Old 03-14-2013, 02:45 PM   #1771
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
Originally Posted by Mr. Phonso View Post
So after talking with Rich it seems like nothing is wrong with my bracket. Apparently there are two types of Toyota mounts. Guess which type I have...
w58 trans mount?
JohanM is offline   Reply With Quote
Old 03-14-2013, 05:27 PM   #1772
CDD200
CDD200 is an unknown quantity at this point
hoping to take my car to the dyno in the next week or so... what kind of numbers have yall been seeing, @ what psi and what turbos, thanks
93 s13 coupe 5 speed- Ls2 swap in the works
97 sc300-gte/v160
CDD200 is offline   Reply With Quote
Old 03-14-2013, 05:52 PM   #1773
JdmOdz
JdmOdz is an unknown quantity at this point
I love there potential
JdmOdz is offline   Reply With Quote
Old 03-14-2013, 08:17 PM   #1774
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
Originally Posted by Wadacolor View Post
w58 trans mount?
no, there are two types of r154 mounts. I just happen to have the type that is not compatible.
Mr. Phonso is offline   Reply With Quote
Old 03-14-2013, 08:19 PM   #1775
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Pics? What's the difference?
BiG MiKE86 is offline   Reply With Quote
Old 03-14-2013, 09:54 PM   #1776
Mr. Phonso
Well this is the one I have, from a soarer transmission. The other type has a skinnier base and fits in the holes basically.
Old 03-14-2013, 10:04 PM   #1777
BiG MiKE86
BiG MiKE86's Avatar
This is the mount I have - looks a bit different
Got this one for $4 on rockauto.com
Old 03-14-2013, 11:17 PM   #1778
Mr. Phonso
4 bucks? Haha that is jokes! How does it feel?
I see it is missing the 4 bolts at the bottom but for that price you really can't complain lol. I can also spot another difference between the two types of mounts. Yours is much taller which explains why the excessive bracket dips down so low in the bends. I just hope that doesn't cause ground clearance issues :/
Do me a favour and measure the bolt holes from center to center? I know one of them should be 2.2" apart from each other to work with the xcessive bracket.
Old 03-15-2013, 05:52 AM   #1779
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
Yea the one you need is the one with the screw in the middle like that ^^^
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 03-15-2013, 06:05 AM   #1780
BiG MiKE86
BiG MiKE86's Avatar
LoL that's the same mount advance auto sells for like $20+ ill probably upgrade to the Xcessive mount down the road once everything is in and running. Ill get those measurements tomorrow for ya
Old 03-15-2013, 08:14 AM   #1781
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
The mount Big Mike is using is the correct one. And FYI thats the same exact mount that sells for $69 on Drift Motion other than the fact that its a factory Toyota part.....its the SAME thing lol.
@Mike....I dont think you will need to upgrade the trans mount as I have not heard of anyone running into issues with the OEM style one that you have unless your doing it for upgrading reasons.
Super Stoked.....got my FIC 1450 BlueMax Injectors and these puppies look like the flow even better than promoted. This should be more than enough for my measly goal without having to push injectors or pumps too much. With God's good humor I finish up my end of the install and swap tomorrow and then its off to M&S for final touches once the guys are back from 2k13. They work fast so if everything goes well the car will be up and running around mid-April with AC and all until Alpha comes back and sprinkles fairy dust on the tune. Couldnt ask for a better birthday gift.
2muchboost is offline   Reply With Quote
Old 03-15-2013, 01:16 PM   #1782
JohanM
JohanM's Avatar
yeah this looks like a soarer r154 trans mount
Old 03-15-2013, 02:09 PM   #1783
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Couple questions for you guys:
1. What the part # for the correct Toyota oil dipstick if you use the front sump pan and 2jzgte?
2. If I have a hydraulic shop build me a custom high pressure power steering line, what diameter hose, what length, and what psi should it be able to withstand?
Black R is offline   Reply With Quote
Old 03-15-2013, 02:37 PM   #1784
Mr. Phonso
I can get a mount off world pak but the part number shows for auto trans. Picture looks the same though. Are they?
Edit: they are.
