w/ GT2971R .64 @ 13psi on Mustang Dyno 254hp ![]() Poor photos taken by my blackberry (dirty car from the rain): ![]() ![]() |
#1816 |
UPDATE!
Martin tuned my car yesterday here in Orlando. Made 394whp/353wtq @ 18 psi on mustang dyno. Car feels incredible. Again this was on: 2871r .82 Tomei 260 procam Isis manifold 740cc injectors Power FC Supporting mods |
#1817 |
I stil don't understand how my s13 sr made 349whp and 381 of torque "I'm running gt2860rs turbo stock cams and head 16psi of boost 600cc injectorrs z33 mad and a tune from martin at enthalpy. I made that 2 months ago on a mustan dyno !
#1821 | |
![]() Join Date: Dec 2005
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
#1823 |
LOL at the FWD comments
I hope his post kind of opens people's eyes to what different dynos read! Most parts producers and even turbo sellers always love to spout whp results that they got from inertia based dynos especially dynojets, but no one wants to try to market HP gains from brake eddy or mustang dynos because the results are soo much lower in comparison, even all things being the same... a lot of shops tune on dyno dynamics now and use dyno jets for the output to present to the client...just a thought.... should be getting my other friend / custy back in to try to hit 400 whp on the dyno dynamics with this turbo soon though ![]()
#1825 | |
![]() Join Date: Jul 2005
If we are comparing two cars on a dynojet roller... then we can tell which one is making +/- (resolutions) ft/lb of torque. Same two cars on different dynos... even two different dynojets... are going to be apples/oranges. I love the dyno for fun and for double check your tune/timing. You can pick out spots that need fine tuning that you might not see on the street even with a datalog and wideband. plus you can check the engine while its making a pass for oddities (expanding couplers, engine movement, rotating components that are not smooth, etc..) A dyno is not the final solution when it comes to tuning it is simply an extra tuning tool |
#1826 | |
Trader Rating: (58)
![]() On top of that, lets also not forget how every dyno loads a turbo car differently...I know on my personal dyno, it's only a 1000 lb roller...it loads all turbo cars like shit, and often never lets bigger turbo cars hit full boost or even spool remotely at the same time. A dyno like Steve's can load a turbo MUCH better, producing better torque values, and faster spool almost everytime. Once the snow/ice/salt melts, I'll be making a point to goto a Dyno Dynamics to go that way. Again it's not a 100% comparison, but being that Steve will never goto a Dynojet, or put up trap speeds ( ![]() ![]() ![]()
#1827 | |
Don't Mustangs usually yield the LOWEST reading amongst the commonly used dynos? Cody's setup put out peak torque around 310 ft-lbs or so (which is what I would expect from a 260 cam and 2871r). 353 ft-lbs seems CRAZY high for a 2871r...........
Daily driven |
#1828 | |
Trader Rating: (58)
Dyno wise, the mustang ones often give more torque, as they can load the turbo better then a Dynojet. 350 does seem a little high for 18psi, but anything is possible!
#1829 | |
#1830 | |
