01-10-2015, 10:33 AM | #17731 | |
Instagram @Fatlaced40 Last edited by TunanS14; 01-10-2015 at 11:09 AM.. |
01-10-2015, 11:20 AM | #17732 | |
Trader Rating: (24)
Feedback Score: 24 reviews
Thanks for your reply. Tell me where is this new hub with bearing that cost just as much? Timken front bearings are $50 ea and rears are $100 ea. I only use timken bearings, because I have had good success with them in all my previous cars. Besides I have arp studs on my hubs so I don't really need a new hub. Anyone with more knowledge know if oem bearings work with ichiba front and rear hubs?
REVIEW |
01-10-2015, 11:44 AM | #17733 |
Trader Rating: (24)
In all the conversion hubs I've used I've been able to replace the bearings with OEM or Timken replacements.
I run rear OEM hubs because they last longer than the conversion hubs. |
01-10-2015, 03:34 PM | #17735 |
are the kouki bumper extension brackets needed to put on the 180sx front bumper? or will it fit fine with just my pig nose brackets?
im talking about these things:http://www.frsport.com/Nissan-62293-...t_p_32852.html edit: and where can i get the nissan emblem for the front bumper? ive googled and everything i found was like over 30$ +shipping which imo is ridiculous. Last edited by dirtychubbs; 01-10-2015 at 09:00 PM.. |
01-10-2015, 06:36 PM | #17737 |
Does anyone know what I need to do to become a vendor here on Zilvia? I am not looking to do a group buy or advertise. I can't find any information about the subject. (Yes, I have ready contacted admin/mods/RJF... No reply)
Instagram @Fatlaced40 |
01-11-2015, 12:48 AM | #17738 | |
Trader Rating: (24)
I didn't feel like going to the junkyard and pulling out a set of hubs and nobody was selling OEM hubs at that time.
REVIEW |
01-11-2015, 08:53 AM | #17739 | |
Ichiba Hubs USE NISSAN Bearings, ie, OE bearings. That work for you?
01-11-2015, 02:52 PM | #17740 |
Welded diff supporting mods
should I wait for my coils or should I install my welded diff now with my tokico shocks and lowering springs?
Or does this not even matter? I just want to go drift |
01-11-2015, 04:43 PM | #17741 |
01-12-2015, 07:12 AM | #17743 |
a little? All I did was check Ichiba to see what they used for bearings and it was right there...Nissan bearings, or oe. if you would like sarcasm, I could try a little harder for ya though
01-12-2015, 09:28 AM | #17744 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
perhaps instead of being a smart ass to people in the future, you can forgo the attitude as you never know when someone will come along and shut you down because your providing information that is wrong! copy and paste isnt always your friend pumpkin... |
01-12-2015, 10:08 PM | #17745 |
alright so i recently installed a walbro 255 fuel pump for my ka24de. also installed a new fuel filter. a little bit after that, one of my fuel injectors wasnt working properly. would cause the engine to shake and would cause sputtering. drove the car like this for maybe 10 miles and nothing was wrong except for the sputtering and engine shaking. i change the bad fuel injector and the sputtering and engine shaking goes away. but now, when i give it gas, the idle drops low and hesitates before the engine revs. it doesnt do this all the time though and it did make the car stall once. if i keep an eye on it i could make sure it doesnt stall. and it also feels just a tad bit sluggish on acceleration. the car also started to run rich. my question is what is causing it to do this? do i need an adjustable fpr? help would be much appreciated.
Instagram:@juhd_ |
01-12-2015, 10:31 PM | #17747 |
would this fix the revving hesitation/dropping idle before it revs? why wasnt it doing this when i had the bad fuel injector in? also would it be bad to drive like this for a while?
Instagram:@juhd_ |
01-13-2015, 12:26 AM | #17749 |
Does anyone know what size bolts are used to bolt an SR ac compressor bracket to the block? And what size bolts to install the compressor itself to the bracket? This is for a s13 sr20det redtop. I have searched and the one piece of info I found was wrong. Pm me plz
01-13-2015, 01:50 AM | #17750 |
What aero looks mostly stock for fenders? I need some nice fenders that's mostly stock looking with no vents cause I'm not a fan. I can't find any decent stock ones that aren't dented or taxed for being stock fenders.
01-13-2015, 06:41 AM | #17751 | |
I was only referring to the call out for sarcasm, since a quick, not research quality, look on google provided an ample answer TO FITMENT, not quality, which was what was being asked. If you want to educate we dirty unwashed unknowing on the finer points of quality, please proceed sir, in all due haste!
01-13-2015, 12:10 PM | #17752 |
If the stock fpr is working fine then whats causing my car to do this? Is it the injectors? I only changed one and prior to changing it, it never gave me this problem
Instagram:@juhd_ |
01-13-2015, 01:21 PM | #17755 |
Get a cheap inline fuel pressure gauge to verify fuel pressure with and without vacuum source. My bet is on pinched injector o-ring. Go to hardware store and replace all your injector o-rings. It's silly cheap and make sure you use a little oil around them when installing to prevent them from binding.
I had a Walbro 255 and a stock FPR that never had these issues so don't worry about the 255, it should be fine. Your fuel pressure will be slightly higher because of it but not enough to cause noticeable hesitation you're describing. |
01-13-2015, 01:43 PM | #17756 |
One of my headlights is out on my hatch, bought a new headlight still Dosent come on. Bought a new switch and installed it, still Dosent come on. Check the fuses they are all good, what else could it be??
Instagram: Nismo_Lk |
01-13-2015, 02:15 PM | #17757 |
The injector probably isn't seated all the way. The first time I replaced an injector I did the same thing. It ran so rich that the exhaust was pretty much all raw gas. You might want to pull off another injector cap to compare how the new injector is supposed to sit in the rail.
01-13-2015, 04:03 PM | #17758 |
Swapped z32 brakes and booster on my s13.... After it warms up I get a squealing from my brake booster under light pressure... After I stop I can apply the brakes fully or completely let them off...and the noise quits....light pressure and it starts again. Really think its vacuum prob coz when I apply brakes my idle goes up and down. Drives me crazy....and is really embarrassing sitting at a stop light with my booster yelling. Please help
01-13-2015, 05:12 PM | #17759 | ||
Instagram:@juhd_ |
