#1771 |
Sosideways did you purposely make your passenger side height different from your drivers side? Or are you gonna adjust them equally and just slapped it together to drive.
Nothing says racecar like a stock car with no interior. |
#1772 | |
POWERED BY MAX: ![]()
#1773 |
![]() Join Date: Dec 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
I can get front roll center adjusters, but don't really need them. Rear drop knuckles/spindles and subframe risers don't exist for my car, I'm not a fabricator, and having someone fab them for me would be $$$$. I have seen a part some drivers use to that lowers the mounting point of the rear lower control arm where it bolts up to the rear knuckle, but that's it.
Holding it and...WHEEL POPS OFF! O^O^O |
#1774 | |
![]() Join Date: Nov 2004
A proper alignment will make a car handle MUCH better. In other news, I had risen my car for proper geometry and all that stuff. Then felt suicidal, so my car is back to being low, and with a better alignment after sorting my arm situation out. LOVING LIFE
#1775 | |
They're still not perfectly even on all corners, but for now, it's close enough. |
#1776 | |
street dancer. GLEAM |
#1777 | |
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
Is the preload just different or did you actually screw the shock into the bracket more on one side? |
#1778 | |
I've done plenty of track driving, mainly karting and iam not that slow ![]() Anyways I can't be that bad because I managed to qualify and then finish 9th in the uk odc (the final was the 7th time I had drifted ever!) I understand that I put the vid up and left myself open to negative comments, but I posted it so peeps couls observe the car not so much my driving ![]() Peace homey, iam guessing you weren't trying to insult anyone :thumbs:
[SIGPIC][/SIGPIC] |
#1779 | |
![]() Ill play more with rideheight and tyre sizes ![]() ![]()
[SIGPIC][/SIGPIC] |
#1780 |
![]() Join Date: Nov 2005
Just thought I'd share some suspension stuff from Grunewald's (Blu808 built) Camaro. Looks like an interesting setup, adapting the stock front knuckles with bolt-on adapters:
![]() ![]() Bumpsteer is goofy, but it's because of the location of the tie rod.
#1781 | |
Both dampers are set to the same clicks left and right, but shouldn't affect ride height as the spring determines ride height, not damper settings. And yes, I did physically screw the threaded shock body of the driver's side coilover further into the lower bracket, that's why the driver's side is only 8.75" from the bottom of the top hat/the top of the spring to the top of the bottom bracket, while the passenger's side is 9.25". I'm going to chalk it up to the chassis being 19 years old and probably somewhat tweaked, as well as spring variations between the two springs on the coilovers. Half an inch of difference between two sides isn't that bad. Plus, when the car is on the ground, both sides sit at the same height, just that the passenger's side is compressed a tiny little bit more than the driver's side. |
#1783 | |
![]() Join Date: Jan 2007
#1784 |
If anything, the passenger's side front is the lighter side between the 2 front corners.
Then the passenger's side rear is also lighter than the driver's side rear. So no, it doesn't make sense why the coilover on the passenger's side front is longer than the driver's side, as it should compress less. Again, I'm going to chalk it down to spring variation between the driver's side spring and the passenger's side spring, as well as the chassis may have tweaked from being 19 years old. |
#1785 |
Mine was like that too, but im not down for different height coilovers, sounds dumb.
After i swapped out my subframe with a new one and new solid bushings, the car sat the same. lololol |
#1786 |
How exactly are you getting your measurements are you measuring from a bolt to the ground? My s14 was that way because of an accident. My s13 coilovers are same on each side and the control arms are parallel to the ground equally
#1787 |
The car is level when on the ground.
Driver's side ground to center of tension rod bolt height is 4", same with passenger's side. And honestly, I'm not that worried about the coilovers being off by half an inch to make 4 or 5 posts on a forum about it. Let's move on. |
#1788 |
What's the reason the Mustang and Camaro and maybe other cars have the steering rack + tie rod in front of the lower control arm, compared to behind, like our cars?
#1789 |
It allows the engine to sit lower when it can sit behind instead of on top of the steering rack.
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#1790 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
for you guys with monoball on stock LCA
when you try to move the stud thats on the monoball(arm). is it suppose to be hard? like i just got mine done. before when i still have the monoball and the housing and i try to put it on, the monoball just slides in/out easy. now that i have the housing welded on the arm i pressed the monoball in and i put the stud on. when i try to move the stud, its harden than it used to be(compared to when i didnt have it welded on the arm yet) is it suppose to be like this? and im just trippin cuz its my first time doing this.
REVIEW |
#1791 | |
#1794 | |
If the clearance was good, it shouldn't affect it that much, but if you did it too tight, it will basically not let the bearing move around too much, or at least it'll feel all tight and hard to move. What was the bearing's O.D.? And what was the housing's I.D.? |
#1795 |
Trader Rating: (24)
im cant remember its in my inbox and im on time out lol
but yes it feels all tight and hard to move. thats bad eh? what does this mean? how do you know if you did it too tight and how do you not do it too tight? when you weld the housing on the arm? i had a shop welded it because i have no welding skills and another shop pressed the monoball in because i dont have a press. but i think i have the same parts what 95katurbo has.
REVIEW |
#1797 |
![]() Join Date: Oct 2009
![]() Feedback Score: 11 reviews
i've been checking out this thread for a while. finally its time to post up what i've done.
budget LCA and circuit sports tie rod ends: ![]() rear view: ![]() |
#1798 |
![]() Join Date: Jul 2005
Your set up looks nice. Did you replace the spherical bearings or heim joints in your budget arms?
Are you running stock tension rods?
![]() Instagram - SJKnoop |
#1799 | |
Trader Rating: (24)
like if i try really hard. i can kinda move it. but on the other arms i cant move it at all.. is there a way to fix this without buying new housing and monoball? because money is really tight. i was thinking maybe i can grind off the weld thats holding the housing and reweld it? (if this will fix the problem) heres some pics of a RLCA ![]() ![]() ![]() ![]() ![]()
REVIEW |
#1800 | |
i did replace the ball joints. i didnt do the heims yet. i'm gonna leave them for now. and yes its the stock tension rod with poly bushings. |
