#17671 |
![]() Join Date: Jul 2012
![]() Feedback Score: 10 reviews
Is it normal for ignition timing in an sr20det, to drop to 0 degrees (TDC) when ever letting off of the throttle?
Say I'm idling at 900 rpm and ignition timing at 15btdc, then rev the engine to 3000rpm (timing going between 30-36 degrees) and then let the throttle go. Should the timing drop to 0 and then back 15btdc? |
#17672 |
![]() Join Date: Nov 2005
I need a new transmission mount.
Do solid ones cause too much noise or vibration? Or am I better off getting an OEM style one that is of a harder urethane?
http://www.nissanroadracing.com/ |
#17673 |
AFC #1
![]() Join Date: Oct 2003
IMHO a solid transmission mount is 10x worse than solid engine mounts. Get Nismo.
#17674 |
Hi guys, small question here that i didn't wanna make a new thread for. So here it is.. today me and my brother were checking out my exhaust and were trying to see if we could Lower my 1995 s14 any more. As it sits, it's pretty high (17" rims and like a 2" ugly Gap inbetween tire/fender) it's fugly, and i can't comprehend how other s14's slam their car to where they have no wheel gap and their front bumper is almost touching the ground.
The question is.. how do you guys clear your Oem downpipe thing? mine sits lower than my cat and is like 3" off the ground.. am i missing some super kewl step to lowering my car with Oem down pipe? Please help, thank you. edit: you can actually see my gap in my little avatar picture. My oem headers are what sit so low btw (idk what else to call the piping) thanks |
#17675 |
S14 came with no radio. I have put in a pioneer double din. My question is I have no dash lights. Clock works. Dimmer switch is good. No blown fuses,and yes tail lights work as do the ac,heater control lights. On the harness adapter there are 2 wires not hooked up, one which says illumination the other says dimmer. Do one of those 2 wires need to be hooked up to the pioneer to complete the circuit?
#17676 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
I have a nagisa double lok rails. It's kind of rough to slide the seat back and forth. I would have to pull and push on the steering wheel for me to adjust the seat. Is this normal? Is it suppose to slide like the stock slider?
REVIEW |
#17677 |
![]() Join Date: Sep 2012
would anyone know why the temp guage on my cluster isnt working? it never worked when i bought the car. my speedo didnt work so i changed the cluster. the new cluster had a working speedo but the temp guage still didnt work. but about a month ago, while i was driving it started working but only for a few minutes. and it was just jumping all over the place. this was the first time it ever happened and the only time. so can someone help me out? car is a 91 KADE
Instagram:@juhd_ |
#17678 |
Trader Rating: (24)
Have you check the connections? It could be the sensor.. most people just add a senor and water temp gauge for accurate reading.
REVIEW |
#17681 | |
#17682 |
Before you go buying a sensor, make sure its the coolant temperature SWITCH.
There is a coolant temp SENSOR and coolant temp SWITCH. One is for gauge cluster and one is for the ecu. Just a heads up. And you can get them at auto zone |
#17683 |
-Bought an s14 sr
-Didn't come with a turbo -got oem bb t28 -no banjo bolt for turbo oil feed, however it came with one in the block -oil feed banjo bolt from the block doesn't screw into turbo -threads look ok Does the turbo have a different thread pitch banjo bolt from the block?? |
#17684 | |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
http://www.enjukuracing.com/products...FQphfgodsKQASw |
#17685 | |
Went full retard and forgot i had another turbo. The answer is No if anyone is wondering. The banjo bolts on the block and turbo have different threads.
#17687 | |
#17688 |
can i get someone's opinion on these lower control arms for my s13 ?http://www.frsport.com/FRSPORT-1128-...-R_p_2246.html
Well it help with a smoother riding experience or should I get a different brand like moog? |
#17689 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Those are the same thing as moog, but more expensive and without a brand name attached. The moog balljoints are good stuff.
You are really overthinking this. |
#17691 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
anything is better than 20+ year old ball joints, control arms and bushings! however, id HEAVILY recommend you order 2 brand nuts + bolts for the lower control arms. reason being is that the insides if the bushings have a metal sleeve that likes to rust to the bolt. if this has occurred, you will have to cut the bolt out with an angle grinder... and i speak from personal experience. nissan sells the nuts and bolts brand new for like $14 a set. |
#17692 |
Trader Rating: (24)
The moog are $35/ea. I had an frsport balljoint fail within 6 months of install a while back. Might as well go rockauto if you want generic flca with new balljoint and bushing.
#17693 | |
#17694 |
![]() Join Date: Dec 2012
Trader Rating: (22)
![]() Feedback Score: 22 reviews
Will there be an issue with using s13 rlca and uprights on an s14? I've searched and the threads that come up only talk about z32 rlca. I'm thinking there wouldn't be an issue since s13 and s14 rear arms are interchangeable?
#17695 |
Can anyone shed some light on whether the heater core lines are accessible in an S13 with a non-VVTI 1JZ swapped into it with the stock twin turbos? I've read briefly in the 2JZ swap thread that people have trouble running heater lines with factory twins on a 2JZ but do you run into that same problem with the 1JZ swap?
#17696 |
AFC #1
S13 RLCA are shorter and have a different angle to them. There is a reason people swap to an S14 subframe.
#17697 |
Trader Rating: (22)
![]() Well I'm swapping a s14 subframe into my s13 but the s14 RLCA's are in bad shape and my s13 ones are in good shape so I wanted to save money and time by using my s13 ones.
#17699 |
When I am driving or drifting (most of the time) my motor cuts out after about 4k RPM's, throttle stops working and when it drops to 0 RPM's my throttle starts working again. This doesn't happen all the time but most of the time. My father told me to clean the MAF and see if that solves the problem. What else could it be if I do not have a bad or dirty MAF? 😆
#17700 | |
Clean MAF Replace Fuel Filter Run test, if fine, problem fixed If not fine, sensors are cheaper than injectors...maybe Run test If not fine, suck it up and replace injectors If you have a ECU code breaker, see what codes come up and if you can, correct the bad part/s The bottom line, though, is these are all systems in the car that are ~20 years old and probably haven't been replaced at all during their service life
