Old 09-18-2012, 05:20 AM   #1651
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
You will need a stupid amount of camber, I have a hard time fitting a 255/35 on my 18x10.5+15 s14 with roll and slight pull
Te37 is offline   Reply With Quote
Old 09-18-2012, 07:39 AM   #1652
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Pblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of light
Feedback Score: 48 reviews
I am wondering if I am going to rub at full lock(modded knuckles) on my 14
Wheel Size & Offset: 18x9.5 +14 18x11.5 +19
Tire Size: (Front) 225/40/18 (Rear) 265/35/18
And what is needed on the rear as far as a pull ?
This is not my track setup and I do not plan on sliding much with these wheels. But I can not risk damaging my car or wheels so id like to know if im going to run into any issues.
Do you suffer from vaginal dryness...
Pblesh85 is offline   Reply With Quote
Old 09-18-2012, 04:14 PM   #1653
Eazy_tom
Eazy_tom's Avatar
Eazy_tom is an unknown quantity at this point
how much camber are you running te37?
Thank you for the input btw.
Eazy_tom is offline   Reply With Quote
Old 09-18-2012, 04:36 PM   #1654
Te37
Te37's Avatar
I'm running -1.5 in the rear, and that's as low as my tein coils go
Old 09-18-2012, 06:17 PM   #1655
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by Eazy_tom View Post
Stock body s14, would it be hard to tuck 18 x 10 1/2 +15 ?
I'm guessing I'll need a pull.
18x10.5 +10 with 235/40-18s. Running about 2 1/2 degree of camber. You'd need more camber and more pull if you want to fit wider tires.
CLICK HERE!!!
Old 09-18-2012, 06:22 PM   #1656
fliprayzin240sx
18x11 +28 on 265/35-18s. Your setup would stick out another 15mm pass these. Fenders pulled as much as I can before it starts getting all wavy. I pulled it some more a year later after this shot but the fender started to wave. Ended up smoothing it up with some bondo.
CLICK HERE!!!
Old 09-18-2012, 07:16 PM   #1657
SLYDEWAYS 96
SLYDEWAYS 96's Avatar
Trader Rating: (34)
SLYDEWAYS 96 is an unknown quantity at this point
Feedback Score: 34 reviews
Anyone know if a 18x8.5 +35 up front will clear a 300zx bbk and look decent with 245/40r tires on a s14 chassis? And how would a 18x9.5 +35 with 285/40r look in the rear? Don't wanna run more than -2 camber and fenders front and rear are rolled already. Rims I'm deciding to go with are Enkei Wheels - Tuning Series - Raijin
SLYDEWAYS 96 is offline   Reply With Quote
Old 09-18-2012, 09:28 PM   #1658
Eazy_tom
Eazy_tom's Avatar
Thank you guys, good stuff.
Old 09-18-2012, 09:36 PM   #1659
fliprayzin240sx
I'd suggest you read thru this thread a couple pages back, should be more than enough to answer ALL your questions...
CLICK HERE!!!
Old 09-19-2012, 07:47 PM   #1660
TunanS14
TunanS14's Avatar
TunanS14 is an unknown quantity at this point
This should be called the "All wheel fitment questions answered by fliprayzin240sx thread" Haha!
TunanS14 is offline   Reply With Quote
Old 09-19-2012, 10:36 PM   #1661
humilde_s13
humilde_s13's Avatar
humilde_s13 is an unknown quantity at this point
Originally Posted by fliprayzin240sx View Post
PM Knoop (95KA-Turbo), think he runs knuckles and 10js up front on his S14. He should be able to tell you if he had any clearance issue.
Not 100% sure but to me, running undersized wheels is like raising the car up. All you're doing is giving yourself more gap/space between the tires and fenders. I think you'd have a better clearance if you can trim down your spacers to the min you need to clear the brakes. You probably just need about 12-13mm from my personal experience with most rims I've ran. And for ever 3mm you get back, is about 1* you can get back roughly.
