#15421 |
![]() Join Date: Sep 2012
So, dumb question. My '95 S14's driver mirror has fallen off the track. It seems one of the studs(?) that hold the window to the regulator assembly has sheared off in the window itself. Anyone had this problem? If so, do I need to replace the entire window? If not, anyone know what bolt size I need?
#15422 |
Bandwagon.
no but thanks for trying lol
hmm, cool. or how would we do so to measure it correctly? Checking if my 64" wing is wider, looks like it is.. but at the same time it doesnt.... |
#15424 |
S14 is 68" wide, S13 is 67" wide. These are direct from the dimensional specs for mechanical data for each body type. Unless you can stretch that wing, it is not wider than the car. It is wider than the top of the car, but it is not wider than the body at it's widest point, the rear quarter panel
#15425 |
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
another z32 brake question I KNOW :/
question is : for those of you who have separated the front calipers how much torque did you apply to the bolts that hold the caliper together ? Sent from my iPhone using Tapatalk |
#15427 | |
#15428 |
![]() guys to tuck the fuse box back into the dash,you just have to cut the wires and connect em back once the fuse box its inside right? dumb question but i need a straight foward answer
#15429 | ||
Bandwagon.
remeasured my wing, its 68" so it is wider. Quote:
I say 215/40/17or18 on a 17or18 x 9.5 +12 is perfect. Hatch doe, idk if coupe is different. yes that's what you have to do, usually they rewire the fuse box into their glove compartment. |
#15431 |
I have a question, my throttle body has no throttle body stop screw. I just got one and wondering how it should be adjusted, is there a procedure? I believe i read somewhere that you have to disconnect the iacv than adjust it? please let me know. This is for an rb25
Nothing says racecar like a stock car with no interior. |
#15432 | |
Trader Rating: (92)
#15433 |
![]() Join Date: Nov 2005
Anyone used the VIS copy of the DRFT bumper for S13 pop-ups? I'm looking for how it fits out of the box. I know their new stuff fits well...
#15434 |
Anyone know of a inner tie rod removal tool that works with the 240sx?
I've tried two different auto shops that had the tube style tool and they weren't large enough. The inner tie rods are frozen on good and won't come off with adjustable wrenches. |
#15435 | |
![]() The tube should come with a bunch of different sized ends to use, sometimes you'll have to buy an extra pack to get all the sizes, so that might be the problem.
#15436 | |
Bandwagon.
so school me on S15 HLSD's you need the differential and output shafts and someone told me about having to shim it also in a s13 pumpkin. But I researched that you dont/can't shim an s15 helical... What do i need for it to work |
#15437 |
I think they meant shim the diff so the ring gear interfaces with the pinion gear properly. Just something you do with every diff when setting it up properly, definitely not the same as shimming a VLSD. The shims go between the side bearing races and the diff housing.
#15438 |
![]() Join Date: Jun 2012
I am running a base map from Nismotronic on my KA-T and I want to use an SAFC to prefect my fuel and DEC AIR settings. Now i hear that SAFC II can cause advance in my timing. Is there a way to prevent the timing from being advanced while still controling the DEC AIR settings. Sorry if i sound like a fucking idiot because I dont know much about this whole thing.
#15439 |
![]() Join Date: May 2011
![]() Feedback Score: 7 reviews
Catch can tubing?
Alright so i've been trying out different things for a week and im tired of throwing money away. I've relocated my catch can to the intake side on my S13 SR to help route the lines away from the heat. And the hoses are still getting melted! I've looked into heat wraps and things like that but I thought i'd ask what most people do for this tubing that will actually hold up to exhaust manifold radiant heat.
Looking at - Clear/Braided tubing - Blue Goodyear Hi-Miler tubing - plain black heater hose - stainless AN hoses - bracketed hard lines? Pics aren't enough anymore I need tips on what works! Thanks. |
#15441 | |
Nomex - Fireproof Braided Sleeving If you take an old license plate, wrap it with header wrap, this makes a great fabbed heat shield that will reflect up to 1800* or the temps your headers/turbo manifolds will reach, or you can go to Jeg's and get this: JEGS Stainless/Ceramic Heat Shield Panel - Free Shipping on All Orders @ JEGS If you use the ceramic shield, AND nomex or other wrap/tubing protection, you should be ok You asked for advice on what works. Yes it does make you cry a bit when you pay for it, but you only cry once and you do not buy twice.
#15443 | |
#15444 |
#15445 |
![]() Join Date: Sep 2010
Has anyone wired a bee*r into a single cam? I have tried every which way, follow a couple different diagrams using pin 31 and 22 as well as pin 3 and 31, everything in between, And I have had no luck. No light and no cutoff, nothing. Anyone else have this problem? Yes I've searched and exhausted every which way possible. Am I missing something or is this thing a dud. Help is gratefully appreciated...
#15446 | |
#15448 | |
2. On the left side of the page under Settings & Options, click "Edit Signature" You can choose to use a picture or text as your signature. |
#15450 |
![]() Join Date: Feb 2008
What kind of (semi-flexible) hose can I use to tuck the brake booster vacuum hose (behind the motor/under the lip where the firewall meets the cowl) that won't collapse on itself?
Picture for reference... ![]() The OEM hose seems to be pre formed (for stock location of course) and has a plastic tube inside the straight section(s). Where as the bent sections probably don't have that plastic piece that I can see and are pretty stiff. I have looked around and thought of SS braided line (in black of course), which is cool for me and not worried about price. but I normally see it for pressure lines (i.e.-> coolant/fuel) I thought there might be another kind of hose that can handle vacuum for the brake booster without collapsing.. |
