Old 12-07-2014, 11:22 AM   #151
ixfxi
ixfxi's Avatar
ixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfection
I've been preaching about this for how long? Near a decade, easily.
Besides not having any of the power steering clutter nonsense is when you drive over water, you will immediately feel the disconnect of traction with the front tires through the steering wheel. It gives you a huge advantage over cars with numb power steering.
I have a HICAS rack that I de-powered. I am curious how that is going to feel. The closer ratio might make it a bit too much, but I'm willing to give it a shot. I know my front tires arent going to help either (275mm R888)
ixfxi is offline   Reply With Quote
Old 12-07-2014, 12:13 PM   #152
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Buddy of mine had a depowered hicas rack on his s14 and loved it. If I could have found one before depowering mine I would have gone that route for sure
Old 12-07-2014, 02:47 PM   #153
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
There is a Dodge Omni universal manual steering rack going in my car.
Looks same as this, except mine will be mounted properly, unlike this person's who has a deathwish.
Old 12-08-2014, 06:36 AM   #154
JZ78
JZ78's Avatar
JZ78 is an unknown quantity at this point
You have any more info on the Dodge Omni rack...like what kind of modification needed to fit in an s13, is it just Bolt on? Anymore info would be greatly appreciated kind sir.
sent from my mind
91 s13 hatch back in the game
JZ78 is offline   Reply With Quote
Old 12-08-2014, 10:31 AM   #155
zdfhh
zdfhh is an unknown quantity at this point
So, compared to the way you had it before with the looped lines, how does it feel?
zdfhh is offline   Reply With Quote
Old 12-08-2014, 11:47 AM   #156
TheRealSy90
TheRealSy90's Avatar
Does the dodge omni rack use the same tie rods?
Such a good signature.
Old 12-08-2014, 12:09 PM   #157
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Originally Posted by Hoffman5982 View Post
^That really wasn't worth reviving this thread over.
But here we are, so I will give my impressions on having a depowered rack:
I love it. I've had it in for about 2 months now after my 3rd rack started leaking like crazy. Throwing the car is harder, obviously, but the amount of feedback you get is incredible. I can also transfer as hard as I want not worry about countersteering fast enough. A manual rack forces you to become smoother while drifting. Parking lots really aren't bad. if you're standing still, turning sucks. But if you're moving slowly its super easy to pull in and out of spaces. On my garage floor I can turn it with one hand while standing still, but not quite as easily on concrete that isn't so stiff.
If you're going for a low power drift car, this is definitely a great option. One thing I should note is that the faster you're going while drifting, the harder it is. So if you're running more power and going for higher speed entries, keep your power steering.
But it was... Im not the only person interested in this...
I was also told I Need to run a breather off the rack itself, do you have one or did you weld or crimp everything shut...
Old 12-08-2014, 05:24 PM   #158
Matej
Trader Rating: (39)
No, but there are plenty of tie rods with the Omni threads on one end and S13/S14 on the other. The Moog website has a convenient list will all the thread pitches and lengths listed. The U-joint can also be ordered with the 240SX tooth-pattern on one side and the Omni patter on the other.
In the picture above the rack has the mounting brackets cut off, but they come new with mounting points on one end. I am just going to bolt it down through the stock holes on the crossmember (doubt they will match up exactly, so one of the holes on either the rack or the crossmember will probably need to be elongated or redrilled). On the other end I will use the clamp made for it and do the same thing with the holes.
It is the most basic and generic rear-steer manual rack I found. The nice thing is that the dimensions and angle of the shaft are similar to an S-chassis rack, and it even has a nearly identical travel distance.
Old 12-08-2014, 05:45 PM   #159
TheRealSy90
More or less travel?
Old 12-08-2014, 10:17 PM   #160
ixfxi
ixfxi's Avatar
Matej
can you please keep us posted with your progress? This is really awesome.
Do you mind sharing some info/specs as for OE S-chassis vs Omni racks? Turns to lock, thread pitch/diameter, etc. I think a lot of people will find this information useful.
Old 12-08-2014, 10:41 PM   #161
Hoffman5982
Trader Rating: (25)
I had grease fittings welded into the two ports on the rack and the two bigger ports sealed off. You fill it with grease and cut the piston that holds the seal specifically so you're not having to push hair, so having a breather isn't necessary. I was told to just seal them so debris wouldn't make its way inside.
Now that the Omni rack has come up, I am curious as to whether there is a difference between a properly depowered rack and a rack originally made to be manual as far as ease goes?
Old 12-09-2014, 06:59 AM   #162
Corbic
Corbic's Avatar
Rack Ratio will be another big factor.
Old 12-09-2014, 07:03 AM   #163
Corbic
Corbic's Avatar
Matej,
You going to use the Flaming River stuff (~$300) or "Autozone" one (~$140)?