I would bet smaller tires, those are enormous!!! Look up tire calculators and use 205/55-16s for an overall diameter for reference you wanna shoot for the same diameter or maybe smaller. The larger 40 series 18" tires I'd run is 235/40-18s. Even those are larger than usual.
Also, why do you want to run such wide tires? Wider tires mean, more fender work you'd need to clear them.
My current setup is 18x10 +7 225/40-18 and 18x10.5 +10 235/40-18
If you insist on running 245-265 width tires, you'd need to kick it down to 35 series tires and massage the fenders some more or run more camber.
i have seen this car so many time during my lunch break and i lookss sickk
I will give you my pistol ammo at the speed of light towards your doom
humilde_s13 is offline   Reply With Quote
Old 09-20-2012, 08:26 AM   #1662
Fracture
Fracture is an unknown quantity at this point
I'm thinking of running these "http://wedssport.jp/products/tc105n.html"] in 17X9(F) and 18X9.5(R) but I'm not sure what inset to buy that would fit with the stock metal of an S13 hatch. Any suggestions?
Fracture is offline   Reply With Quote
Old 09-20-2012, 09:56 AM   #1663
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Originally Posted by Fracture View Post
I'm thinking of running these in 17X9(F) and 18X9.5(R) but I'm not sure what inset to buy that would fit with the stock metal of an S13 hatch. Any suggestions?
No specific information, no specific answer.
Don't know which offset you want. For the fronts +10 works. Needs a little fender work but it can work fine. For the rears, +10 for the rears will require a lot of camber if you don't want to molest your fenders. So my suggestion would be don't?
Roll pull, depends on your alignment.
Tires, I prefer stretch but if you want to go with meaty tires, your alignment and fenders will need some raping to get them to fit.
For Sale #1 | For Sale #2
Old 09-20-2012, 11:54 AM   #1664
ali-d1936
ali-d1936 is an unknown quantity at this point
Can someone check my wheel offst calculations
Not sure of my wheel offset but took measurements can someone just tell me if this is correct please.
Wheel width (from inside the Lips)
Meaures 9.5inches = 240mm Therefore Centerline of wheel = 120mm
Backspace, *( from the mounting face to the inner lip at the back)
measures 135mm
so 135 - 120 = 15
so the wheels are 18 x 9.5 +15 ? they do fill the arches really well on a s15.
dose this sound right? i was told buying them that they are 18x9.5+35
Pics for ref
Thankyou
ali-d1936 is offline   Reply With Quote
Old 09-20-2012, 12:05 PM   #1665
DJDANGER24
DJDANGER24's Avatar
18x9 +10 215/40 all around on stock metal
f/r need to be rolled unless you run an insane amount of camber.
f: 3.0°
r: 3.5°
DJDANGER24 is offline   Reply With Quote
Old 09-20-2012, 02:51 PM   #1666
Fracture
my bad the link didn't show up
I meant these ^ in 17X9(F) and 18X9.5(R)
I'm not sure how to workout inset as apposed to offset. I know that inset is measured as positive offset from wheel center to stem side but I wanted to get a second opinion just to give myself an idea of what would work.
Old 09-20-2012, 05:36 PM   #1667
fliprayzin240sx
measures 135mm
so 135 - 120 = 15
Pics for ref
Thankyou
Measurement's good but I dont thik they're 9.5j +15. They'd stick out further than that on S15s if that is spot on spec wise. Dont think they'd be +35 either, cuz even 9j +35, the fronts will be rubbing on the suspension. Thats unless the fronts are spaced out. They're probably more 9j +20-25 ish, maybe even +18.
CLICK HERE!!!
Old 09-21-2012, 10:12 AM   #1668
DJDANGER24
DJDANGER24's Avatar
17x9 +10 18x9.5 +10 will work with stock metal but I am not 100% sure on what exactly you are trying to accomplish. Are you going for a wheel offset to fit fat tire or going for a good fitment?
