#16591 |
but as a track car that is run for 30 seconds a run once or twice a weekend. I could definitely survive that and there would be 0 suspension travel so I could set my suspension where I wanted it and not worry about body roll and rubbing the tires or the wires under the front fenders.
#16592 |
![]() Join Date: Jun 2013
I think I damaged the plastic bit on the nozzle of my #3 injector when I was pulling them out (SR20DET).
Is it okay? The one on the left is damaged, the one on the right is non damaged ![]() I also lost one of the metal washers that goes between the rubber bushing and the injector under the fuel rail cap. Doesn't look too important though. |
#16593 |
Just installed some megan racing track coilovers on my s13 vert and they aren't very low friendly. I've already removed a collar from each corner. Any other suggestions?
#16594 | |
Instagram username:angelmkiv |
#16595 | |
"Hey dude, just bought some new __________ for my S13 track car! ![]() "Awesome ![]() |
#16596 | |
![]() OE - 238, 242 Advertised duration. Numbers for duration at .050" are typically 33% or so less, maybe lower(A 278 has ~220 @ .050") Stage I - 258 - 260, can be used with OE components and OE ECU in most cases Stage II - 266 - 272, requires aftermarket valvetrain components and ECU tune, Headers, free flowing intake and exhaust The build of the engine should dictate the use of the vehicle. A DD will work and perform better at Stage I or Stage II, as Stage III builds are overly aggressive for the street and have the street manners of a crack whore(none). For the track, drift will require a totally different set up than drag or road race/solo(Auto X). For DD and Auto X, Stage I set ups shine, and Stage II set ups work well on longer tracks with less technical parts. Stage III set ups kill on drift, drag, and road race, but you dang well better have Stage III skills and not OE skills when you decide to go there! Stage III 280+, See required components for Stage II
#16597 |
Can anyone verify that the NEW Origin Lab Rear Overfenders for the S14, have higher arches than stock? It could be the picture on there site but it seems that the wheel arches are higher than stock.
#16598 | |
You really need a new pintle cap. I no longer have the link, but google it, they're like $2.50 each. You can also buy the rubber isolater part that your little metal bit came off. Personally, I'd cut it another piece of metal - that's not the kind of bushing that really compresses when it's in place, there might be a bit less support, and the injector might be more prone to leaky o-rings or something, I don't know. |
#16600 |
AFC #1
![]() Join Date: Oct 2003
They all fit. Some of the latter ones have a better CHRA. That has nothing to do with fitment.
#16601 | ||
#16602 | |
#16603 | |
![]() Join Date: Oct 2012
They are called HKS "STEP" 1, STEP 2, etc. http://www.frsport.com/HKS-22002-AN0...3_p_16527.html |
#16604 |
![]() Join Date: Aug 2010
![]() Feedback Score: 8 reviews
OK so I have an RSEnthalpy tune for n62 maf, and having a bit of trouble with hooking it up.
There's a million pages on how to wire them, anyone point me to the right one as some are different? also where are you putting the MAF? in the stock location? can you do it with the stock intake pipe? because I can't get the stock pipe to fit over it and cant find any adaptors anywhere to get it to work! I'd like to keep it as simple as possible |
#16607 |
Need help
I searched no spark. So now I'm asking I've got a redtop that has no spark. Fuel pump works. I have a 1993 q45 ignitor I wired it in by a diagram. Plus I have 3 plugs don't know we're they go. Is anyone in the fredericksburg
,partlow area I need help or I'm going to say screw it and take car motor and all to scrap yard ill take the 200 dollars over this headache |
#16609 | |
http://www.amsoil.com/shop/by-produc...?code=ASLQT-EA If you had to choose between these two obviously choose 75W-90. http://www.amsoil.com/shop/by-produc...e-gear-75w-90/ However, I highly recommend using GL-4 oil: http://www.amsoil.com/shop/by-produc...r-lube-75w-90/ A lot of transmissions these days run completely fine with GL-5 gear oil, but older cars like 240s have transmissions that are more suitable with GL-4 oil. Im currently running that exact Amsoil GL-4 oil in my tranny right now. Basically, some of the chemicals in GL-5 oil that aren't present in GL-4 oil slowly eat away at the synchros in your transmission. Something in your transmission that is slowly being eaten away doesn't really sound like a good thing. Glad to see another person using Amsoil gear oil for their tranny fluid though. |
#16610 | |
#16611 | |
#16613 |
![]() Join Date: Sep 2012
does anyone know of a company that sells silvia fenders that arent vented and made to go with aero? want an oem look but people want a decent bit of coin for some fucked up metal ones.
#16614 | |
Also, if you cannot absolutely find anything, disassemble the intake plastic piping from the air filter up to the throttle chamber to see if there is anything inside the throttle chamber causing it to slowly close. |
#16615 | |
http://www.ebay.com/itm/1989-1994-Si...2e0874&vxp=mtr Non-vented on the side (which is what I'm assuming you're looking for), but have thin venting on the rear part. |
#16616 | |
#16617 | |
![]() Join Date: May 2013
Tomorrow I will dissassemble the intake piping to see what in the hell is going on. Thanks. |
#16618 | |
Does anyone have any suggestions? |
#16620 |
![]() Join Date: Mar 2011
Trader Rating: (18)
![]() ![]() Feedback Score: 18 reviews
Quick sr20 question.
If I have a redtop and swap over the t25 for a forced performance big t28 (gtir guts, t25 housing) will I need a retune if I run stock or just over stock boost pressures? |
