07-24-2014, 10:51 AM | #16981 |
S14 trunk lid width
sorry, i forgot to measure my trunk last night.
can someone who has a S14 or access to one get me the measurement of the trunk lid width at the lowest point (towards the rear bumper) from edge to edge? if you can provide a picture with tape measure on it would even be sweeter. thanks in advance.
07-24-2014, 05:44 PM | #16983 | |
Get ready for the shitty part of troubleshooting: Look for the WIRE for each interior light at the fuse panel where the fuse is being blown out. You can do this two ways at this point. Disconnect the battery 1st way: Use a multi meter to check each single wire from the fuse panel, all the way out to it's power end or ground end. Your meter will deflect if you have a good wire. If your meter does not deflect, your wire is broken or shorted to ground between the ends. replace the broken/short part of the wire after you find it from there...this take a fuck load of time, sucks balls to do because that one wire is probably the one that takes a bunch of other stuff to find it(like breaking open the wire harness protector) 2nd way: Find each wire that goes to the fuse panel for the lights, find it's other end, just replace the wire because you have to do all that other stuff after 'check with multi meter' in the 1st way. 3rd way: Keep the battery connected, and do a continuity check with the hot wires. Either way, you are going to have to tear into the system to replace the bad wire/s
07-24-2014, 05:48 PM | #16984 |
When you have unregulated power going directly to the fuse panel due to a shorted relay, you are getting all 650+ amps direct from the battery to the panel which will blow fuses like a mofo
If you have a direct short to power or ground, fuses will blow as well. Either way, the job of troubleshooting a ghost in the wire is a real bitch
07-24-2014, 11:00 PM | #16985 |
I bought an S14 SR and it has red injectors on the stock fuel rail. I keep hearing red injectors are only KA 270s.
Did these come stock with red injectors? or do i really have KA 270s and my shits gonna blow up? |
07-25-2014, 02:09 AM | #16986 |
SR transmission with KA clutch slave cylinder. Has anyone ever had any issues? I don't understand it. The bolts for the Sr transmission are bigger than the ka slave. I had to drill it out and it's fine.. but still don't understand how no one I've talked to has had this issue..
07-25-2014, 06:37 AM | #16987 | |
07-25-2014, 02:57 PM | #16988 |
For S14 Steering rack bushings - is it still recommended to stick with OEM/Nismo for the passenger side bushing? From all the threads I can find, it says the energy suspension passenger bushing is too small for the S14, but then again these threads that I'm reading are several years old. Has this issue been corrected since with ES bushings? The suggestion from most seems to be to buy the combo kit from SPL parts, but I dont see that they sell a Nismo/ES bushing combo for the S14 anymore, and I want to change my bushings soon so, input?
07-25-2014, 10:36 PM | #16990 |
planning to buy all the pbm suspension arms but dont have the money to buy all at once. which ones would be better to buy first? i wanna get rucas for sure right off the bat to adjust camber. i know they are all important but what else would be practical with alignments?
07-26-2014, 01:15 AM | #16991 | |
Or am I doing it wrong??? Still good to purchase RUCAs first though because they'll help for clearance with your coilovers, with that half-moon shape. Just make sure your car is aligned! |
07-26-2014, 08:34 AM | #16992 | |
07-27-2014, 10:31 PM | #16993 | |
This is what happens when you don't buy Toe Arms first: That was taken almost 3 months ago. It's actually worse now, of course. Really need to buy some Toe Rods soon... |
07-28-2014, 07:01 AM | #16994 | |
07-28-2014, 11:14 AM | #16995 |
Hey, really dumb question, lol, but:
Do the heat shield brackets on the Megan test pipe face up or down. Since the underbody already has a heat shield I wasn't sure if they face down so you can put a shield on to hide the test pipe. Thanks. |
07-28-2014, 01:09 PM | #16996 |
Down, to make it look like a cat.
07-28-2014, 02:25 PM | #16997 | ||
AFC #1
http://i27.tinypic.com/2cqh3sx.jpg Quote:
-Most sets are Toe and RUCA's in the rear. Like said above you won't get far(2*) with RUCA's before you max out the stock toe rods. -Not many people know how to dial in the rear tension/traction rods. They should be last on the total list. -Then on the front the tension rods are mainly firming up. A good shop can adjust them. Caster is listed on most alignment machines but not listed as adjustable stock. Before that I would make sure your Tie rod and rod ends are in good shape.
07-28-2014, 10:29 PM | #16998 |
Where should the 3 lines be going to from my boost pressure solenoid? I found that one of the three nipples on it was not being used beacause I have been having a missing problem lately. So now I have my WG actuator vac line running to one nipple, Then the nipple on the opposite side is running to my second vac nipple on the TB, and the third nipple is used for my boost controller. Is it supposed to be a boost source instead of vac source?
07-29-2014, 12:16 AM | #16999 | ||||
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
doesnt really matter, unless you REALLY feel like hunting down a cover (theyre pretty much extinct). break them off, throw them in the garbage otherwise they will start vibrating at certain RPMs. without a cat, you will never "legally" pass smog as it is, so why bother trying to fool law enforcement? (just being blunt) Quote:
OEM KA24de/SR20de 270cc injectors: OEM S13/S14 370cc SR20det injectors: TOMEI/NISMO/HKS sidefeed 740cc injectors: Quote:
if youre concerned with alternative cooling options, upgrade your radiator to a Koyo 55mm aluminum unit, its a night and day difference! dont cheap out and buy a knock off, a lot of them are poorly built and dont actually have hollow upper and lower tanks!!! |
07-29-2014, 04:24 AM | #17000 | |
07-29-2014, 10:36 AM | #17001 | |
No No I understand this and my TB third nipple is capped off and my other two vac lines are done the exact way that you just stated. But when I bought my car with the sr in it I never new what this thing was. MY WG actuator line runs to what reads to be a "turbosmart solenoid valve" which has 3 nipples on it; And one of the nipples was not being used so I didn't know the correct way to run my vac lines with it. So now I have one nipple running to my waste gate, the opposite nipple running to smaller nipple on TB, then the other nipple runs to my boost controller. So is this solenoid needed for my boost controller, or should I just take it out? |
07-29-2014, 11:07 AM | #17002 |
Trader Rating: (22)
Feedback Score: 22 reviews
Why is it that I come back to the s chassis scene and everyone suddenly believes their stock KA on some coilovers with beat up interior and exterior is worth 3k now?
just saying... legit question I think.. |
07-29-2014, 12:21 PM | #17004 |
I'm not a bright person when it comes to electrical work, so I have what could be a very stupid question. Recently my third window amp on my Zenki blew, as well as the motor. Since this was my third amp, my brother and I deleted it following this guide, and I replaced the motor with a new unit from autozone. Now everything on the door harness is running proper, sending ground and power appropriately, but the new motor once plugged in receives power under either switch positions. If I have the motor plugged in, testing wires at the plug on the harness side all signals are appropriate, but motor side both wires receive power. Why this is he case is entirely beyond me. Anyone have any ideas?
07-30-2014, 06:47 AM | #17008 | |
If your tires are worn, rounded on the inside it can be one of three issues: Balance, Camber, or Toe. It can be CAUSED by: Improper balance Improper Alignment Worn Tension Rods or Camber Plates If you are a mechanic, go back to school.
07-30-2014, 06:53 AM | #17009 | |
Caveat: This is just one POSSIBLE issue. Check grounds, look for power shorts, etc
