Old 06-02-2010, 03:22 AM   #1801
lame_s13
lame_s13 is an unknown quantity at this point
Originally Posted by gprb25 View Post
Answered my own question by searching on Stance's website... the top locking nut on an inverted coilover, it's ok to hit it with an impact on low setting.
yea I tried tightening the nut in the rear with no success. Ive tightened the fronts with an impact and it worked great, but theres no way your gonna fit an impact under the rear window so dropping the coil would be necessary. I might give this a try along with lubricating the pillowball mount.
lame_s13 is offline   Reply With Quote
Old 06-02-2010, 11:12 AM   #1802
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
lift car off ground and remove rear wheels. with the spanner wrench, have someone hold the coilover while you (or someone else) torque the top nut. the manual that came with the coilover will tell you the torque setting.
WheelsDirty
Old 06-02-2010, 05:25 PM   #1803
KA24sleeper
KA24sleeper's Avatar
KA24sleeper is an unknown quantity at this point
Going to install fog lights and was going to connect them to the front turn signals power line, but i dont know which wire to cut, is it the green one?
SUSPENSION>Power
KA24sleeper is offline   Reply With Quote
Old 06-03-2010, 01:26 AM   #1804
jspek
jspek is an unknown quantity at this point
Send a message via AIM to jspek
im storing the sr out of my coupe. dont know when ill be using it again. whats the best way to keep it stored?
jspek is offline   Reply With Quote
Old 06-03-2010, 05:52 AM   #1805
t.vo408
t.vo408 is an unknown quantity at this point
Is a test pipe enough to cause the car to smell like fuel in the cabin? Enough so that I get dizzy after driving for 40 minutes?
t.vo408 is offline   Reply With Quote
Old 06-03-2010, 06:16 AM   #1806
s14owner95
s14owner95 is an unknown quantity at this point
Send a message via AIM to s14owner95 Send a message via Yahoo to s14owner95
plug all the holes with rags and then put a tarp over it.. try to keep it indoors if possible.. otherwise, build a cheap box around it and set it outside.. some 2x4's and some plywood would work
straight gas? a test pipe would only pump the car full of exhaust fumes, which is a different smell that gas.. is this an S13? chances are that little gasket around your fuel tank is messed up.. did you change the fiel pump lately?
s14owner95 is offline   Reply With Quote
Old 06-03-2010, 02:00 PM   #1807
t.vo408
This is an s13 coupe, I bought the car so I'm not sure about the fuel pump. But this did not happen until I swapped the sr20det, and TP in. BUT, I am also having problems with the cars idle at operating temperature and start up when warm. I think its running too rich at those moments and bogging out. Would running super rich have an effect like that? Or maybe a leaky injector o ring or something?
Also when I stick my head in the trunk near the fuel pump I do not smell gas, so I don't think its from that.
Old 06-03-2010, 05:53 PM   #1808
Bob_Sagat
Bob_Sagat's Avatar
Bob_Sagat is an unknown quantity at this point
Can I lay dynamat over the factory sound deadener?
Bob_Sagat is offline   Reply With Quote
Old 06-03-2010, 10:34 PM   #1809
DevilZ
DevilZ's Avatar
DevilZ is making a name for him/her selfDevilZ is making a name for him/her self
How many quart of tranny fluid does a 92 300zx manual tranny take?
What kind of brand an weight should I use?
DevilZ is offline   Reply With Quote
Old 06-03-2010, 10:59 PM   #1810
taquatch.
taquatch.'s Avatar
taquatch. is an unknown quantity at this point
shit pic but what size overfenders? 18x12 0 no spacers
taquatch. is offline   Reply With Quote
Old 06-03-2010, 11:34 PM   #1811
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Thanks for the info on how to measure, now can someone please tell me the measurement of the s14 control arm? Just need to know how long it is and where you measured it from so i can match it. Thank you.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 06-03-2010, 11:47 PM   #1812
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
yellow pipe dope....good for NPT fittings in contact with oil?
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
Old 06-03-2010, 11:49 PM   #1813
TurboSE
TurboSE's Avatar
taquatch - not overfenders, it's called "pulled"...there's a ton of info if you search for it.
Old 06-03-2010, 11:51 PM   #1814
TurboSE
TurboSE's Avatar
yup...did it in a truck I used to own...just clean it really good, I scrubbed with Simple Green and never had a problem. If you're not keeping your carpet, it'll look better if you remove the factory stuff.
Old 06-03-2010, 11:57 PM   #1815
t.vo408
Will this coolant temp. sensor work with a s13 blacktop sr20det with an E5 ecu?
Old 06-04-2010, 12:03 AM   #1816
Bob_Sagat
Bob_Sagat's Avatar
I think maybe he's asking what size over fenders to get?? Thats what I gathered. Looks like 30mm's would do the trick if he plans on keeping that much negative camber.
