Old 10-31-2013, 07:34 AM   #151
Southern Elegance
Southern Elegance is an unknown quantity at this point
Do you think its manageable to notch the trans tunnel for the shifter and it still be in a comfortable position if i wear to go without extending the shifter housing? Also did you extend it 2''???
Southern Elegance is offline   Reply With Quote
Old 10-31-2013, 07:43 AM   #152
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
I wouldnt risk it... you would probably falcon punch the radio every time you shifted into 1st 3rd and 5th. I think its a 2.5" extension and sits right in the center of the hole but dont quote me on that length.
BiG MiKE86 is offline   Reply With Quote
Old 10-31-2013, 09:39 AM   #153
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
I extended mine exactly 2inches,... and it is spot on!
...another option would be to source a soarer shifter assembly. Also extends it perfect
/threadjack
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 10-31-2013, 11:28 AM   #154
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
The throttle body looks awesome!
How much did they charge you for that? And do you know how much they took off it?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 10-31-2013, 12:32 PM   #155
BiG MiKE86
BiG MiKE86's Avatar
Hit up mkomar24 (member on here) Mike of Nocturnal Motorworks in St. Louis
Charged me $75 + return shipping ($10) and had it done and back on its way to me the same day he received it!
I can get you the overall measurement from the flange if you'd like - I dont know the specifics
Old 10-31-2013, 12:47 PM   #156
Southern Elegance
/threadjack
So the soarer assembly will bolt up to a chaser tranny? i tried searching it but couldn't find anything on it also doesnt help work blocks all the jzx forums...
If so ill just pick that up and call it good
Old 10-31-2013, 01:47 PM   #157
Flicktitty
Flicktitty's Avatar
if you could that would be great, I really need to do this over winter.
Old 10-31-2013, 09:51 PM   #158
BiG MiKE86
BiG MiKE86's Avatar
Ill get that tomorrow
Got the CXRacing upper radiator hard pipe kit and installed it. I'm fairly impressed with the kit minus 2 minor issues. The supplied hose clamps are way too big but work and the 90 DEG coupler fits pretty loose on my KOYO radiator
Super loose
Installed - I like the look
Gets a bit close by the power steering pulley but clears just fine
Here is the loose hose clamped down... It may work... Guess we'll see if it leaks
Installed lower hose as well but it still needs a good 5-6" trimmed but looks like it lines up nicely
untrimmed it kinks pretty bad (see pic)
This bad boy came in today as well (10 Micron filter)
Old 11-01-2013, 01:17 AM   #159
reynas14
reynas14's Avatar
reynas14 is an unknown quantity at this point
Mike i have to say that your build is motivating me to try a bunch of things your doing. You and flick have convinced me to go single as well. Im currently looking up all this stuff to do it, which fuel rail did you go with?
I was thinking of buying 525cc or 650s since my turbo will be smaller than yours(thinking about the GT3082r for around 400-500). Also i have most of what info i need for the single retrofit but im not quite sure how your able to control your turbos boost and such without an EMS. Could you shed some light on these?
And seriously badass paint job, super clean look!!! If mine turns out half as good as this well that will be alright! haha
reynas14 is offline   Reply With Quote
Old 11-01-2013, 06:20 AM   #160
BiG MiKE86
BiG MiKE86's Avatar
Thanks for the kind words! I went with Fuel Injector Clinic for the fuel injectors and rail
Injectors (775cc) High Impeadance
775cc FIC Toyota Supra 2JZ-GTE Fuel Injector Clinic Injector Set (High-Z)
Rail (Dual Feed -6AN)
Toyota Supra 2JZ-GTE Fuel Rail -6 Fittings Both Sides
As for boost control I will be using the Tial MV-S 38mm wastegate with a Greddy Profec B Spec II (electronic boost controller) to control boost pressure
Goodluck with your build and make a thread with your progress
Old 11-01-2013, 12:25 PM   #161
reynas14
reynas14's Avatar
Ok that definitely helps Mike. I have a scary good idea of what im going to run now and im going to put getting my r154 off to do the single than get it early next year. Also I took a trip out to zerolift today. Met Robert and talked for awhile about my car and some options. He was nice and very knowledgeable on this swap. Also they have a nice shop, clean and neat. They seem pretty legit and seriously considering buy most of my stuff there. Im gettin too geeked for this swap!!! Haha
Old 11-04-2013, 02:01 PM   #162
BiG MiKE86
BiG MiKE86's Avatar
Didnt do squat this weekend -___- but I did order some Hella 50mm projectors for the headlight retrofit! hoping to get some proper cut-offs, high light output and not piss off other drivers at the same time
Link to where I bought em... best price I could find (saved ~&70 over clearcorners.com)
Hella 009071081 - Free Shipping on All Orders @ JEGS
Also bought the conversion brackets from Derux (Zilvia.net member)
http://zilvia.net/f/sale-items/38100...-blackets.html
And ill be following this how-to guide
http://zilvia.net/f/archive-faqs/128...eadlights.html
More pics coming soon
Old 11-04-2013, 03:05 PM   #163
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
...love the progress and color of the engine bay.
2muchboost is offline   Reply With Quote
Old 11-04-2013, 10:56 PM   #164
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE's Little Build!