Old 12-09-2014, 08:31 AM   #164
ixfxi
ixfxi's Avatar
Thats always been my understanding, that the ratio is not as close with the actual manual racks. My guess is that the Omni requires more turns to lock.
You guys were talking earlier about how you capped or vented the rack. Maybe I took the cheap way out, but I just stuffed some foam in the ports and called it a day. The foam keeps debri and shit out. I dunno, seemed sufficient for me.
Old 12-09-2014, 08:33 AM   #165
Corbic
Corbic's Avatar
Basically yes. The more turns they lighter they are. I'll check the 911 tomorrow for a turn count.
It's the epitome of a perfect manual rack.
Another factor impacting turning weight is the actual alignment.
Old 12-09-2014, 08:37 AM   #166
ixfxi
ixfxi's Avatar
If I am correct, caster is the most important when it comes to steering weight. Not exactly easily adjustable though.
Old 12-09-2014, 05:39 PM   #167
Matej
Trader Rating: (39)
240SX rack
137mm of travel with stock inner tie rods, +15mm or so extra travel attainable with spacers
3.5 or 3.7 turns lock-to-lock with stock inner tie rods (please correct), less for a Hicas rack
11/16" 36-tooth spline
M14x1.5 (please correct if wrong) female inner tie rod thread pitch
Omni rack
127mm of travel
4 turns lock-to-lock
9/16" 26-tooth spline
9/16"-18 male inner tie rod thread pitch
More technical info: http://www.flamingriver.com/download...anualRackSpecs
The Omni rack will not match the stock rack for competitive driving/drifting, I am mainly only doing this because I like the simplicity of manual steering and this was the best option I found so far. However, I will be using the GKTech knuckle adapters or possibly some mild modded/aftermarket knuckles, which should make up for the shorter travel and the longer ratio.
Here is a good list of inner tie rods:
http://www.moog-suspension-parts.com...r_Tie_Rods.asp
A conversion U-joint and/or a shaft spline conversion/extension can be bought from places such as this:
http://www.borgeson.com/xcart/catalo...0-p-1-c-2.html
Matej,
This one:
http://www.helixsuspension.com/catal...Rear-Steering-
Though I ordered it through some random vendor months ago and they keep pushing back the shipping date, so I will probably order one from elsewhere.
I did have a random junkyard one, but it was old and I only used it for mock-up.
Also, there are two models available, one with a long pinion, and one with a short pinion.
Old 12-09-2014, 10:24 PM   #168
ixfxi
ixfxi's Avatar
Matej, a quick search online shows the following:
Steering Rack Ratio
HICAS - 14.9:1
Standard - 17.0:1
Turns to Lock:
HICAS - 2.6
Standard - 3.1
hehe, man... my car is going to FUCK me up. But maybe not. I quickly searched the Miata rack specs and it appears the actual manual rack is 3.3 Turns to Lock, and the Powered is 2.8 Turns to Lock. On paper, the manual HICAS rack should be nice.. but as we all know, real world is totally different than paper. I'll report back if and when I ever finish assembling this piece of shit car.
Old 12-10-2014, 02:41 AM   #169
Hoffman5982
Trader Rating: (25)
Just be prepared for pain if you dip off the road or anything. First time I slid with the manual rack I made a mistake and tried to catch the wheel. My wrist still gives me problems if I try to put all of my weight on it in a weird way. I'm just waiting for the broken thumbs my friends who ran manual racks had from time to time. There's no forgiveness.
Old 12-10-2014, 11:02 AM   #170
ixfxi
ixfxi's Avatar
then you didnt properly empty the rack
when the rack is empty, you can turn the wheel very easily except when you are 100% dead still. if you're parking and even moving very very slowly, the wheel turns easy
i have had my setup on multiple cars for over 10 years, no issues... autox events, etc.
Old 12-10-2014, 12:47 PM   #171
Hoffman5982
Trader Rating: (25)
I mean when you lose control. As I said before the only time it's hard to turn I when standing completely still, but even then it's manageable. At slow speeds you can barely tell it's manual. But when you screw up while drifting and go off the road or something, it can be brutal. I haven't had any problems since that first night now that I'm aware of it
Old 02-16-2017, 07:50 AM   #172
JayJay240sx
JayJay240sx is an unknown quantity at this point
s13
I was reading up on the miata forums and they talk about play in the steering unless you weld the pinion, is this also an issue in the s13's? I have a 92 240
JayJay240sx is offline   Reply With Quote
Old 02-28-2017, 10:38 PM   #173
Tulok
Tulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really nice
nobody in the ENTIRE thread ever spoke of welding, EVER.
Tulok is offline   Reply With Quote
