#16863 |
![]() Join Date: Jan 2013
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
I'm buying an SR20 swap soon. I REALLY want power steering. The seller has everything I need for power steering aside from the lines. Will my power steering lines from the KA work on the SR?
#16864 |
Where to purchase Wheel lip for a Vsxx in SoCal
at a good price would you guys recommend having someone taking the wheels apart n replacing lips or the processes is pretty basic & DIY ? |
#16866 |
![]() Join Date: Mar 2008
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
I have a s14 kouki carbon fiber hood and I need to mount my silvia emblem on the front.
I don't have the two alignment holes. Could someone with a kouki and the silvia badge measure the distance from the center tip of the hood to the bottom tip of the badge? Thanks a bunch! Also, while you're at your car with your tape measure, could you measure the dimensions of the nissan emblem in the center of the kouki taillights? Thanks Again! |
#16867 | |
#16868 |
![]() Join Date: Jun 2009
![]() Feedback Score: 11 reviews
Has anyone had issues with putting an SR fan shroud into an S13 with A/C? The drier on the passenger side is in the way of the fan shroud so I removed it for now, but I really want to have working A/C in the near future.
#16870 | |
![]() Join Date: Jun 2008
i'd try wheelflip or vip modular
#16871 | |
ahhh that sucks. had that happen to me before. had to remove everything. sorry i dont think there is.
#16872 |
How do I know if I have 26mm or 30mm z32 calipers? They are aluminum, I measured rotor thickness and they were at 26mm but they are 3 years old, could they wear down to 26?
#16873 |
As long as you have a duel cam ka then it will bolt up..if you have a 89-90 s13 then you need a 91-94 dohc power steering lines setup
Instagram username:angelmkiv |
#16874 | |
AFC #1
![]() Join Date: Oct 2003
#16875 |
I read that yesterday, but it's not very helpful.
"The following is a comparison of some different Z32 300ZX brake calipers. The "26mm Aluminum" calipers were used ONLY on 1990 non-turbos. They used a 280mm x 26mm rotor. The "30mm Aluminum" calipers were used on 1990 Twin-turbos and ALL 1991-1992.5 300ZX's (both turbo and non-turbo alike). They used a 280mm x 30mm rotor. The "30mm Iron" calipers were used on ALL 1992.5-1996 300ZX's (both turbo and non-turbo alike). They also used the 280mm x 30mm rotor. Of course, the easiest way to tell aluminum from iron is to use a magnet, but I hope this helps some people trying to figure out what they've got/are getting if buying with just a picture for info." I measured my rotor thickness, it was right at 26mm, but the rotors are years old, so I'm wondering I guess if it's possible that I have 30mm ones and they've worn down to 26mm, or if I have 26mm and I'm being a retard. |
#16879 |
![]() Join Date: Jan 2011
Trying to decide which turbo to use on my sr.
Blew my s15 t28 up. Options are isis 3871 holset hx35 with bep housing. Car is used purley for drifitng. Sr has a built bottom end, stock head (have parts for built head just no doner head at the moment) 1000cc injectors aem v2 twin disk clutch stock trans one piece driveshaft
#16880 | |
http://zilvia.net/f/showthread.php?t=432611
#16881 |
![]() Join Date: Dec 2012
Trader Rating: (22)
![]() Feedback Score: 22 reviews
Currently have two small problems with my s13, I searched but didn't really find an answer.
First problem, after the fuel pump is done priming, I can hear a moaning sound coming from the fuel pump. At times I can hear it while the car is on. Recently I replaced my fuel pump because it went out but that sound is still there. Any thoughts? Second, I have to turn the key multiple times for my car to turn on. Sometimes it's two times or other times it's like 10 times I have to turn the key. I doubt it's the starter. I'm leaning more on the ignition switch is going bad. Any advice or answer is greatly appreciated. And thx in advance |
#16882 |
I have an s13 blacktop sr20det with apexi power fc and got an iat sensor and harness. The harness came with several connectors to use on the ends of the bare wires that go to the ecu. Which do I use? Picture of harness from FRsport showing the ones included.
http://www.frsport.com/APEXi-415-XA0...s_p_26603.html Also, Are these the correct places on the ecu to connect the harness to? http://www.importintelligence.com/appofcsrdiat.html Thanks! |
#16883 |
![]() Join Date: May 2013
Is there any other way to dampen coilovers? Reason why I ask that is because every time I turn the knob left it never stops. There is no stopping point. Is it broken?
Sent from my iPhone using Tapatalk |
#16884 | |
Did you install a stock replacement pump or a walbro? I've heard of Walbros making noises. When you say "turn the key" do you mean into the start position? |
#16886 | |
@tannermwilson |
#16888 |
you could also try VRWheels
@tannermwilson |
#16890 |
![]() Join Date: Dec 2009
So my car randomly decided not to start out of no where. My car won't start and NO clicking sound - nothing!! What could this be, any ideas? bad starter or solenoid??