Thanks
More parts rolling in... Precision Turbo 3-5/8" V-band clamp and flange
The retrofit brackets for the new hella projectors
Dug these dual projectors (that i got for practically free) out of the shed. I'll be testing the retrofit on these first so that I don't ruin my mint set of triples
They are really dirty but pretty complete just missing a bracket on one light
Old 11-06-2013, 06:39 AM   #165
BiG MiKE86
BiG MiKE86's Avatar
I received my serpentine belt yesterday. I went with the Goodyear Gatorback model (part number located in pics below) and it fits quite nice for the 2JZ-GTE with NO A/C compressor installed.
Old 11-06-2013, 05:26 PM   #166
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
Your making me want to make a build thread, but have a feeling I'd be to lazy about it. Lol.
Nice build.
turbob16ef is offline   Reply With Quote
Old 11-06-2013, 07:43 PM   #167
BiG MiKE86
BiG MiKE86's Avatar
Nice build.
lol go for it! thanks
Old 11-07-2013, 04:25 PM   #168
BiG MiKE86
BiG MiKE86's Avatar
Projectors came in super quick straight from HELLA (bought thru JEGS)
And I did a quick test with the factory halogen bulb to confirm the angle of the cut-off
Mmmm mmmm nice crispy cut off and it even angles the right way! Fellow drivers you can thank me later for NOT blinding you!
Also ordered a set of 55W 5000k HID's for the new projectors
Stay tuned - more to come this weekend
Old 11-08-2013, 07:56 AM   #169
EvilEgg13
EvilEgg13 is an unknown quantity at this point
How does the wiring specialties harness integrate into the fuse boxes? I see that you have relocated your boxes to behind dash and was wondering if you have any issues with integrating them.
EvilEgg13 is offline   Reply With Quote
Old 11-08-2013, 10:30 AM   #170
BiG MiKE86
BiG MiKE86's Avatar
Fuse boxes are in stock locations - harness plugs in really nice everywhere
I can snap a pic of the connections if you would like
Old 11-08-2013, 04:40 PM   #171
EvilEgg13
My mistake, I must have confused it with another build on here.
If you could post some pictures of the connections that would be great.
Old 11-12-2013, 11:52 AM   #172
BiG MiKE86
BiG MiKE86's Avatar
I'll get those pics today or tomorrow I haven't touched the car lately
Haven't done much of anything lately but I did receive my 55W 5000K HID kit in the mail so now I can finish my headlights
Been testing the headlight baking on a beat up set of dual projectors I have so I don't ruin my triples and the 225deg for 10mins doesn't get em hot enough to easily pull the glass so I'll be trying some hotter temps
Quick pic of the HELLA projectors with 55W 5000K HID's
Old 11-16-2013, 01:41 PM   #173
BiG MiKE86
BiG MiKE86's Avatar
Playing around with a crappy dual projector as the guinnea pig
Got the lens off and then it was on to figuring out how to remove the projector
got the new bracket and projector loosely mounted on because I can't figure out what to do with this last clip and square piece that comes with the bracket
Anyone have any ideas?
Old 11-18-2013, 10:36 AM   #174
Kwolfe
Kwolfe is an unknown quantity at this point
Sweet build, in for JZ
Kwolfe is offline   Reply With Quote
Old 11-22-2013, 09:18 AM   #175
BiG MiKE86
BiG MiKE86's Avatar
Figured out where that last tab / square went on the new projector
Disassembled the triple projectors and began the retrofit
Projector installed
Glass reinstalled
Installed on car... Still prefer the look of the bricks any day
I also dropped the gas tank last weekend to finish running the fuel lines, install pump, and just clean out that year old gas
Tank out... Fuel pump still hanging there. I'll be replacing the pump this weekend and reinstalling the tank
Installed brand new OEM driveshaft bolts
Trimmed about 2-3" off the OEM lower radiator hose and it fits like a dream
Wiring specialties connection at the fusebox (someone had a question on this)
Also redesigned the a/c eliminating bracket
Old 11-27-2013, 12:11 PM   #176
erics240sx
erics240sx is an unknown quantity at this point
Hey bud it's Eric again. I forgot to save your number when I was texting you. Hit me up again 2032287483
erics240sx is offline   Reply With Quote
Old 01-07-2014, 02:05 PM   #177
BiG MiKE86
BiG MiKE86's Avatar
Been forever since I've updated this... Got the fuel lines ran just need to mount fuel filter now and wire in AFC NEO to crank it I think... Along with some heater hoses and minor little things
Also bought some one way check valves for my gas tank vent instead of leaving it open or capped
More updates soon
Old 01-07-2014, 11:06 PM   #178
Silviacraze05jr
Silviacraze05jr is an unknown quantity at this point
finally u got the neo, awesome bro.
Silviacraze05jr is offline   Reply With Quote
Old 01-08-2014, 07:24 PM   #179
BiG MiKE86
BiG MiKE86's Avatar
Yep - was that you that I bought it from?
Old 01-10-2014, 01:54 AM   #180
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
for you check vavles for the fuel vent line, why did you buy 2? shouldn't you only need to run only one of those?
Do you have a picture of your setup?
i currently have my line cut and capped off, but thinking about cutting it further back, near the gas tank, and installing a check valve.. but i also have an s14, and i know that they have 2 way gas caps..
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
