#15903 |
How do you tell who sells genuine OEM nissan stuff?
S13 s14 Nissan SR20DET Timing Chain Kit Silvia 180sx 200SX 240sx | eBay Claims to sell OE components and FRSPORT 13028-53J03 Kit OE Complete Timing Chain Kit S13 S14 S15 SR20DET claims to sell OE components of course if they're both real OE stuff you'd want to go with the cheaper set. But there must be a catch here.... also What set of bushings would you buy? http://www.frsport.com/DIF-10038-Sol...4_p_15144.html http://www.frsport.com/Stance-ST-42-...4_p_26421.html Is it necessary to raise the subframe slightly for lowered vehicle suspension geometry? Does the style difference matter? DIF using 2 halves per bushing and stance using just one piece? |
#15904 | ||
#15905 |
Would this fuel pressure regulator work for e85, 300-350 whp?
Tomei 185002 Fuel Pressure Regulator Type L (Large Diaphragm) I've been reading that you either want it at 3 bar fuel pressure at idle or 4 bar, although 4 bar puts more strain on things but atomizes better. I've read through this whole description and it doesn't mention anything about 3 or 4 bar, or if its linear or not, or even if its adjustable. |
#15906 |
Hey whats up everybody I have a silly question, but just figured I'd ask anyways..
I have a friend thats selling an LSD that belonged to an S14 and I was wondering if it might fit on my S13. He wasnt too sure when I asked him and I dont want to try to put it on just to find out it wont fit, so if anybody knows please share your knowledge and educate a fool like myself. Lol |
#15907 | |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
DLG - DIRTYLOVE |
#15909 |
The downpipe i just picked up has the o2 sensor bung like 2 inches fromthe turbo. It seems way too close. Its for the sensor that goes to the ecu, Not the wideband. Is this location ok? Or should i move it further down stream?
Edit: i see on the stock sr turbo elbow the sensor is also really close. So i guess thats means its ok. |
#15910 |
![]() Join Date: Aug 2010
Couple of questions:
Do I HAVE to use insulated wire when extending the MAF over on a LHD 240sx swap. Does anyone have a link to a pic of a harness thats been converted? Looking to really stance out my car, I am looking at every part that SPL makes, Do I also need to puchase a LCA to run 6 degrees on the front? Thanks a Million guys
#15911 |
![]() How do you adjust the height on a two collar coilover like this? I've never had one like this before so height adjustment wasn't a problem, but i think after i adjust the collars to proper height to i adjust the knob on bottom to lower the top plate? thanks |
#15912 | |
I think 5 degrees in the front might be the limit for most coil overs. I'd say just extend and weld your LCA for the 6 degrees. Pretty easy. I did it with a harbor freight welder and no welding experience (just read up on the gist of welding) and it's held strong so far for 1 season of drifting. |
#15913 | ||||||
![]() Join Date: Dec 2004
Trader Rating: (58)
Yup, that'll work. I personally don't like sourcing that close to the TB nor do I like T'ing into things, but they do work. I like keeping all sources seperate and into the manifold more to help with potential troubleshooting. Quote:
Hard to say with those pics. Looks painted to me. Quote:
That will be perfectly fine. YOu want to keep the base fuel pressure the same as what your tune is setup for. You can essentially set base fuel pressure at 50, so long as the tune is based off that value. Quote:
![]() Quote:
And in -6* yikes! Just make sure you'll be able to adjust caster and have adjustment in your tie rods to even get that close. -6 is bazaar! Quote:
Now as far as to adjust height, you'll need to raise or lower the perch thta the spring sits on. Lower static height, just lower the adjuster.
#15915 |
![]() Join Date: Jun 2007
Looking for a high-quality, performance shock/strut combo for S13... something with front camber plates & maybe with decent options to lower the car without going stupid low. Pissed Nismo doesn't make them for 13's anymore
![]() For the record, I have HKS Hipermax Performer coils... Looking to sell them off & simplify.
#15916 | |
![]() Join Date: Feb 2012
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
I loveeee my Tein super drifts ![]() |
#15917 |
what are these 3 plugs (2 gray 1 brown) used for? I bought this 89 coupe off a guy and he had really gone to town on the wiring. Shitty job with crimp connections and everything. He told me the car used to be an auto so I assume that's what these are for. Just double checking that I can run my car with a 5 speed manual SR20DET without these plugs?
I really only need the speed sensor working on the transmission. Everything else is unnecessary. ![]() |
#15918 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Yeah, those are part of the auto wiring.
There is a 4th plug underneath that you'll need to jump to allow the car to turn over. Look up 5spd swap wiring if you can find the other plug. |
#15919 | |
Trader Rating: (24)
Ground control sells 8610/yellow combo which is bolt-in, or piece together your own setup (preferred). You'll enjoy real shocks. Ditch the megan outer tie rods while you're at it and never look back. |
#15920 |
Cool, I think the previous owner routed it to the front of the fuse box, I know what you're talking about. I should be good then.
#15922 |
My 1996 daily driver is slightly lowered to where if you looked at it from the side it seems the center of the wheelwell and top of the tire are about touching each other. I'm currently driving around on 18x9's 225/40 tires and with the stock spare tire in the trunk, a 15x5 or thereabout. I mounted the spare to see if i can drive around in it should i get a flat tire. It works but it drops the corner the spare is mounted on so much (about 4 fingers off the ground if i remember correctly) i'd have to drive very slow and carefully and would have one hell of a time getting up driveways. I want to keep my trunk accessible for my daily routines; work, grocery shopping, etc but i'd like to have a larger spare so my car doesn't sit so damn low with the spare on.
My question is how wide or big a wheel/tire can i get to fit in the spare tire space of my trunk and avoid having the board and rug be all wobbly in the center. I'd like the board to remain seated flush and not protrude upwards because of a wide wheel. What sizes have worked for you guys? Links to this topic would also help. I'm almost certain I read about this a while ago but after searching on here and coming up short, i'm wondering if it was some other website I read this about. Thanks in advanced. |
#15923 | |
![]() My inners/outers are Circuit Sports and I rike them. I just do spirited driving and occasional drag racing... However, I do like the 'direct' feel sensation between my hands and the road; so I will likely never go back to an OEM tie rod end. That being said, the HKS coils are amazing and very forgiving... but I still crave a smoother ride if that makes sense. Thanks for the reply brotha- I will look into them!
#15924 |
Trader Rating: (24)
CS, Megan -- same thing.
Koni setup has a DIY on here, but you can do it cheaper if you run z32 or eclipse yellows in back and just do custom housings and race shocks in front. |
#15926 | |
#15927 |
What is a stand alone (MAP style) that can tune an SR20DET and a 1JZ or 2JZ? I'm running an SR right now and want to get something to tune it with that will work for a 1JZ in the future. Something under 2k for all the parts, ecu, harness, any random sensors, etc.
I was looking at haltech but it appears the one for 1800 or so only works well on 4 cylinders and isn't the greatest choice for anything more than 4. |
#15930 |
Bandwagon.
i hate that door stuff. like marshmallow goo lol
try a steamer |