Old 03-15-2013, 02:57 PM   #1785
91ka24
91ka24's Avatar
91ka24 is an unknown quantity at this point
U can just buy the isis high pressure ps line and a a.n. fitting to get the line at the angle u want and it will work just fine. That's how mine is set up and i have 0 issues
Follow me on Ig- Andydennington
91ka24 is offline   Reply With Quote
Old 03-15-2013, 03:08 PM   #1786
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
My stock s13 line bolted right up, the hell with special lines haha.
di-devol is offline   Reply With Quote
Old 03-15-2013, 05:35 PM   #1787
Black R
Black R's Avatar
The banjo bolt is too long - I need a shorter one.
Old 03-15-2013, 05:52 PM   #1788
di-devol
Mine fits fine with the power steering sender off, is yours still on there?
Old 03-15-2013, 06:26 PM   #1789
JohanM
JohanM's Avatar
The new design keeps you from being able to use it, so no more Isis line for power steering, I got both the clutch conversion line and works perfect and the power steering don't.
Old 03-16-2013, 11:38 AM   #1790
Black R
Black R's Avatar
Power steering sender?
I'm using the s13 ps line and idk which bolt going through the banjo fitting into the aristo ps pump, but it bottoms out and I had to use some extra crush washers to take up the space, but it still leaks and I'm tired of adding fluid all the damn time.
I bought -AN fittings to go to the rack and to the pump, and braided lines, but there are a couple of issues:
The fittings are hard to get to in order to tighten them up at the rack AND the fitting at the PS pump won't go in bc there's some weird outlet inside the PS pump - so it only gets like 2 revolutions.
I'm probably just going to cut the union bolt down 1/4" to 1/2" and then bevel it + chase the threads with a die, then reuse the s13 ps line.
Old 03-17-2013, 06:14 PM   #1791
di-devol
[IMG][/IMG]
1jzgte weight on top
auto trans bottom. Just thought I would share.
Old 03-17-2013, 08:53 PM   #1792
Black R
Black R's Avatar
What do you guys have these vacuum lines going to?
The one under the tps sensor:
The one on the firewall side of the intake manifold - I think this one affects idle control somehow?
(to the right of the center of this pic - small vacuum line)
Old 03-18-2013, 06:00 PM   #1793
bullfrogg0
bullfrogg0's Avatar
bullfrogg0 is an unknown quantity at this point
I'm using the s13 line and the 2jz banjo bolt and have no issues with leaks or anything
bullfrogg0 is offline   Reply With Quote
Old 03-19-2013, 06:33 AM   #1794
Black R
Black R's Avatar
I was losing a little fluid every now and then.
Lately something has let loose, so I bit the bullet and put -AN fittings and braided lines on instead of the stock s13 high pressure power steering line.
I'm still losing a ton of fluid (like 1/2 qt) every time I drive the car, so I'm not driving it till I get it sorted.
No visible leaks from the lines though.
Is it possible I've ruptured the seals on the rack itself?
I've heard that the jz motors push more psi in the power steering system than the s13's do, and that this could happen. Just a bs rumor?
I was going to install a hicas rack anyway, but this is just plain annoying.
Old 03-19-2013, 08:50 AM   #1795
2muchboost
Trader Rating: (33)
If anyone is using the ATI Crank Pulley the stock Drive Belt will not fit as it is about 1/2 inch too short (the ATI Pulley is larger than OEM). The 2 belts which I have found to fit are:
Gates K060775
NAPA 25-060775
Old 03-19-2013, 09:52 AM   #1796
bullfrogg0
bullfrogg0's Avatar
I daily drove my car (35-40 miles a day) for 6 months and the only issue I had was the alternator died
Old 03-19-2013, 10:02 AM   #1797
BiG MiKE86
BiG MiKE86's Avatar
Any of you guys have to beat in the trans tunnel? My engine without the trans sitting in the bay makes me think that's going to be the case...
Xcessive brackets and mounts being used
Old 03-19-2013, 10:05 AM   #1798
di-devol
Ha, I thought the same thing. It sure looks like it huh?
Old 03-19-2013, 10:06 AM   #1799
BiG MiKE86
BiG MiKE86's Avatar
Yeah it does - did you get yours in yet? Please give me some good news
Old 03-19-2013, 10:16 AM   #1800
di-devol
I'm far from finishing lol. I yanked it to finish up the engine. I'm at a stand still while working my ass off waiting to get paid. Bi-weekly checks suck.