Old 06-04-2010, 12:04 AM   #1817
Bob_Sagat
Bob_Sagat's Avatar
Cool, thanks. I am keeping the carpet, so I didnt really want to deal with the whole dry ice thing if I don't need to.
Old 06-04-2010, 09:03 AM   #1818
TurboSE
TurboSE's Avatar
Now that I read it, I think you're right....I also think 30mm would do it
Old 06-04-2010, 09:36 AM   #1819
TurboSE
TurboSE's Avatar
Summit recommends black RTV.
Old 06-04-2010, 12:49 PM   #1820
MANOlOS14
MANOlOS14's Avatar
MANOlOS14 is an unknown quantity at this point
Ok i have some kyb's struts, dnt know exactly which kind however i know they're the oem setup, a friend is selling me some megan springs for $80. My question is, can i put the lowering springs on my stock kyb's??? heres a pic of the megan springs...
http://www.eracingzone.com/images/T/...Springs-27.jpg
Please help! Thx!
MANOlOS14 is offline   Reply With Quote
Old 06-04-2010, 03:51 PM   #1821
Gnnr
Gnnr's Avatar
Originally Posted by .Smitty. View Post
Does anyone know where the pictures went in the S14 5 speed swap sticky in the FAQ section? I got everything through the auto removal and now I'm onto manual install. I come back from college to find out the pictures are no longer there. Difficult to do without seeing it, personally.. Would appreciate it if someone had saved it all..
Here, got the images back up.
http://zilvia.net/f/tech-talk/325897...ml#post3479406
Gnnr is offline   Reply With Quote
Old 06-04-2010, 05:11 PM   #1822
M11's
M11's's Avatar
M11's is an unknown quantity at this point
with the j30 caliper swap how much closer to the rims do they get over stock.... rim clearance
WELCOME TO THE SHITTY WOK
M11's is offline   Reply With Quote
Old 06-05-2010, 12:06 AM   #1823
Sato Tatsuya
Sato Tatsuya is an unknown quantity at this point
Hey guys, I need help locating this hood...I have been searching for a long time now, and I still can't figure out which company make this hood. I've tried Dmax, Uras, Origin, among many other popular/famous companies, and none of them are the right ones. So I'm kinda desperate now and any sort of help is greatly appreciated.
Thanks!
The hood that is hanging on the wall in the background is the one I am trying to look for.
Sato Tatsuya is offline   Reply With Quote
Old 06-05-2010, 03:55 PM   #1824
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
Small Questions Thread (Use this insted of making NEW threads)
Thanks!
That is the most common hood in the world!!!
Check out :
VIS
DMAX
URAS
Etc. Ebay
All the same thing
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 06-05-2010, 04:38 PM   #1825
Sato Tatsuya
Check out :
VIS
DMAX
URAS
Etc. Ebay
All the same thing
Hmmm, like I said, though, I've checked all those out before, and they are definitely not the same. If you are to compare the dimensions, and the way the vents are designed, it LOOKS the same, but it's really not that similar. Hmmm, I guess no luck here too.
Thanks anyways though!
Old 06-05-2010, 05:35 PM   #1826
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
why cant there be a S13.5 or S14.5 thread?
okay.. just for 180sx, S14, blah blah blah
killer240 is offline   Reply With Quote
Old 06-05-2010, 08:05 PM   #1827
dalers08
dalers08 is an unknown quantity at this point
Im in need of a brake booster for my 1990 240 hatch sohc. It was an auto until a few days ago when I did a 5 speed swap, now after the swap it seems the booster went bad. Now my question is...
Are the s13 brake boosters the same for 5 speed or auto? Are s13 brake boosters the same as s14? What other cars use the same brake booster, so if I go to the junkyard Ill be able to look at other cars.
Thanks
dalers08 is offline   Reply With Quote
Old 06-05-2010, 09:04 PM   #1828
dirtdiggler666
dirtdiggler666's Avatar
Trader Rating: (26)
damn i have not posted here in a year or so
ok who makes fender flares the rivet on type for s14? search wont work at all for me
dirtdiggler666 is offline   Reply With Quote
Old 06-05-2010, 09:20 PM   #1829
amdnivram
amdnivram's Avatar
amdnivram is an unknown quantity at this point
Send a message via AIM to amdnivram
I have a silvia front end. My passenger headlight's outer bulb is dim in comparison to the driver's side. What should i look for to fix this? They turn on fine, the high beams turn on fine so i doubt its the light switch.
Originally Posted by wh0aitznic0 View Post
In all seriousness, if you don't wanna break the bank get her a pack of the personalized MnM's and have little sweet messages on them. Bitches love messages.
http://silaudrey.blogspot.com/
amdnivram is offline   Reply With Quote
Old 06-05-2010, 11:33 PM   #1830
WERDdabuilder
WERDdabuilder's Avatar
on the s13 DCC...any know how to keep the lit after you turn you head lights on? like which wire to mess with.
When the power of love overcomes the love of power, the world will know peace