Old 09-21-2012, 11:36 AM   #1669
Fracture
215/40 and 225/45. tire sizing i can figure out on a fitment calculator i just wanted to know wheel insets that would work on s13's
Old 09-21-2012, 05:35 PM   #1670
I'm Redline
I'm Redline's Avatar
After several days and intermittent hours of going through this entire thread, I have come to the conclusion that the guy who posts here, or on NICO who had a zenki/kouki that he tracked was onto something that looked like it worked
17x9.5 +18's with 245-45-17
The photos from the car that was tracked that had this tire/wheel combo had the wheel/tire just barely tucked. It looked good. Now if I can remember where I saw it and get the SUSPENSION set up to clear all that... The car looks like it has the basic spring/shock combo on it with these wheels and tires. I figure whatever wheels with Advan S.4's to clear the edges since they have the highest amount of curve on the sidewall
Am I missing something?
My work in progress...
Old 09-21-2012, 07:50 PM   #1671
drftx
drftx's Avatar
Trader Rating: (42)
drftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant future
Feedback Score: 42 reviews
Send a message via AIM to drftx
i got a question if anyone can answer
i recently sold my old wheels and kept my tires they are 235/40/18 feddy 595's old wheels were work kiwami 18x10.5+23
new wheels are work equip 18x11-9 was wondering if the 235/40 will be too much on a 11? if anyone has pics of a 235/40 on a 18x11 lemme see thxx!
drftx is offline   Reply With Quote
Old 09-21-2012, 08:35 PM   #1672
zooopreme
Trader Rating: (38)
Who in their right mind would ever trade your Kiwami's for Equips? Smh.
Anyway, since they're Federals they run like 245's. 245/40 on a 11"? Doable. Safe? No. If I were you, I'd just run 255/35.
Old 09-21-2012, 09:13 PM   #1673
fliprayzin240sx
No, should clear for the most part. 245/40-17s are the same diameter as 225/40-18s.
Its doable, but I've ran 265/35s and those are stretched on 11j. Stretched like me running 225/40s on 10js.
CLICK HERE!!!
Old 09-22-2012, 02:17 AM   #1674
joeli102
joeli102 is an unknown quantity at this point
I have 17X9.5 +12 with 245/45/17 on my S13 hatchback and I was wonder if it is possible to fit them with stock metal. Should I roll the fenders and then camber or camber and then roll the fenders. I have adjustable coilovers and RUCA
joeli102 is offline   Reply With Quote
Old 09-22-2012, 08:48 AM   #1675
fliprayzin240sx
Its doable but you'd have to run more camber in the back. I fucking hate pulling the rear hatch fenders due to the denting effect. If you pull the rear fenders too much, the are directly on top of the arch have a tendency to buckle in and dent.
CLICK HERE!!!
Old 09-22-2012, 01:50 PM   #1676
MeGusta.jpeg is an unknown quantity at this point
For the front, what size spacer would i need to clear stance coilovers
225/40 on a 17x9.75 XXR wheel
MeGusta.jpeg is offline   Reply With Quote
Old 09-22-2012, 03:02 PM   #1677
zooopreme
Trader Rating: (38)
No. Go search.
XXR spacer fitment bullshit is easy to find.
Old 09-22-2012, 04:52 PM   #1678
fliprayzin240sx
Originally Posted by zooopreme View Post
No. Go search.
Plus it doesnt do just jack and shit if we dont know the offset.
CLICK HERE!!!
Old 09-23-2012, 12:14 AM   #1679
joeli102
So just camber as much as possible in order to pull as least as possible... Does anyone have photos of a set up like this?
Old 09-23-2012, 12:53 AM   #1680
MrSanchez925
MrSanchez925 is an unknown quantity at this point
Question, I just picked up a pair of 17x8.25 +25 F & R for my s13. And am planning to lower the car a significant amount, (tucking tire) and possibly throw in a 15mm spacer in the rear and a10mm up front.
I am debating weather to run a 215/45/17 or a 205/40/17. What are your suggestions?
MrSanchez925 is offline   Reply With Quote
