Old 10-15-2019, 05:43 PM   #1651
jr_ss
Have you tried short shifting 3rd and getting into 4th at say the 1000’ mark?
Old 10-16-2019, 08:02 AM   #1652
tuzzio
tuzzio's Avatar
I'd like to give it a shot next year.
Starting to do some research on wheel / tire sizes.
Currently running 18x9.5 +22 235/40. As the car is rather low. I'd like to find something that would be similar. Not opposed to running spacers if its more inbound toward the coilover as the car has ARP extended studs. Seems like a 15" wheel is common with like a 26x10 tire? Any recommendations?
Old 10-16-2019, 06:03 PM   #1653
jr_ss
15” rims offer the cheapest and best options. You can run 16” but your selection narrows and tires become more expensive. I have Z32 TT rears with 255/60/16 ET Street SS tires waiting to go on. Prior to that, I ran BFG Comp drag radials in the same size. Without heat in them, I would spin through 2nd. Heat them up and I’d get solid traction in second with little spin. Mind you, this was on the street. The drag strip was a different story.
You also have to consider your FD ratio and the track you’re running at. 1/8 and 1/4 miles have completely different setups. A taller tire will change your effective ratio and could push you to shift extra in the 1/4. If you already have a lower numerical ratio, you’ll want a smaller tire unless you’re making big power.
Old 05-23-2020, 12:11 PM   #1654
s14sfreakaleak
s14sfreakaleak is an unknown quantity at this point
would 15x10 with 5.5 backspacing work with a s14? anyone running that i see most run the 15x8. looking for a rear set up on my 2j s14.
s14sfreakaleak is offline   Reply With Quote
Old 05-23-2020, 03:42 PM   #1655
jr_ss
Short answer no. You need higher offset/more back spacing unless you want huge amounts of tire poke.
http://www.wheelspecialists.com/wheel-specs
Old 05-24-2020, 04:38 PM   #1656
s14sfreakaleak
thank you jr_ss.....so i need to stick with the 15x8 with 6.5 BS as most s14 run? i don't want poke at all i want my fenders untouched stock body
im going to keep that link saved and look at it! thanks!
Old 05-24-2020, 07:03 PM   #1657
jr_ss
Most guys aren?t making enough power to warrant more than what you can get on an 8? rim. 10?s just add weight and rolling mass.
Ideally, 5.75-6? would be best, but the 6.5?s work, especially on tires that grow.
